20 Most Recent
LG SecurDisc 20x Internal Double-Layer DVD RW/CD-RW Super Multi Drive w/LightScribe Questions & Answers
Ive got a Acer Aspire
Download the VLC media player to play back anything and also download the free version of Ashampoo burning software. With both you are in the drivers seat at no cost.
My dvd not writing but read
There can be several reasons for that. Try to use Nero software if you are using LG SUITE. Also the DVD write speed and format has to match that of your writer. Ate you copying another DVD or writing data or edited media such as movie video or music files? Check compliance format.
HL-DT-ST DVD-RAM GH22NS30 does not
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose DeleteAfter deleting the keys, close the registry editorReboot your computerOpen My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. oryou might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark? ! or a red x right click you will need to update the driver or
hope this helps you
Im having trouble with my
Hello there,
If your LG SecurDisc 20x Internal Double-Layer DVD RW/CD-RW Super Multi Drive
w/LightScribe does not read disc, burn cds or dvd, then it means there is a problem with the lens of the LG SecurDisc 20x Internal Double-Layer DVD RW/CD-RW Super Multi Drive
w/LightScribe.
You will have to replace the LG SecurDisc 20x Internal Double-Layer DVD RW/CD-RW Super Multi Drive
w/LightScribe or have the lens replaced.
Be sure not to use the LG SecurDisc 20x Internal Double-Layer DVD RW/CD-RW Super Multi Drive
w/LightScribe to watch movies as that weakens the lens easily.
Hope this helped.
Goodluck
Elect_Comp
My DVD did not always
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark?! or a red x right click you will need to update the driver or
hope this helps
A friend installed a
this might be because you have not selected the option to burn an audio dvd or your burning software does not support dvd burning
there are plenty of free burning software programs on the internet
http://www.majorgeeks.com/BurnAware_Free_d5839.html
BurnAware Free is one of the most popular free CD, DVD, Blu-ray Disc burning software available for Windows. Using this program you can easily create and burn Audio and MP3 CD, Data and DVD-Video disc, ISO and Cue Image, erase or format rewritable disc, copy your CD or DVD to ISO image.
hope this helps
Device name-HL-DT-ST-DVD-RAM-GSA-H55N
it reads all cds,
click start control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you will see options to update driver,roll back driver,or
make sure that the cd-dvd burner is getting enough power test all leads that are attached to the dvd drive including electrical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose DeleteAfter deleting the keys, close the registry editorReboot your computerOpen My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.as for your computer hanging after it crashes
try uninstalling a few unnecessary programs then click start run type cmd then type chkdsk/r/f which will scan for and attempt to fix any bad sectors and automatically fix any corrupt files on your hard drive this will schedule on restart then defragment your hard drive
hope this helps
My dvd writer (secure disc
It could be a problem withthe lens, you should try cleaning the lens, it's already gone bad there is noharm in trying
If you take a little riskcan solve .
follow the instruction: Don'tpanic its very simply.
- When running your pc , open the drawer.>
- switch off the ac power
- remove power cable & sata or pata cable
- remove all the screw from the back side
- press clip to open the font panel
- reverse the CD/DVD rw
- just remove the cover
- clean the optical lance
- http://www.howtodothings.com/computers/a3631-how-to-clean-a-cd-rom-drive.html
- use a little ( not much )oil place on two steel shaft
- cover all the equipment
- now you can fit to your PC
Ifit does the same problem please change the CD/DVD rw because the lance has defected.
Hopeit will help you.
Don't for gate to vote me.
Not apearing on my computer
1.Install the driver disk that came with the drive.You can even download the driver from the internet from here-
http://www.lg.com/us/computer-products/optical-media/LG-internal-dvd-burner-GH20LS10.jsp .
2.If the drive does not work still then check out the connections made in the system i.e power cable,IDE/SATA connector also check that the data cable {IDE/SATA} is not faulty.Heck the jumper settings
See the drives user maunal to check for jumper settings or try to find the printed sticker/label on the drive
3.If drive does not works your drive is faulty
hope this solves your problem..please don't forget to rate me ....
When i try to copy files in writable disk folder
make sure that the dvd burner is getting enough consistent power (the power might be
cutting in/out) test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty
hope this helps
LG SecurDisc Super Multi internal DVD not working properly
Dear Friend,
You can try this method, firstly u will do right click on my computer at desktop. here is method for doing this thing: right click on computer------->properties-------->hardware-------->device
manager------>right click on your burner
drive-------->properties----->driver------>uninstall.
GO back to the device managger window, click 0n "action" and then on
"Scan for hardware changes".
The OS should find your burner and install back its drivers properly. right click my .
GO back to the device manager window, click 0n "any drive" and then u will see a option on the bar at above "Scan for hardware changes". then click on "Scan for hardware changes",
The OS should find your burner and install back its drivers properly. but if your internet is connected then it is very good. Then u will latest drivers & internet search & update the firmware also.
for any type of drivers u can check this website also: http://www.softpedia.com/ , here u will get any type of softwares @ totally free, you have no need to pay any thing.
Thanks alot,
Sanjeev Suri
Lg writer not work
Is this device showing in Device manager if so try Nero burning room for writing .Also try checking by reading a normal CD
DVD plays in DVD player is not seen at all by Windows XP
Hi,it's obvious from your problem that the particular disc that cannot be viewed on your computer is of a formatt not supported by the windows XP.some DVDs are of low quality which can be viewed practically on any DVD player but as a result of their low quality and the sensitivity of the Windows they are not recognized by your computer.
In as much as other DVDS play on your computer,it means there's no problem with your computer,but an unsupported disc formatt is been trying to be viewed and there's nothing you can do to view a DVD formatt not supported by your computer.please don't be bothered.
Thanks and take care
My DVD/CD-ROM drives stop working. On the device
Hi friend,
Firstly you update the DVD/CD-ROM drives form device manager and restart the system,if nothing happning in that condition you need to reinstall the DVD/CD-ROM drives through CD or net.
Thanks,
