20 Most Recent
Pure Digital Flip Video Camcorder Questions & Answers
Transferred video files from my Flip onto my
You have chance to get back some or all of those lost videos from your Flip Camcorder if you take care.
First things first: DO NOT take any more videos with the memory card or hard disk (on your camcorder) that you want to recover videos from. Take the memory card or disk out of your cam and put it in a safe place. Because if you take any more videos or save any data to your memory card or hard disk, you may quite possibly ruin your chances of video recovery.
Then Connect the card or disk to your computer as it should appear as a "Removable Drive" or put the card in a card reader attached to your PC.
Next, if you are comfortable with using a PC then you can download a data recovery utility that will recover your videos with Wondershare Recovery Software (I once used this program bounded with some other software) from the following link:
Video Photo Recovery (if you are running
Windows OS)
Mac Data Recovery (from
MacUpdate site)
Remember - Do NOT try & write anything back to your camcoder(card or disk) until you can recover your videos safely!
Forgot my flip camera security code
1 Enter the number you think is your 4-digit unlock code. Do it once slowly, so you don't waste the number of tries you're allowed before the cam completely locks. If you never set a code, try 1234. The factory sets this as the default. If that fails, try the last four digits of your home phone number. That's the default of some network providers. If all these fail, go to Step 2.
2 Click the menu key, which has horizontal lines on it. It sits between the left and right soft keys and above the round 5-way navigation keys. You should now see the unlock code bypass screen. Enter your 6-digit security code. Select "OK." If this doesn't work or you don't remember your security code, go to Step 3.3 Try 000000 as the factory default setting for the security code. If that doesn't work, go to Step 4.
4 Call your network's customer service center. Locked ones usually let you call both customer service and 911. However, calling on a separate phone will make entering the code they give you easier to enter and test while they're still on the phone with you.HID KITS.
My flip video has a broken lens. Where can I get
If you've never received an answer to this, I have a Flip UltraHD that had the same problem. I took pictures all along the way of fixing it. Let me know if you'd like to see how to fix it! Not hard at all if you're GENTLE!
Shame on Flip for not making this simpler!
2g FLIP HD camera shows
Keep in mind that this isnt compatible with MAC; try to reinstalkl the software camera and check USB connetcions are right. Uncheck "hidden" files and folders in properties.
Keep us updated.
After removing the movies from
Your videos may still be in the Recycle Bin/Trash. Try plugging the device back in to your computer, then check the Recycle Bin to see if the movies are there. If they are, delete them from the Recycle Bin (or empty the bin completely) and they will be permanently removed from the device.
Broken lens
Had a broken lens as well. As you're probably aware it's not really a lens but a protector like a watch crystal. So I went to a jeweler who said, "Oh I don't know, it's not a watch. Bla bla bla." I said I'm not going to hold you accountable. He said fine. He fixed it easily. $20.
Hello i have a pure
the format in your camera is RAW once its transfered to the PC it is upconverted to a Mpg,Mov or AVI after witch it was not 30 mins in s the first place it was only half that.
Editing a video to say 30 mins can be done in windows movie maker, you might need to add some content to it tho.
The other purpose for this is so you can upload the video to youtube without a time limit restriction.
let me know
Do not forget to rate before you leave. Btw, I’m available to help over the phone in case u need at
https://www.6ya.com/expert/edwy_1a56970cf1ea4620
I had connected my flipvideo to my laptop, when I
Right click on my computer->properties->Hardware->Device manager. In device manager uninstall all usb root hubs under USB. And then connect your device and click on scan for hardware changes in device manager. Your device will be recongnized.
