20 Most Recent 1999 Ford Taurus Questions & Answers
My coil plug 2 is tilted on the coil pack. I've tried to get the lock tabs on both sides but they only seem to allow one or the other side to clip into place so it has left them sitting at a tilt?
Remove the plug completely and check the internal pin and socket contacts. Spray the outside of the male socket with WD40 and offer the two connectors squarely together until it locks. ..
4/10/2024 11:22:10 PM • 1999 Ford Taurus • Answered on Apr 10, 2024
1999 Ford Taurus stereo wiring diagram
These are the three top websites. According to Just Answer it came with AM/FM Radio, AM/FM Radio Cassette, and two types of AM/FM Cassette / CD Changer. All 4 are shown in the link https://www.justanswer.com/ford/0hkix-find-1999-ford-taurus-stereo-wiring-harness-diagram.html These are the other two websites.
1999 Ford Taurus Car Stereo Wire Colors and Locations
The12Volt https://www.the12volt.com > installbay > stereodetail 1999 Ford Taurus Stereo Wiring ; Ground, Black/Light Green ; Illumination, Light Blue/Red ; Dimmer, n/a ; Antenna, Left Rear ; Front Speakers, 5" x 7" Doors.
1999 Ford Taurus Radio Wiring Diagram
MODIFIEDLIFE https://www.modifiedlife.com > 1999-ford-taurus-radi... Our 1999 Ford Taurus radio wiring diagram shows you all the radio wire colors and what they do. Table of Contents. 1999 Ford Taurus Radio Wiring Diagram; 1999 ... .. Here is the AM/FM Radio wiring 2006-11-30_195850_radio1-undefined-undefined-0.gif
5/28/2023 6:24:34 PM • 1999 Ford Taurus • Answered on May 28, 2023
1999 Ford Taurus. I want to do a TCM reset. It goes into gear but only briefly!
Question edited for clarity. Question moved to model category. There is no such thing as a 'hard reset' on a car. You are getting confused with phones and tablets. Disconnecting the battery just clears any saved data, and that won't help you. You are falling into the 'let's try replacing this' method of car repair. It is costly and it doesn't work. If you replace the TCM and ECM they need programming to the vehicle. Find a local auto-electrician. He will have a pro grade scan tool computer that will analyze the TCM and the ECM, and the transmission solenoids and the communication between all those parts. The data from that testing will tell you what is wrong and what, if anything needs replacing.
10/19/2022 8:22:51 PM • 1999 Ford Taurus • Answered on Oct 19, 2022
2answers
Dash gauges all die but car continues to run
Most likely is the ecu. the question is it an ECU fault or one of its sensors have it diagnosed at a dealer
9/6/2021 6:43:41 PM • 1999 Ford Taurus • Answered on Sep 06, 2021
Blows cold when first started and then blowes warm
I would replace the AC compressor cycling switch it may be sticking have seen it a number of times. The switch is located in the receiver dryer on the passenger side of the engine compartment. See picture below.
9_14_2012_7_34_09_pm.jpgIf this isn't the problem the AC compressor relay may also cause this, flip a coin.
5/11/2021 1:18:35 AM • 1999 Ford Taurus • Answered on May 11, 2021
Relay FOAB-14B192-AA
FOAB-14B192-AA is a fairly common Ford relay. It used for switching high current loads such as lighting or A/C.
5/21/2020 9:20:29 AM • 1999 Ford Taurus • Answered on May 21, 2020
Is there a modulator valve on my 99taurus
No you have an electronic pressure control and other switches what is the problem your vehicle is having? Go to rockauto.Com and look up your vehicle then go to automatic transmission and you'll find all the switches and solenoid valves
9/15/2019 12:00:14 PM • 1999 Ford Taurus • Answered on Sep 15, 2019
5answers
1999 ford taurus overheats boils out of res.new
It sounds like you have an air pocket in your system. By the RH strut tower take the heater hose loose from the metal line and fill the cooling system when coolant starts coming out reconnect the hose. If that doesn't work jack the car up where the over flow tank is the highest point and fill the cooling system.
8/13/2019 2:30:59 PM • 1999 Ford Taurus • Answered on Aug 13, 2019
1998 ford taurus left turn signal blinking fast
Replace the bulb that stays on and doesn't blink, if that doesn't solve the problem, let me know.
5/30/2019 12:26:32 PM • 1999 Ford Taurus • Answered on May 30, 2019
1999 taurus turn the key to the start position
We will have to pinpoint what the engine is missing.
- Spark
- Fuel
- Compression
All three of these are tested when the engine is being cranked over. There are two way of checking for fuel. Fuel pressure and fuel trigger. Both are very important and must be present for the car to start. Fuel pressure is self explanatory. You just hook up the gage and see what the reading is. Fuel trigger is check with a noid light. The injector gets unplugged and the noid light gets plugged in to the injector clip. With the engine cranking over, this light must blink. This is the signal to the injectors from the computer. You can have all the fuel pressure in the world, but it wont matter if the injector is not pulsing gas into the cylinder like it should! Compression tester, spark tester, fuel pressure gage and noid light are all accessible at your local auto store. All three tests play a very important part in diagnosing a no start condition. Be extremely careful when doing these tests.
Thereis a relay in the Power Distribution Box, that governs the fuel pump (click image for zoom)...
Test it and keep us updated.
4/20/2019 1:46:18 AM • 1999 Ford Taurus • Answered on Apr 20, 2019
2answers
Ford taurus v6 duratec vacuum hose diagram
under the hood is a vacum diagram
1/31/2019 4:24:01 AM • 1999 Ford Taurus • Answered on Jan 31, 2019
2answers
I just need fuel spec for 99 taurus 3.0 ohv i cant
FUEL SPEC FOR 99 TAURUS IS 26 - 45 PSI.
9/30/2018 2:07:48 AM • 1999 Ford Taurus • Answered on Sep 30, 2018
2answers
1999 ford taurus is leaking coolant told heater hose manifold needs replacing for about $500.00
It's very possible it could be leaking and need replacing. $500 is too much to pay for this repair. I would get a second opinion and another cost estimate.
8/9/2018 4:08:42 PM • 1999 Ford Taurus • Answered on Aug 09, 2018
1999 taurus hard starting, once it starts runs fine. it has original coil pack and crank sensor
Does this engine have a cold start mechanism? I would check that out since it appears to be the source of the problem.
4/17/2018 3:46:57 PM • 1999 Ford Taurus • Answered on Apr 17, 2018
99 taurus runs good cold
Check for a broken bushing for the IMRC - intake manifold runner control. Do you know what this is ? P2004 P2006 Intake Manifold Runner Control IMRC Function and Diagnostics
2/8/2018 8:33:45 PM • 1999 Ford Taurus • Answered on Feb 08, 2018
Transmission for 1999 ford taurus
You may want to change your transmission fluid and filter for a start
1/20/2018 4:24:00 PM • 1999 Ford Taurus • Answered on Jan 20, 2018
3,307 questions posted
Popular Products
2001 Ford Taurus
2001 Ford Taurus
2,262 Questions
2000 Ford Taurus
2000 Ford Taurus
2,121 Questions
2002 Ford Taurus
2002 Ford Taurus
1,869 Questions
1998 Ford Taurus
1998 Ford Taurus
1,431 Questions
1996 Ford Taurus
1996 Ford Taurus
1,365 Questions
Top Ford Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
xxxxxx xxx
Are you a Ford Expert? Answer questions, earn points and help others
View Most Popular
Taurus Ford
  • Taurus Ford
Most Popular Question
k tcm reset 99 taurus gose into gear but
  • Cars & Trucks
