20 Most Recent 1999 Saab 9-5 Questions & Answers
3answers
How to removing the rear bumper bar
Slide under the bumper and look on the back side of it. You will find the bolts that attach it to the body.
3/3/2020 8:40:16 AM • 1999 Saab 9-5 • Answered on Mar 03, 2020
3answers
P1181 diagnostic code
P 1181 code- long fuel trim max value air fuel lean.possible causes fuel filter clogged or restricted-fuel injectors dirty or restricted-fuel level too low during heavy acceleration events- fuel pressure regulator has failed.not supplying enough fuel- water or alcohol in fuel causing low 02 sensor signal during acceleration.
9/14/2018 8:33:53 PM • 1999 Saab 9-5 • Answered on Sep 14, 2018
2answers
Can't get the key out of a 99 saab 9-5
This may or may not work,it worked on a different car. Try shaking the steering wheel back and forth while pulling on key, or turning ignition. Hope it helps.
2/24/2018 9:52:19 PM • 1999 Saab 9-5 • Answered on Feb 24, 2018
2000 9-5 wagon 2.3L turbo. trouble light comes on
For the amount of money it will cost it would be worth changing the thermostat anyway. They aren't very expensive and reasonably easy to repair. Water pump replacements are more expensive AND more work. Try the cheaper one first as thermostats are known to wear out. If the overflow tank is backing up it will be because the safety valve built into the water pump is diverting built up pressure.
2/11/2018 9:06:36 PM • 1999 Saab 9-5 • Answered on Feb 11, 2018
1999 Saab 9-5 problem with
Check the idle air control (IAC) sensor and the throttle position sensor(TPS).
2/4/2018 12:50:43 AM • 1999 Saab 9-5 • Answered on Feb 04, 2018
A saab dealer told me that they can order a belt
probably just shorter belt will not go round air-con
2/3/2018 8:03:06 AM • 1999 Saab 9-5 • Answered on Feb 03, 2018
I bought a 2002 9-5 saab from auction, but it
you will have to go to the dealer and see if they can replace the key if not then you will have to replace the entire lock cylender
7/14/2017 5:38:45 AM • 1999 Saab 9-5 • Answered on Jul 14, 2017
Missing, running rough
head gaskets do not "dry out" running rough indicates injector problems --stale fuel dirty injectors or sticking injectors run the fault codes to determine fault area oil around spark plugs indicates that the rocker cover seal under the plug tube is leaking into the plug area
7/1/2017 4:01:01 AM • 1999 Saab 9-5 • Answered on Jul 01, 2017
Power steering pump failure
there may have been air trapped in the power steering system. Keep a close eye on the system & your oil. Make sure your not leaking (wrong filter etc.)
4/9/2017 8:49:17 PM • 1999 Saab 9-5 • Answered on Apr 09, 2017
Saab 95 1999 started then cut out now will not start up turning over but will not start
my saab did something similar to this except it sounded funny when it turned over (real fast) turns out that it had something to do with variable valve timing piston in heads, they wanted like 1300to repair it so just sold it , hope that s not your problem too
8/25/2016 9:17:22 PM • 1999 Saab 9-5 • Answered on Aug 25, 2016
1999 Saab 9-5 Logo
618 questions posted
Popular Products
2004 Saab 9-3
2004 Saab 9-3
557 Questions
2001 Saab 9-3
2001 Saab 9-3
322 Questions
2003 Saab 9-3
2003 Saab 9-3
335 Questions
2002 Saab 9-5
2002 Saab 9-5
176 Questions
Top Saab Experts
ZJ Limited
ZJ Limited
john h
Sean Wright
Sean Wright
Are you a Saab Expert? Answer questions, earn points and help others
View Most Popular
9 Saab
  • 9 Saab
Most Popular Question
change turbo in 1999 saab 95 2 3t
  • Cars & Trucks
