20 Most Recent 1991 Peugeot 405 Questions & Answers
2answers
Peugeot 406
Most likely the ECU (Engine Computer Unit) is responding to some duff sensor / loose cable / whatever ..
All modern engines have more sensors than you can shake a stick at, some positioned in the most inaccessible places, that can cause the most obscure problems imaginable (remember the Oxygen Sensor in the Exhaust manifold that was 'poisioned' by some dufff supermarket petrol ??)
It's a Peugeot garage computerised diagnostics job I'm afraid...
4/6/2022 9:45:05 PM • 1991 Peugeot 405 • Answered on Apr 06, 2022
3answers
Hi, I've Peugeot 206 model 2004 petrol n
did the head get resurfaced or planed
2/4/2022 5:15:15 PM • 1991 Peugeot 405 • Answered on Feb 04, 2022
2answers
1998 Peugeot 406 1998 estate 1800 petrol fuse box
a haynes handbook,but i doubt it as a lot of immobilisers use the earth side of the relays to cut out engine and circuit diagram would make it too easy for the boy racers to half inch the jam jars.sort of classified info .sorry cant help
3/20/2020 11:16:06 PM • 1991 Peugeot 405 • Answered on Mar 20, 2020
3answers
Peugeot 206shredding fan belt. alignment ok pulleys ok
You've covered all the reasons why fan belts shred. I would suggest looking closer, and making sure the bearings are good in all belt driven devices.
Reply back if you have any further questions.
1/9/2019 10:55:54 PM • 1991 Peugeot 405 • Answered on Jan 09, 2019
2answers
Central Locking Issues on Peugeot 406 exec 2.2 hdi (2002)
Hi,just reading with interest" Ianhende's" problem with his 406, I have the same sort of problem with a 2002 406 hdi (110) i.e hazards going off,plus central locking turning on & off whilst driving. have replaced battery, the mechanic is thinking that it is to do with a faulty door lock, any ideas out there ???? [email protected]
10/30/2018 8:45:43 PM • 1991 Peugeot 405 • Answered on Oct 30, 2018
2answers
406 diesel owners manual
Which model is the car? I have the manual for Peugeot 406 Mar 1999 to 2002 in PDF format. If that's any good to you I can either send it via email or try and find the original link I downloaded it from.
10/7/2018 5:53:20 PM • 1991 Peugeot 405 • Answered on Oct 07, 2018
I have only the oil light on the dash at ignition,
My friend is a part time mechanic he gets his solutions from www.reliable-store.com he gets from their every single detailed info, instructions, diagrams, error codes, troubleshooting, transmission etc. everything on all vehicles, and factory manuals for service, repairs, parts, owner's, operations, maintenance etc. U can get help from there there is a girl at chat she can help you
3/20/2018 5:36:22 PM • 1991 Peugeot 405 • Answered on Mar 20, 2018
7answers
My heater blower on my peugeot expert is not working
hi, had same problem twice with my 98 expert , first time it was heater control board(the slider sends a varying voltage thru the thin green wire at the motor plug, to a semi conductor encased in an ally heatsink when checking motor operation check thick red wire for 12v, and thin green for 1.5-4.5v, depnding on slider movement, and thick green for earth conn) , second fault was overheated conns both at motor conn and at relay(mine was bright green cased one behind glovebox), Terry
3/11/2018 1:20:31 PM • 1991 Peugeot 405 • Answered on Mar 11, 2018
Won't Start & No glow Plug Light on Dash
I am with a similar problem...
After putting on a new sump i found that the starter motor would work cranking the engine but no power is going to the glow plugs. The light on the dash does not appear either.
The relay for the coils does click but that is the end of it. I have a suspission it is the imobiliser but after taking the battery on and off several times to reset... still nothing.
There is fuel, good battery (fully charged), fuel lines are clean pressurised...
Any ideas???
3/6/2018 2:52:07 PM • 1991 Peugeot 405 • Answered on Mar 06, 2018
2answers
Citroen Relay 57 Plate. In the manual it says that
There is no fuse box on the passenger side if it is a R/H drive relay. I removed almost every panel trying to find it despite what the handbook says just ignore it. I finished up going to my local Citroen dealership and asked one of the guys there who said there were just 2 fuse boxes one behind the panel just below the drivers R/H knee and the one under the bonnet. The fuses from the none existent 3rd fuse box are incorporated into the 2 which there are.
2/1/2018 5:32:06 PM • 1991 Peugeot 405 • Answered on Feb 01, 2018
My peugeot 206 heater only blows cool air out the
Sounds like you have a blockage in your water system or your head gasket has blown. If the radiator is full then check the water to see if it is oily or check the oil to see if it is a grey colour as what you are describing is common when the water is not circulating through the internal radiator in the dashboard that air is pumped through to give you the warm air and the car is overheating quickly means the water is leaking into the engine somewhere. If the oil and water are fine then use a garden hose to flush out the water system heater hose.
11/4/2017 12:37:04 AM • 1991 Peugeot 405 • Answered on Nov 04, 2017
Temperature gauge not working
maybe a fuse or a wire got disconnected from the guage
5/18/2017 2:51:16 AM • 1991 Peugeot 405 • Answered on May 18, 2017
My central locking is not workin
if you can hear clicking chances are your motors are shot
3/8/2017 10:33:28 AM • 1991 Peugeot 405 • Answered on Mar 08, 2017
Fuse box diagram peugeot expert 1998
On this website you find fuse box description for Peugeot 405 http://www.autogenius.info/peugeot-405-1991-and-1992-fuse-box-diagram
7/10/2016 9:02:06 AM • 1991 Peugeot 405 • Answered on Jul 10, 2016
2answers
My indicator light at the front driver side is out
do both sides flash fast or just one side ? if it's both sides you may wish to purchase a new flasher relay for your car. if it's fast on one side still... check further to see if there is a burnt out bulb including (if it has one the side marker light).
robert
12/2/2015 6:46:25 AM • 1991 Peugeot 405 • Answered on Dec 02, 2015
How do I download automatic transmission shop manual from Library 629?
i would,nt have thought it would be a good thing to manually shift into first gear whilst going downhill, only use manual shifting from start off ,and overtaking but then the kickdown should be ok for that , not to be used as a brake , how steep is this hill ? i know this isn't what you asked but i dont think theres a problem with it not doing that
7/13/2015 10:39:53 AM • 1991 Peugeot 405 • Answered on Jul 13, 2015
2answers
Rover 400 immobilised and I cant over ride it with my code!!
not sure about this model ,depends on year but removing fuse F! stop immobilisor from working
12/18/2014 9:02:47 AM • 1991 Peugeot 405 • Answered on Dec 18, 2014
Can't enter radio code in puegeot 206 as the numbers 7 and 8 are not on the radio
If you need the code check gumtree.com and search peugeot clarion radio code, they email code from your serial number! Quicker and cheaper than main dealer, I have used them!
12/5/2014 2:52:45 PM • 1991 Peugeot 405 • Answered on Dec 05, 2014
638 questions posted
Popular Products
1990 Peugeot 405
1990 Peugeot 405
103 Questions
2005 Peugeot 405
2005 Peugeot 405
805 Questions
1989 Peugeot 405
1989 Peugeot 405
164 Questions
2006 Peugeot 405
2006 Peugeot 405
161 Questions
Top Peugeot Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Arnie Burke
Arnie Burke
Are you a Peugeot Expert? Answer questions, earn points and help others
View Most Popular
405 Peugeot
  • 405 Peugeot
Most Popular Question
check engine light rough idling
  • Cars & Trucks
