20 Most Recent
Uniden Corded Phone with 5.8GHz Cordless Handset and Digital Answering System Questions & Answers
Yellow light keeps flashing
It's not one of "our" phones since FixYa neither makes nor sells phones.Without knowing the model of your phone I can't be sure, but I believe you have unheard messages on the voicemail system provided by your telephone company. This system records messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
Lost manual
Since you neglected to specify the model of your Uniden 5.8GHz phone I can only suggest you select it from
the list beginning here to download a copy of the manual.
How to set the number
Since you declined to specify the model of your Uniden system, I can only direct you to select it from the list beginning at
http://www.uniden.com/scat/cordlessphones_mnl
Getting messages from outside line?
Since you declined to specify the model of your Uniden system, select it from the list beginning at
to download the manual.
How do i access my voice mail remotely
to download the appropriate manual.
Where do i get a new battery
You can order the battery direct from Uniden on their online store at:
http://www.unidendirect.com/
It is also possible that Radio Shack may carry a replacement but I highly suggest if you check there you carry the phone handset or at least the battery with you.
Can I add another uniden hand set to a uniden D1680 series
The Uniden D-1680 system can have up to 12 handsets registered to the base. (The phone system was sold in bundles with 0 to 11 accessory handsets.) However, this cordless phone system has been discontinued. I can only find used DCX160 handsets (the compatible accessory handset) on Amazon and E-bay.
I hope this helps.
Sync 2 versions of Uniden Dect 6.0 to work off the same base.
Yes, you can join an older and a newer version of Uniden Dect 6.0 cordless phones to work off the same base. Here are the steps to sync them:
- Disconnect the power cord from the base of both phones.
- Take the battery out of each handset.
- Wait for a few minutes.
- Reconnect the power cord to the base of the newer version phone and insert its battery.
- Wait for the phone to register on the base, which should take a few seconds.
- Once the newer phone has registered, repeat steps 4 and 5 with the older version phone.
- The older version phone should now register on the same base.
- Test the phones to make sure they are working properly.
If for some reason the phones do not register on the same base, refer to the instruction manual that came with the newer version phone for further troubleshooting steps.
