20 Most Recent Envision 19" Widescreen Flat Panel LCD Monitor Questions & Answers
I keep getting a popup
go to setting and turn off notification setting
12/31/2017 5:23:26 PM • Envision 19"... • Answered on Dec 31, 2017
Screen is black when computer is turned on. Tthe
Try a different video card or disconnect the one you have in your PC and use the VGA monitor connection on the motherboard. If it works your video card is gone.
12/22/2017 9:07:42 PM • Envision 19"... • Answered on Dec 22, 2017
I HAVE 19 INCH WIDE
Try monitor on different computer to isolate the anomaly. If it works fine you have an issue with your current computer. If it doesn't then the issue is with the monitor. U might also want to check if the adapter is ok
6/19/2017 10:30:22 PM • Envision 19"... • Answered on Jun 19, 2017
My monitor won't stop blinking.
You could have a faulty inverter board or faulty CCFL lamp which can cause the screen to flash.
Check out LCD Parts for service, parts and DIY info - click on this link to their WEB site. :-
www.lcdparts.net
7/1/2016 8:53:22 AM • Envision 19"... • Answered on Jul 01, 2016
Contrast disabled in sRGB pop up, how to get rid of it
check settings in menu. it seems you have settings for auto instead of adjustable.
4/10/2015 3:10:59 AM • Envision 19"... • Answered on Apr 10, 2015
I can not get rid of the blue screen. it keeps poping u
you are driving the monitor at too high of a resolution. lower it and see if the blue screen goes away.
4/10/2015 3:06:55 AM • Envision 19"... • Answered on Apr 10, 2015
Had been taking several attempts to get it to come on. Sometimes had to unplug and retry. Now only says "Scan TV". Is repair likely to be more expensive that what set is worth?
Sometimes heat is a real big issue with LCD monitors, over time it causes fractures and circuit breaking in the chips and pops off a few capacitors. It is likely that your control board has a couple bad capacitors and/or components that have failed yet have not removed the display capacity. So your T-Con board is likely not the issue. When searching online use your monitors make model and production date and include "Main Control Board" so you can find products that are for your unit. Searching Ebay and Amazon are common places these units will be sold and run anywhere from 5$ to 200$ depending on your monitors grade. Source: http://www.ebay.com/sch/i.html?_odkw=Envision+driver+control+board&_from=R40&_osacat=0&_from=R40&_trksid=p2045573.m570.l1313.TR0.TRC0.H0.XEnvision+main+control+board.TRS0&_nkw=Envision+main+control+board&ghostText=&_sacat=0
3/6/2015 4:55:40 PM • Envision 19"... • Answered on Mar 06, 2015
How do I turn off notice to set display to 1440x 900?
Get rid of the splitter!
7/26/2014 3:59:57 AM • Envision 19"... • Answered on Jul 26, 2014
Sound from built in speakers
There will either be a menu driven volume control or physical volume buttons. Also make sure you have an audio cable plugged in from the monitor to the computer. It will typically be a lime green port on both. Connected by a 3.5mm head phone jack
2/2/2013 10:56:13 PM • Envision 19"... • Answered on Feb 02, 2013
0answers
Will not stay on
Be the first to answer 12/15/2011 11:56:15 PM • Envision 19"... • Posted on Dec 15, 2011Be the first to answer
2answers
Frequency out of range
You need to Set the Desktop Display Settings to match those advised by the monitor... in other words, your desktop's resolution settings aren't supported by that monitor, so right click on desktop, choose settings, and change the resolution (1440 x 900 ) and set the Refresh Rate (60 Hz).
10/24/2011 6:35:57 AM • Envision 19"... • Answered on Oct 24, 2011
My laptop LCD screen is
I would go ahead and boot into safe mode where you say it does work and then take a look. See how it detected it...ie look in device manager and see if it picked it up by it's true brand/type etc. Check the settings both of the display and on the envision itself. Check the resolution selection. It's probably picking it up as a lower res. but when it boots into reg windows may be trying to run at full res and perhaps that's what it won't do. Check to see what driver it's using. It may need the specific driver from envision and not the generic driver. It could also be a bad pin on the envision itself.
If you have another computer you can hook it up to, do that to make sure the envision is working. That way you can deduce which is the problem, the monitor or the setup in your laptop.
7/10/2011 6:40:26 AM • Envision 19"... • Answered on Jul 10, 2011
The on/off button on my
Sounds like one of the buttons is jammed or broken (stuck). Try pressing each button one at a time. Does one not click or feel like the others? You might need to pry at it a little to unstick it. Let me know if that works or not.
7/3/2011 9:26:10 PM • Envision 19"... • Answered on Jul 03, 2011
I dont have sound on
Have you check the connections to green connector on computer?is the volume turned up on the monitor,
6/15/2011 2:17:22 AM • Envision 19"... • Answered on Jun 15, 2011
I keep pressing menu and it tell me OSD Locked?
This has most likely annoyed many of you at some point. You turn on your monitor one day and see a jeering message telling you something about an "OSD Lockout". It doesn't allow you to change any of your monitors settings, including the setting intended to turn off this message. While I've only seen this error on HP monitors I know that others have encountered it on other brands as well. The fixes I provide should work on those monitors too. (Note: OSD stands for On Screen Display.)
Fix One:Plug in the monitor and power it up. Hold down the Power button until you get a message saying "OSD Unlocked". If the problem persists after OSD is unlocked then unplug the monitor from the wall, wait 20 seconds and try again.
Fix Two:Turn on the monitor and hold down the Menu button for 10-20 seconds. This should unlock the OSD.
Fix Three:Turn off the monitor, press down the Menu button and then turn on the monitor. Wait 10-20 seconds. This should unlock the OSD.
Fix Four:The Menu button may be stuck in a pressed in position. To get it "unstuck" you'll usually need to open up the monitor. This could be tricky unless you know what you're doing. Unfortunately there are too many models of monitor for me to provide detailed instructions. If you have warranty this is where you want to contact the manufacturer.
If you think this solution helps you then your token of appreciation in the form of Rating and a testimonial will be esteemed.
Thank you and Keep Visiting FixYa!
4/12/2011 7:42:33 PM • Envision 19"... • Answered on Apr 12, 2011
Moniter will not stay bright
can be due to damage in LCD panel or due to low voltage
4/6/2011 7:08:31 PM • Envision 19"... • Answered on Apr 06, 2011
Monitor displays "no signal" when powered on.
If it has the standard VGA cable just go to your local electronics store and purchase a new VGA cable and all should be fine. I would take the old cable with you that way you are replacing the cable with the exact same type of cable.
3/21/2011 3:24:54 AM • Envision 19"... • Answered on Mar 21, 2011
Envision 19" Widescreen Flat Panel LCD Monitor Logo
59 questions posted
Top Envision Computers & Internet Experts
Alexander
Paul Bade
Grand Canyon Tech
Grand Canyon Tech
Are you an Envision Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Envision Computers & Internet
Most Popular Question
keep pressing menu tell me osd locked
  • Computers & Internet
