20 Most Recent
Verizon Communications Ethernet/Wireless-G Gateway DSL Starter Kit for Questions & Answers
I have a Verizon Wireless DSL Modem/Router GT704WG
hi,
you can try to follow these steps,hope these works
1. Log into router's IP address (192.168.1.1) and enter password. Select "Advanced Setup".
2. Click on Advanced on left hand menu and select UPnP
3. Check all three boxes in window and click on Apply
4. Close router configuration window and run XBox test again.
thanks and God Bless
9/27/2011 2:52:07 AM •
Verizon...
Answered
on Sep 27, 2011
What kind of wireless card
NOTE: Client PCs can use any Wireless 802.11b/g card to communicate with VersaLink. The Wireless card and
VersaLink must use the same Wired Equivalent Privacy (WEP) security code type. The factory default for WEP is
Enabled. Please be sure that your computer's wireless adapter is configured properly for whichever network setting
you use: WEP or WPA. You can access the settings in the advanced properties of the wireless network adapter.
2/23/2011 4:31:00 AM •
Verizon...
Answered
on Feb 23, 2011
I have had the same problem. The aircard shuts itself off.
There is apparently a firmware problem in the Novatel USB727 that causes the aircard to shut off when the signal is handed off to a different tower. I happen to be in a high traffic area so there are several towers in my immediate area. Cell calls are typically handed off when traffic on any particular tower gets heavy. Unfortunately when the handoff occurs, the firmware does not handle it properly and the aircard shuts off. Supposedly new firmware is coming, but as of 8/14/09 none was released yet.
8/17/2009 7:01:24 PM •
Verizon...
Answered
on Aug 17, 2009
Internet connection
connection is OK, try to move the router or the computer close. till you have a good connection. then start move away, till you start to have problem. that is the max distance you can go away from the router.
2/4/2009 8:30:52 PM •
Verizon...
Answered
on Feb 04, 2009
Trying to hook verizon UM150 card to verizon wireless DSL Gateway
the UM150 wireless card goes into the computer.
however, the DSL need to be wired to your computer for initial configuration.
if you just hook up the DSL as verizon say, then you will have a open wireless network, anybody can get access to your network.
2/4/2009 8:26:55 PM •
Verizon...
Answered
on Feb 04, 2009
My internet connection
This is obviously a faulty modem/router. You may either request a new modem from your provider or if the service is not that good, you may consider other Internet providers.
8/6/2008 1:53:34 PM •
Verizon...
Answered
on Aug 06, 2008
Como cancelar el winter driver
EnglishIt is a car, and cars are complexbut no car was told , maker, model , and year.we can not guess cars. post the VIN? and all that is knownname a problem what can't your car do right?name symptoms or evidence that is confusing to you.then answers can happen.onlygood luck , finding itand Mucho Gusto.my guess now is this is posted to computer forumand not to CARS !must be some odd traction controls thing'but 10,000 models of cars,
I need a product key
Have you actually purchased Visio, or are you just trying to get it for free?
As a software guy, I would have to advise against piracy. :)
There are several ways to get Visio for cheap. If you are a student, there are discounted versions available online and in stores. Also, you can check with your school for even cheaper options sometimes. Try the university bookstore if available. Or a Computer Science department maybe.
If you are working, and your company uses MS Office applications, find out if they have the "Microsoft at Home" program. You can get MS Office applications for really cheap that way. I can get Visio through my company's "Microsoft at Home" program for a few dollars.
My Employer Says They Are Going To Cut My Wages. Can They?
If you are in the middle of a contract, then cutting your wages is almost certainly a violation of your employment law rights. While I am by no means an expert on this matter, I did have a similar issue years ago - mid-contract wage cuts - and I hired an
employment attorney to fight the case on my behalf. It turned out that my employer was basically looking to scare people into taking the wage cut.
They got into some pretty serious legal trouble for their transgression, and nothing happened to me in terms of wage cuts after that. If you are between contracts, your employer can re-negotiate your salary, but as far as I am aware, if you are in an agreed-upon contract, they cannot just decide to reduce your salary. If you want to settle matters, contest this action with support from a legal professional.
Solitaire master has a hang
clarify pi please. if you meant pi to mean main screen picture, you probably have used up your free time on this program.
