20 Most Recent 2002 Chevrolet TrailBlazer Questions & Answers
3answers
2002 trailblazer has code p1512
Hello. To fix this issue before you replace your throttle body. Open your fuse box and make sure the 3 shiny bolts are tight as they act as ground and come lose from vibration.. let me know if you need more help.
9/14/2022 6:43:34 AM • 2002 Chevrolet... • Answered on Sep 14, 2022
2answers
2002 Chevrolet Trailblazer. What does 'cal err' mean on my trailblazer radio mean?
Question edited for clarity. Question moved to model category. It appears to be a software error that only the dealership or an auto electrician can fix! https://www.google.com/search?q=2002+trailblazer+radio+cal+error ..
7/13/2022 10:28:48 AM • 2002 Chevrolet... • Answered on Jul 13, 2022
2answers
How many quarts does a 2002 trailblazer take (6 cylinder)
On the 2002 Chevrolet Trailblazer with a 3.4L or a 4.3L the oil capacity is 4.5 quarts.
6/29/2022 7:08:40 AM • 2002 Chevrolet... • Answered on Jun 29, 2022
02 trailblazer code p0740 , P0753, P0758, P0785, P1860 transmission codes what and where are the fuses to check?
You will have to pull the transmission fluid pan off and change the automatic transmission shift solenoids change both 1-2 and 2-3 shift solenoids you also need to change out the torque converter clutch solenoid. it is spring-loaded watch the shift valve when changing the tcc solenoid and pull your dipstick out before putting the pan back on makes it easier make sure to reset codes on the computer after you are done.
5/15/2022 10:08:30 PM • 2002 Chevrolet... • Answered on May 15, 2022
2answers
Can you deactivate the security system in a 2002 trailblazer
It would not be an acceptable thing to comment on this subject as there are people out there that read this public forum that may use any advice offered for a criminal intenstion. Ask your vehicle dealer.
3/17/2022 10:06:27 PM • 2002 Chevrolet... • Answered on Mar 17, 2022
7answers
Hoist to lower spare tire does not work.
Same thing happened to me on my 2002 trailblazer. The last few wraps of the cable was corroded to the point that it wouldn't unwind with the tool supplied. First thing to do is cut the crimped end of the cable off with a grinder or cut off wheel but don't forget to support the spare. This will get the spare out of your way then simply take out the 3 mounting bolts for the cable hoist. At this point you could buy a new cable hoist from the dealer and install it yourself or you might be able to do what I did. I managed to pull and remove about a foot of the rusted cable, slide the rectangular metal piece, that actually holds the spare at the center of the wheel, back on the cable and attach a 1/4" cable clamp to the end of the cable which of course must be in good condition. There should still be enough cable to re-attach your spare to it and hoist it back up. Don't forget to lube things up so it won't happen again. Good luck. (buying a new one sounds better, doesn't it?)
mikethemedic in Hawley,Pa.
9/26/2021 8:51:26 PM • 2002 Chevrolet... • Answered on Sep 26, 2021
2answers
Shift button on a 2002 trailblazer won't engage
Shift Lock Release
This vehicle is equipped with a shift lock release system.
If your vehicle has a dead battery and you need to
have your vehicle towed, there is a shift lock release
lever that will allow you to move the shift lever out
of PARK (P).
To access the shift lock release lever, do the following:
1. Press on the sides of the boot around the shift lever
to release the boot.
2. Lift up the boot on the shift lever and you will see an
orange lever.
3. Press the orange lever down and move the shift lever
out of PARK (P).
4. Snap the shift lever boot back in place.
8/8/2021 9:54:06 PM • 2002 Chevrolet... • Answered on Aug 08, 2021
Is it possible for a break switch to only work the brake lights and not the safety part of the switch on a 2002 Trailblazer
brake light switch does lights and interlock to shift out of park dont know what 'safety part' your asking about
8/8/2021 9:39:50 PM • 2002 Chevrolet... • Answered on Aug 08, 2021
2answers
Where is the oxygen sensor located on a 2002 chevy
On the Air tube intake halfway between air filter and intake!
7/11/2021 4:21:30 AM • 2002 Chevrolet... • Answered on Jul 11, 2021
2answers
2002 trailblazer 4.2 4wd i have a code p1345 that
dammed electronics ,bane of my life so your not the only one and in cases like this i can only suggest you bite the bullet and take vehicle to a main dealer .sorry i know this isnt the answer your looking for but from experiance certain things on modern motors you cannot do your self
6/22/2021 2:31:07 PM • 2002 Chevrolet... • Answered on Jun 22, 2021
2answers
2002 chevy trailblazer just started running rough
Sounds like the engine is not firing on all cylinders. Check the spark polugs and cables.
5/6/2021 6:33:15 PM • 2002 Chevrolet... • Answered on May 06, 2021
2002 trailblazer rear suspension control arms both sides have rusted out of frame do they make replacement mount for these
You will either have to have a metal shop fabricate new mounts and have them grafted in, cut good ones out of a salvage truck and have them grafted in, or completely replace the frame with a good used one out of a salvage yard.
1/27/2021 2:00:55 PM • 2002 Chevrolet... • Answered on Jan 27, 2021
2answers
My "Gate Ajar" light is on eventhough the back
Mine was doing same thing. 03 trailblazer. Mine ended up being the 4 prong connector sensor gear was out of alignment. You have to take the entire latch out to remove the sensors. You can then rotate or realign the gear for the gate ajar switch. This was after realigning the gears.
7/1/2020 9:31:47 PM • 2002 Chevrolet... • Answered on Jul 01, 2020
4answers
Replacing license plate lights on Chevy Trailblazer
I just had the same problem. I took the cover off, saw the white bulb base, twisted it to take it out, but it popped back inside the door. I got it out, but it wouldn't pull through, so I twisted it back in place and went to Autozone to get new bulb. Once I saw the new bulb, it was obvious, just the bulb itself pulls out. There's so little room to work, I couldn't get it with just my fingers - - maybe rubber gloves would have worked, but I used pliers, lightly, wiggled it a little and it popped right out. I had a similar issue once with the taillight bulb and had to break the bulb and then grip the remaining filament wires with pliers to get it out, so that was my backup plan, just in case.
Hope this helps others.
3/31/2020 4:40:52 PM • 2002 Chevrolet... • Answered on Mar 31, 2020
2answers
Rear wiper will not shut off
The switch is wear I would start.
9/30/2019 4:21:29 AM • 2002 Chevrolet... • Answered on Sep 30, 2019
TOTAL POWER STEERING FLUID CAPACITY 2002 TRAILBLAZER
beleive its 2.5 oz
7/30/2019 9:09:29 AM • 2002 Chevrolet... • Answered on Jul 30, 2019
2002 chevy traailblazer head gasket replacement and put it back to gether
If you are asking how to do this, it is not easy, it is very complex and takes a long time. The big points: Drain the coolant, disconnect battery, take off the intake manifold, take of the exhaust manifold, remove the head, clean the head and check for warp and cracks, clean the block and remove all debris from cylinders, install gasket, put head back on, put manifolds back on, replace coolant, change oil, connect the battery. You may have issues with bolts that break or strip out the block, you should send the head in to be checked, the valves and springs should be checked and those seals replaced, you need special tools and reference materials.
6/27/2019 1:43:47 PM • 2002 Chevrolet... • Answered on Jun 27, 2019
2answers
Locate camshaft sensor 2002 chevy trailblazer
Assuming you have a 4.2L engine here is the location.
Hope this helps out,
if so please rate my answers.
Brett
6/27/2019 1:43:19 PM • 2002 Chevrolet... • Answered on Jun 27, 2019
2002 Chevrolet TrailBlazer Logo
3,943 questions posted
Top Chevrolet Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
john h
Are you a Chevrolet Expert? Answer questions, earn points and help others
View Most Popular
TrailBlazer Chevrolet
  • TrailBlazer Chevrolet
Most Popular Question
many quarts 2002 trailblazer 6
  • Cars & Trucks
