20 Most Recent Champion G5NG853S Household Juice Extractor Questions & Answers
Overheating champion juicer
to the person. champion juicer running hot. if your blade is dull it will run hot bcuz its harder to turn and gets clogged easy. look online for new or less used blade.
7/26/2017 3:10:57 AM • Champion... • Answered on Jul 26, 2017
My Champion Juicer rattles.
Where is the noise coming from?
1/28/2016 6:14:24 PM • Champion... • Answered on Jan 28, 2016
I cannot remove the blades from the shaft. This
Do not use WD40. Wear heavy leather work gloves. Lightly tap two flathead screwdrivers positioned opposite each other to initially pry the blade apart from the main body of the juicer. Alternate tapping on the screwdrivers until some of the shaft is exposed. Tilt the juicer towards the blade and drizzle olive oil on to the exposed shaft. Every few hours return juicer to stable upright position and use a hammer to lightly tap a screwdriver positioned at an angle that will not gouge the shaft. Rotate blade manually and tap in different positions. Keep juicer tilted towards blade in between tapping attempts to allow oil to penetrate shaft opening. Continue drizzling olive oil on shaft as it is exposed. Cutter may need replacement after this procedure. Use steel wool to thoroughly clean shaft. Soak Cutter blade in hot soapy water for two days.
2/16/2014 2:40:04 AM • Champion... • Answered on Feb 16, 2014
0answers
Won't turn on
Be the first to answer 2/4/2013 5:33:10 AM • Champion... • Posted on Feb 04, 2013Be the first to answer
0answers
Motor will not run
Be the first to answer 12/10/2012 4:31:55 PM • Champion... • Posted on Dec 10, 2012Be the first to answer
Champion juicer developed a high pitched squeal
Champion Juicer manufacturer has an oil refill for 5 or 6 dollars. I just ordered one and I expect that should solve the problem.
10/15/2012 7:14:10 PM • Champion... • Answered on Oct 15, 2012
0answers
I need a manual for G5NG853S juicer
WHAT DO I DO TO REMOVE THE BLADE IT IS FROZEN?????THE JUICER WORKS PERFECT, I REALLY WANT TO CHANGE THE BLEADE
12/9/2011 5:38:19 AM • Champion... • Answered on Dec 09, 2011
I installed a new hub on a Champion Juicer, reconnecting the wires that are attached to the magnet; when I turned it on there were lots of sparks. Any ideas to what could be wrong?
I have had good experience with their technical support. Corporate Headquarters:PLASTAKET MFG. CO., INC. / Champion Juicer 6220 E. Highway 12Lodi CA, 95240USA Tel: 866-935-8423 / 209-369-2154Fax: Fax NumberE-mail Contacts:Business Relations - [email protected]Wholesale Inquiries - [email protected]
11/23/2011 5:58:04 PM • Champion... • Answered on Nov 23, 2011
0answers
I forgot how to use my champion juicer
Here is a direct link to the User's Manual for a Champion Juicer:
http://www.championjuicer.com/manual2.pdf
To view the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents.
You can download this free at WWW.ADOBE.COM if necessary.
Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.
I hope that was helpful to you, good luck and take care.
Joe.
9/13/2011 7:57:48 PM • Champion... • Answered on Sep 13, 2011
My Champion juicer made noise when I started and
Most likely it will need an overhaul. If you are a "Do It Yourself'er" then you can order a "kit" from the Champion Juicer folks over the phone or through e-mail. When I called, they said it runs about $65 plus shipping. This "kit" is not available on their web site. You'll have to call or e-mail their support staff - which (by the way), is very friendly! Thanks, Chris I. I’m happy to assist further over the phone at https://www.6ya.com/expert/chris_6ddd78f70d3cfe52
8/11/2011 11:11:26 PM • Champion... • Answered on Aug 11, 2011
We just got a 2nd hand juicer CHAMPION model
The CHAMPION juicer manual is online at: http://www.discountjuicers.org/manuals/champion.pdf
If your juicer needs parts or maintenance, the phone support is easy to work with - call them directly at:
(209) 369-2154
8/11/2011 10:58:54 PM • Champion... • Answered on Aug 11, 2011
0answers
How do i clean this thing? thanks,
Thank you for contacting fixya.com.
A motor that rotates a blade called a cutter blade usually runs a juicer. This blade should be carefully cleaned after each use, if not it can become sticky or even vacuum locked, which will make it hard to remove when you do decide to clean it. If you have found that your champion juicer cutter blade has become a permanent part of your champion juicer, follow the directions below to help remove it.But you need to be careful as improper technique may damage the machine. Place a book or small object under the rear of the champion juicer to help elevate and tilt the juicer forward. Be sure to use a flat object so the juicer can stand without falling and possibly becoming damaged.
Insert a small screwdriver between the stainless steel portion of the motor hub and the back side of the cutter. Insert another small screwdriver a few inches from the first one.Apply a few drops of coconut or olive oil between the screwdrivers and let the juicer sit for a few minutes, to let the oil run down inside the cutter.Tap gently on one of the screwdrivers to help loosen the blade. Gently tap on the other screw driver to loosen the blade even more. Continue this process until the cutter is completely removed from the juicer. Wash the blade in warm soapy water and dry with a clean towel.
Please get back to us if you have further query else please accept the suggestion.
6/28/2011 6:28:07 PM • Champion... • Answered on Jun 28, 2011
Champion G5NG853S Household Juice Extractor Logo
53 questions posted
Top Champion Juicers Experts
Aron
ADMIN Andrew
ADMIN Andrew
Are you a Champion Juicer Expert? Answer questions, earn points and help others
View Most Popular
Champion Juicers
  • Champion Juicers
Most Popular Question
champion juicer made noise when started
  • Juicers
