20 Most Recent
Sony 720W 5-Disc Mini Hi-Fi Component System with Cassette Deck Questions & Answers
Sony Mini - Hi Fi MHC - EC55 won't play
If you've already tried to clean the lens then with no improvement then its down to the laser having failed.
In some cases these are availble as a replacement part but aren't normally cost effective.
CD burned on my computer won't play back on my
you have probles with a driver try to unistall the driver on the cd or dvd burner and automatic it will install the driver the pc will look for the driver on c:hdd if the porblem continue call 956 400 4141 I'm a computer technician send me you info and i will repair you computer problem.
Sony mini hi-fi component speaker does not play.
I need little more info about sound problem, are you not getting sound in dvd playback or it happens in all inputs like FM or tapes etc?
Did you tried audio cd playback to check sound in all speakers?
Thanks.
Everything works except the cd system, it will not
You say it will not play a CD assuming there is a CD that is in there that got stuck!! You say the tray does not open Assuming there is a stuck cd inside.
____________________________________________________________
Warning before opening this unit please consider its at your own risk and not fixya.com. We assume no liability for the damage of your unit based on our solutions. You hold harmless fixya.com and its experts by attempting such repairs. From Body injury or damage of equipment.
1. You need tools (screw drivers)
2. You need to unplug the unit
3. Loosen and take out screws involved
4. Take off cover and try and dis lodge cd
5. Take cd out
6. button back up unit and plug it in and try to eject the tray.
Caution: Do not shoot the messenger
IF THE TRAY STILL DOES NOT EJECT THEN YOU GOT A JAMMED MOTOR OR BAD EJECTOR.. THIS WILL NEED FURTHER REPAIR. PLEASE CONSIDER BEFORE YOU DO THIS WEATHER YOU FEEL IT CAN BE DONE BY YOURSELF IF NOT TAKE IT FOR REPAIRS.
Finally
I/WE are not
responsible for the damage or injury this may have
occurred, You where warned before if your not experienced to not attempt this and take it to a shop. However if you wanted to save money then try to attempt the repair you are to Accept the solution if it worked or reply to the expert if you have another comment.
Thanks for using
fixya.com Btw, I’m available to help over the phone in case u need at
https://www.6ya.com/expert/edwy_1a56970cf1ea4620
I have a Sony STR-AV770 receiver that has stopped
your question depends on how good you are at electronic diagnosis (symptom diagnosis) and how adept you are at removing and installing electronc components. first you have to determine why the amplifier has stopped working on the left channel. Make sure that the problem isn't a simple one, take the speakers off the right side and hook them to the left side and see if you get sound. If you do,, then the problem is the left speaker or left speaker wire. If you don't get sound then tyr taking the input that feeds the right channel and pluggin it into the left channel and listen for sound, if you get sound now the problem was the signal from your source not being sent down the left side.
If it still doesn't work you need to move inside the amplfier, but first, get close to the back of the amp and give a sniff, do you smell anything (a pungent burnt wire or rubber smell) if you do, the the chances are good that some components have burned out. Do you recall having a shorted speaker wire on the left side? shorted speaker wires are notorious (especailly older equipment) for burning out the final amplifer stage. If this was an expensive amp it might be worth fixing, if its not worth much then maybe you should consider religating it to use as a monophonic amplifier (one channel) you could use it to power a sub woofer in a hibryd stereo or surround sound system.
I don't know what more I can tell you at this point. If you go through the steps I outlined, and want to tell me the result I shall be glad to respond and maybe give you another direction to head in. good luck and I'm glad you are adventruous enough to want to try.
