20 Most Recent Whirlpool 21.0 Cu. Ft. Frost-Free Top-Mount Refrigerator - White-on-White Questions & Answers
2answers
Refrigerator won"t cooled.
Find the model number and let me know some things that are happening and not happening and I will help you solve this.Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
10/10/2012 5:10:41 AM • Whirlpool 21.0... • Answered on Oct 10, 2012
0answers
2answers
Freezer items have frost all
A door gasket is the most likely cause with it letting in moist air from the house. The gasket should be snug on a dollar bill all the way around the door.
9/1/2011 4:51:12 PM • Whirlpool 21.0... • Answered on Sep 01, 2011
Ice maker is no longer working
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
The icemaker is 110v
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
First I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
If you still have trouble GO HERE:
http://www.applianceaid.com/procedures.html
I'm
including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
8/27/2011 3:17:24 AM • Whirlpool 21.0... • Answered on Aug 27, 2011
I have a Whirlpool model ET1MHKXM004 ref/freezer.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
5/15/2011 7:20:50 PM • Whirlpool 21.0... • Answered on May 15, 2011
My refridgerator is not cooling properly. I
HI, you will need to inspect the compressor to make sure it is cycling in intervals. if the compressor is not cycling, this will confirm compressor failure. The evaporator fan blows cold air into the freezer and from there it vents into the refrigerator. Occasionally the vents between the freezer and refrigerator can become clogged with ice, food or other debris. In most refrigerators the cold control for the refrigerator opens and closes these vents. That mechanism may become inoperative resulting in the vents becoming stuck open or closed.
Inspect the vents to determine what is preventing the free flow of air. An overcrowded refrigerator or freezer may be the cause. In other cases the vents may need to be cleaned or ice melted away. To remove a build up of ice, use a hair dryer set to "low". Using a higher setting may damage the freezer. WARNING: Do not let melting ice drip onto the hair dryer. In some models, the vent is located under the temperature control console. The housing either snaps into place or is held in place with screws. Remove the screws, or gently depress the retaining clips with a small screwdriver. Allow the housing to hang by its wiring. A freezer vent control may also have to be removed to access the vent. In some freezer-on-top models, it may be necessary to remove the floor of the freezer to inspect for obstructions.
The condenser coils dissipate heat. If dust and debris accumulate around the coils, your refrigerator may not be able to cool properly, it may run continuously or it may stop completely as a result of an overheated compressor. You should clean rear-mounted coils once a year. Unplug the refrigerator before cleaning. Refrigerators are heavy, never tip one forward or backward. Never attempt to move a refrigerator without an assistant. Vacuum or brush the coils. If coils have a filmy build-up, use warm soapy water to clean them. Take care not to spill or drip water onto the components of the refrigerator.You should clean floor level coils at least twice a year. Unplug the refrigerator before cleaning. Vacuum or brush the coils. Remove the grill from the front of the refrigerator and use a vacuum with a wand attachment to remove any dust and debris. The grill should snap off and on. Pull firmly toward you and possibly upward to remove the grill. If it does not come off with a modest effort, check for screws or retaining clips that may hold it in place.
Another inspection point will be the door seals. This is a easy way for the cold air to escape from your unit as well. this will cause the temperature to rise. The seal should make smooth continuous contact with the refrigerator case. When the seal does not seal completely, warm air enters the appliance. This results in more frequently compressor operation and possibly the inability of the appliance to maintain proper temperature. To test the seal, use the dollar bill test. Place a a dollar bill or a piece of paper between the seal and the refrigerator and close the door. Now pull the paper out. You should feel tension as you pull. Retest along the entire door seal. Replace the seal if the test was unsuccessful.
Next will be the door switch. The interior light in most refrigerators, and the fan in some, are controlled by a door switch. When the door is closed, the switch is depressed and the interior light goes off and the fan resumes normal operation. If the door is misaligned or the switch malfunctions, the refrigerator may become warm as a result of the non-operation of the evaporator fan and the heat generated by the interior light. Test the switch for continuity using a multimeter. Set the multimeter to the ohms setting X1. Place a probe on each terminal. The multimeter should change from a reading of infinity to zero when the probes touch the terminals. With the probes still touching the terminals depress the switch, the reading should change back to infinity. If it does not pass both of these tests, the switch should be replaced.
Be sure to confirm evaporator fan function as well. if the fan is defective, it will prevent proper cooling as well.
This will conclude the most common issue with a under preforming unit. I would advise to check all the above and, if the unit continues to not cool after all the above adjustments are made, i will recommend replacing the cold control device,thermostat and main circuit board.
5/1/2011 7:50:11 PM • Whirlpool 21.0... • Answered on May 01, 2011
My frigerator is not cooling.
possible bad defrost timer or it needs freon
4/3/2011 2:06:34 PM • Whirlpool 21.0... • Answered on Apr 03, 2011
Water leak inside the refrigerator
the defrost drain line is cloged
3/8/2011 7:12:08 AM • Whirlpool 21.0... • Answered on Mar 08, 2011
If it says high or low which one is the coldest
looking at the control . if it atate a (A) to g A is the warmest tempt . and g is the coldest . and on a 1 to 9 the higher the numbet the colest the tempt. / hope this helps mm feed back pls ..
2/28/2011 8:47:57 AM • Whirlpool 21.0... • Answered on Feb 28, 2011
Water wont drain stays in
Clogged drain tube, blow it out. You may also have a P-trap in the back of the unit that needs to be cleaned. Remove it and flush with hot water.
2/23/2011 2:28:23 PM • Whirlpool 21.0... • Answered on Feb 23, 2011
When the compressor turns off there is a loud
Compressor is failing, will need replacement soon. The repair is expensive.
2/5/2011 7:54:44 PM • Whirlpool 21.0... • Answered on Feb 05, 2011
Water leaks inside
It's due to wrong temp setting and malfunction of defrost cycling. Keep thermostat setting at 5 degree or little less. And don't keep it in minus,as defrost cycle will take longer time. And also you will get less cooling in fridge compartment and also water leaks.Check drain line hose may freezed. And also freezer tray get blocked due to over frosting around freezer. Defrost manually by unplug your fridge and after defrost all ices, plug again and keep correct temp setting. Thanks.
2/2/2011 5:47:49 PM • Whirlpool 21.0... • Answered on Feb 02, 2011
Freezer is very cold but
did you check freezer fan behind the freezer? If not working check the wiring for it. If broken fan replace it. Find no leak in door gasket. Temp setting must be at least 5 degree.Thanks.
1/30/2011 4:37:35 PM • Whirlpool 21.0... • Answered on Jan 30, 2011
Whirlpool 21.0 Cu. Ft. Frost-Free Top-Mount Refrigerator - White-on-White Logo
Popular Tags
47 questions posted
Top Whirlpool Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Whirlpool Refrigerators
Most Popular Question
water leaks inside
  • Refrigerators
