20 Most Recent
Sony Blu-ray Remote for PlayStation 3 Questions & Answers
What do I do when
Have you tried performing a ssystem update? Go to the settings menu and 'system update' should be the first option on the list, then just follow the on-screen instructions
Can't pair up my blu-ray remote with the PS3.
I had same trouble in the beginning.
I have 80G PS3 and tried pairing and also registering.
I solved it by taking out the batteries then going to the menu where it says Register Blu Ray remote (System 2.40 version) then put the batteries back in and you do as the instruction says => Press Start and Enter button at the same time for 10 seconds ... it will say it registered.
I just did it.
My PS3 remote (VP3700) stoped
Hi Jfalker,
first of all check if you have latest PS3 firmware update and of course if the batteries didn't run out of charge.
Then switch on PS3 and HOLD down "START" and "ENTER" buttons on the remote for about 15 seconds, it should pair with your console. If it doesn't work at the first attempt, just try few more times.
If it won't work still, please reply to me and I'll get back to you again.
Regards,
Peter
Blu ray remote will not connect to ps3
I just bought the remote - go to settings, accessory settings, and the register bd remote..it will tell you to press the start button and the enter button at the same time until it registers. hope this helps.
Please explane how to hook my playstation 3 blue
1Insert the two AA batteries into back of the DVD/BD remote.
2Power on your PlayStation 3 system manually. You can accomplish this by pressing the "PS" button in the middle of your wireless controller, or on the front of your PlayStation 3.
3Navigate to "Settings" on the PS3 home menu, referred to as the XMB.
4Scroll down the list of settings and select "Accessory Settings" by pressing "X" on your PS3 wireless controller.
5Select "Register BD Remote Control" by pressing the "X" on your PS3 controller.
6Follow the on-screen instructions that appear for registering your BD/DVD remote control. Once the remote is paired, you can control various multimedia applications on your system.
Ninja saga cheat
i have 1 of them remotes aswell and people arnt answering cause they dont know what you mean by ninja saga cheat but if you cant get it connected what to do is go to accessory settings and thenregister bd remote control and then press start and enter at the same time untill the screen changes and it will then work with the ps3 when thats fone hope this has answered your question
Play station 3 dvd remote pairing instructions.
OK I FIGURED IT OUT!!! First turn off the system(ps3) make sure that you take the batteries out of the remote. Then when you turn it back on go straight to system setting, setting accessories, setting blue tooth device. AND THEN IT WILL TELL YOU TO HOLD DOWN THE START AND ENTER BUTTON DOWN!. Don't forget to put the batteries back into the remote. It took like 3 seconds.
I want to use ps3 Blu-ray DVD Remote as a
This is a rare problem ............ i faced
similar kind of problem
i solved my problem with the help this repair
guide you can also try this out i hope this will help you a lot .......
all the best
click here to download
I have a Harmony Remote. Last week it was able to
Your wireless adapter (WIFI) board/antenna is shot.
Ebay is a good place to find a replacement. If your not under warranty you can take it apart and replace it yourself. I can even provide you with the guide.
Or I can do it for you, your choice
AIM = DBurch1102
The remote doesn't work.
Go into the settings section and then go down to accessory settings and click on "add device" Your Playstation 3 will find the remote and ask if you want to set it up. Just click yes and it will be connected,
The remote works through
blue tooth instead of infra-red like most remotes so you need to pair the remote and the console before it will work. Click on the link below to view the owners manual:
http://www.playstation.com/manual/pdf/BDR-H_T_K.pdf
