20 Most Recent
Kenmore 64002 Microwave Oven Questions & Answers
Microwave just stoped working out of the blue
yes its the internal fuse,remove the cover and get a special replacement at the hardware store,but before you reach in discharge the oval shaped high voltage capacitor,it stores upwards of 2000volts a.c,then before you replace the fuse check the capacitor for a short circuit along with the high voltage diode attached to the cap for a short then replace the fuse if no short circuited components are found and plug in and try it
How do I Discharge the capacitor?
Unplug microwave oven, take a long blade screwdriver with a insulated handle, short across the two points of the capacitor and hold it there for 10 seconds to make sure all residual charge is removed.
How do you set the clock
According to the manual, you press the clock button (This is not very helpful!) I imagine you press CLOCK then use the number to enter the time (so for 11:30, press 1, press 1, press 3, press 0) then (probably) press CLOCK again
I have a Galaxy over the range microwave,mod#
There should be a "mini-manual" hidden inside the unit behind the control
panel or hidden behind the grille, which is very
helpful when troubleshooting, & testing.
To access & test the hood vent exhaust fan, you'll have to remove the oven from the wall.
If
so, the installation instructions are very handy, and it's best to have
two people since the microwave can be heavy and awkward.
If you've misplaced yours, you can just enter your full
model number (721.80002401
) at the Sears
parts site.
On the resulting page, look to the right for the blue "View manuals"
button. Click there.
That Sears-related site has many free manuals. While the manuals they
list there are all free, they may ask you to register.
Many times, the owner's manual will have the installation instructions
inside.
If yours is not listed there for free, you would have to order it
through the Sears
parts site.You can remove the oven from the wall, take off the outer cover, plug the oven in, and run it.
Then you can see if the motor leads are getting the voltage they need to run when turned on.
If your cooktop lights recently blew, the resulting surge can damage the controller.
This can often also affect the exhaust fan, cooling fan, turntable, and/or inside light operation, too.
We see (and repair) this a lot. The problem is on the control panel, which
we regularly repair nationwide by mail for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament
shorts, or when the bulbs are removed or installed without first
unplugging the oven from the power line. Either can cause such a
failure on the controller.Details of our service are at
our Web site, along with a video showing how to remove a typical
over the range control panel assembly in under 5 minutes.Feel free to contact me directly with your brand, full model number and symptoms.We're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer.William E. Miller[email protected]http://www.microwavedisplay.com
Cooking
You just place in the food product into a non metallic bowl and set the timer and press start. Not sure what else you are wanting to know.
Let me know how this works out for you.
Benjamin
I have a kitchenaid model kbms1454rss-o and the
You can find
helpful exploded view diagrams and order parts by entering your full
model number from the tag on the oven here.
We're
Turntable support arms
Please post your exact brand and model number so we can steer you to the best supplier.
Otherwise, we may be able to at least give you some suggestions to help you fix it yourself.
