20 Most Recent 2003 Lincoln Navigator Questions & Answers
I have a 2003 Lincoln Navigator and my brake lights don't work?
Some help here, but you may need an auto electrician as they are very complex. https://www.google.com/search?q=2003+Lincoln+Navigator+brake+lights+don%27t+work ..
12/7/2023 5:29:26 PM • 2003 Lincoln... • Answered on Dec 07, 2023
My 2003 LIncoln Navigator liftgate is not working.
check relay and fuses,make sure that automatic liftgate is on. You will have to to the command center and go through the defaults and make sure that the system is on. if you are not comfortable doing that, disconnect battery for approximate ten minutes, this will reset the system defaults.
1/2/2023 11:14:54 PM • 2003 Lincoln... • Answered on Jan 02, 2023
2answers
2003 lincoln navigator wont air up with new compressor
Try this.... My 2003 Lincoln Navigator was manufactured May 22, 2003 so it's the late model that came with the Intec 5.4 Liter DOHC V-8 (not the Triton engine). I replaced the two front ride height sensors (one for each air strut) and replaced the one rear ride height sensor (passenger side) that controls the ride height for BOTH rear air struts. That solved the problem for a few months during warm weather, until the weather started cooling off. Then back to the same issue. The front passenger air strut started releasing air from the solenoid (air block) making a "hissing sound." Replaced BOTH front air strut solenoids (connected at the top of each air strut). That also resolved the problem for a few days. After going all around the world, I discovered it's the Air Ride Control Module (ASM) that was the problem all along. This is most likely the culprit for your air ride suspension problem.
11/16/2022 5:04:56 AM • 2003 Lincoln... • Answered on Nov 16, 2022
3answers
Where can I locate anti theft code to reset radio
This is something I believe your dealership can help you with, or the instructions that came with your radio.
7/14/2022 6:47:52 PM • 2003 Lincoln... • Answered on Jul 14, 2022
Air stops blowing through the vents when accelerating
u have a loss of vacuum to the ac mode control switch, this switch applies vacuum to diff vacuum motors to move air to diff outlets, dash, floor, defrost etc. either the vacuum line or vacuum resivior at the engine is leaking or the mode control is leaking vacuum.
7/10/2022 12:43:43 AM • 2003 Lincoln... • Answered on Jul 10, 2022
2answers
2005 Lincoln Navigator. Message says to Check
Most likely the problem you are experiencing with the park assist is a fault in one of the sensors mounted in the rear bumper. I would not consider it to be a major fix, however there will be a few hours labor involved as the bumper cover needs to be removed to replace the sensors.
6/15/2022 5:11:26 AM • 2003 Lincoln... • Answered on Jun 15, 2022
2answers
03 navigator gear shift gets stuck in the parked
The switch on the brake master cylinder is FAMOUS for shorting out. Unplug it and find the blown fuse. In the fuse box under the hood, fuse 1.5 Your truck may be under a recall for that switch, call the dealer with your VIN number and see if it qualifies.
6/15/2022 5:04:24 AM • 2003 Lincoln... • Answered on Jun 15, 2022
Trying to replace starter motor for 2003 Lincoln Navigator
Some starter motors can be a tight fit in the mounting hole. Using a WOODEN block or the HANDLE end of a hammer Tap the motor firmly, NOT hard, to the left, right, up and down. This should loosen the motor enough to slide it out.
2/5/2022 12:12:32 PM • 2003 Lincoln... • Answered on Feb 05, 2022
2answers
I have a 2003 lincoln navigator. when i start it in the morning the engine get acceleration and deacceleration, it does this for maybe a minute , then runns perfect. the computer shows some codes
Go to an Autozone, Advance auto, or Oreilys for a free Code scan. This will tell you some or all of the problems. Usually this symptom is a result of a bad O2 sensor changing the fuel mix (floating)from lean to rich or the temperature sensor messing with the "cold start sequence".
2/4/2022 4:25:13 PM • 2003 Lincoln... • Answered on Feb 04, 2022
2003 Lincoln navigator manual
google 2003 Lincoln navigator manual took less than 3 seconds https://www.lincoln.com/support/vehicle/Navigator/2003/owner-manuals/
1/1/2022 7:48:52 PM • 2003 Lincoln... • Answered on Jan 01, 2022
My Menu to turn on or off option does not appear anymore
DISCONNECT THE BATTERY FOR 10 MINUTES. THEN RECONNECT AND START AGAIN
11/3/2021 4:29:11 PM • 2003 Lincoln... • Answered on Nov 03, 2021
2answers
Where is the secondary fuse box on a '03 navigator
YOU HAVE FUSE BOX INSIDE PASSENGER COMPARTMENT.LOCATED UNDER DRIVER SIDE INSTRUMENT PANEL.YOU HAVE FUSE AND RELAY BOX UNDER THE HOOD ON THE LEFT FENDER WELL.
10/18/2021 12:38:40 AM • 2003 Lincoln... • Answered on Oct 18, 2021
2003 Navigator. Do I have to remove the fan to replace the radiator?
I would just to get myself more work space. If you have to juggle the new radiator a fan blade into it will ruin your day.
9/23/2021 9:26:15 AM • 2003 Lincoln... • Answered on Sep 23, 2021
2answers
Is there a rear condenser fuse on 2003 Lincoln Navigator
Condenser? What type of condenser? The AC condenser is in front of the radiator. Condensers don't have fuses, they are like a radiator for AC refrigerant gas to cool it, before going to the compressor.
Lincoln Navigator (2003-2006) fuses and relays - Fuse-Box.info
https://fuse-box.info > lincoln > lincoln-navigator-2003...
The Power distribution box is located under the right-hand side of the instrument panel. ... To remove the trim panel for access to the fusebox, pull the panel ...
2003-2006 Lincoln Navigator Fuse Box Diagram
https://knigaproavto.ru > shemy > 585-2003-2006-linc...
Jun. 21, 2018 - Fuse Box Diagram Lincoln Navigator (U228; 2002, 2003, 2004, 2005, 2006) Condensers and Evaporators, no fuses, it is all to do with plumbing and liquid or gaseous gas. https://www.ebay.com/b/Condensers-Evaporators-for-2003-for-Lincoln-Navigator/33547/bn_87489186 ..
9/2/2021 2:11:40 AM • 2003 Lincoln... • Answered on Sep 02, 2021
2answers
03 lin nav wont go into gear after being towed
who towed it was there a towing sequence eg take a fuse out ect like some other cars
3/23/2021 1:39:24 AM • 2003 Lincoln... • Answered on Mar 23, 2021
2answers
Prndl error
PRNDL ERROR NO PARK ASSIST ITS A RELAY burn check your relays before you take it to the mechanic
11/5/2020 6:36:53 AM • 2003 Lincoln... • Answered on Nov 05, 2020
5answers
Lincoln navigation dvd
On my '06 Navigator the navigation dvd goes in a slot on the console to the left of the passenger's feet. There's a removable panel.
On a side note... does anyone have a newer dvd for Canada? The one that came with my vehicle is compile for the Quebec (*gasp*) market and is outdated.
9/18/2020 1:21:10 AM • 2003 Lincoln... • Answered on Sep 18, 2020
2answers
PRNDL error code
Depending on what the actual code is, the problem is usually the neutral safety switch which is sometimes called the shift position sensor.
8/28/2020 6:23:20 PM • 2003 Lincoln... • Answered on Aug 28, 2020
1,454 questions posted
Popular Products
Top Lincoln Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Lincoln Expert? Answer questions, earn points and help others
View Most Popular
Navigator Lincoln
  • Navigator Lincoln
Most Popular Question
2005 navigator sometimes liftgate
  • Cars & Trucks
