20 Most Recent
2000 Nissan Maxima Questions & Answers
Crank no start 2000 Nissan Maxima
Battery disconnected recently? Security system relearn needed. Is your security light flashing?
Fuel pump?
Damp ignition?
Any one of 20 sensors?
Any codes?
Car only goes 20 mph when ac is on
possible overheated motor and most likely will need a rebuild in the mean time check to make sure the radiator and coolant reservoir are full of coolant under the hood.
It might help but i think at this point the engine has been damaged
My 2000 nissan maxima stalls out in the morning
Sometimes a build up of carbon/varnish just inside the throttle body plate will cause this to happen. Clean it with throttle body aerosol cleaner. Also check the wiring contacts in the plug at the mass air flow sensor for corrosion. It can be cleaned with electrical terminal aerosol cleaner. Good luck.
2000 maxima - firestone just
-Depend on what you asked them to install for you.
-Make sure read all information in the receipt before go back to the shop.
Good luck
Mai
