20 Most Recent
Sony KDL-55NX810 BRAVIA NX810 Series 55 Class 54.6 diag. 3D Edge LED HDTV, Black, Full HD 1080p 1920x1080 Resolution, Aspect Ratio 16:9, Infinite Dynamic Contrast Ratio, Viewing Angle Right/Left 17889/89, Viewing Angle Up/Down 17889/89, Audio Power Output Questions & Answers
I NEED CODES FOR MY NEWSTAR NTR-B28Z FOR MY SONY TV
ChatGPT 3.5
User
I need code for newstar ntr b28z for my Sony tv
ChatGPT
Unfortunately, I can't provide specific code for your Sony TV remote without knowing the exact model number. However, you can usually find the code in the user manual of your Sony TV or by contacting Sony customer support. Alternatively, you can try using the auto-search feature on your newstar ntr b28z remote to find the correct code for your Sony TV.
User
ChatGPT
To find the code for your Sony TV using the Newstar NTR B28Z remote, you can try these general steps:
Turn on your Sony TV.
Press and hold the "TV" button on your Newstar remote until it blinks twice.
Enter the code for Sony TVs. Some common Sony TV codes are: 0000, 0011, 0080, 0111, 1234. If none of these work, you can proceed to the next step.
Press the "Power" button on the Newstar remote. If the TV turns off, the code is correct. If not, try a different code.
Once you've found the correct code, press the "TV" button again to lock it in.
If none of the provided codes work, you might need to consult the manual of your Newstar remote or contact their customer support for assistance.
I have a Sony Bravia 4K TV. Trying to download HBO now. Error code 920 keeps popping up.
Okay, Follow these steps to fix out this issue:
METHOD 1: Re-installing the application
Step 1 - Go to the application that you got the error with.
Step 2 - Open that application download page on the Play store.
Step 3 - Uninstall it or even uninstall all the update (If the error came when you were updating the application).
Step 4 - Now you clear the task manager and try installing it once again. If the play store error 920 doesn't come then you have solved the problem and now wasn't that easy. So it's always best to try this step before doing anything else.
METHOD 2: Switching off and turning the wifi (cellular data) on
Step 1 - To remove that load Just turn your wifi off and then turn your wifi on (the same goes with your cellular data).
Step 2 - Now after doing this go to your Play Store application and download the application that you were going to download. Now your Play Store Error 920 won't be bothering you anymore.
METHOD 3: Clearing the cache and data of Google Play Store
Step 1 - Go to settings of your device.
Step 2 - Now find "Applications" option under the settings menu. Here you can find "Google Play Store" option. Open it.
Step 3 - Now, at the bottom, you can find "Clear Cache" option. Tap on it and your all cache will be cleared.
METHOD 4: Removing and adding back your Google account
Step 1 - go to Settings of your Mobile.
Step 2- Now, find "Accounts" and then go to "Google Accounts".
Step 3 - In that section find the account you use for the play store or the account that you were using while the error came in. Once you tap on your specific account you'll find an option to remove the account. Tap on it.
Step 4 - Now you have successfully removed your account and after that re-add your account. After entering your email id and password and hence adding your account. Go back to the play store and find the application that you were downloading or updating when the error code 920 came in. Now re-install it or update it back again. This time you won't be faced with the play store error 920.
For any help visit us: Hbo Go Help
BDV E2100 LOCKED IN TV MODE
Once again a simple GOOGLE search, and the first thing on the list is the manual for this unit!
I suspect this is what you need.
Deactivating the Buttons on the Unit
(Child Lock)
You can deactivate the buttons on the unit
(except for on/off) for preventing misoperation, such as child mischief.
Hold down
(stop/square black button)
on the unit for more than 5 seconds."LOCKED" appears in the front panel display.
The child lock function is activated and the buttons on the unit are locked. (You can operate the system by using the remote control.)
To cancel, hold down
for more than 5 seconds until "UNLOCK" appears in the front panel display.
If that's not the problem, here's the link for the manual.
http://pdf.crse.com/manuals/4446734151.pdf
Code for Sony tv? I am using a universal remote Keyin RM-168E.
All about Universal Remotes and why in 2024 no one uses them!.
https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote
SONY 3 & 4 digit universal codes are
002, 000, 011, 080, 111, 006, 071, 128, 1904, 925, 0000, 0834, 0810, 1685, 1786, 1032, 1972
