20 Most Recent Broderbund Mavis Beacon Teaches Typing Deluxe Version 20: Mac/Windows Questions & Answers
Says Printmaster is running in another program and to close but don't know how?
Question edited for clarity. Question moved to Broderbund Graphics Press CTRL+ALT+DELETE Choose Task Manager That will show all instances of the program being open. You can End Task on ones that look like they shouldn't be open. Put the EXACT message in here https://www.google.com/search?q=Printmaster+18.1+is+running+in+another+program+and+to+close ..
1/27/2023 8:33:09 PM • Broderbund... • Answered on Jan 27, 2023
I have Print Shop 3.0 and it's been updated to 3.05 running on windows 7 and when I try to import a picture or try to save a project the program closes.I've contacted Encore and they sent me n
Did print shop 3 work properly in win 7? If so you should never have updated. See all the grief it has caused you? Go back and install the 3.0 version and leave well enough alone Or maybe that program is not compatible at all with your OS.I have mo bo's that will not load XP but will work fine with anything prior to that. Computers are unpredictable and down right ornery at times but we need them so have to play by their rules.
9/13/2017 1:27:29 AM • Broderbund... • Answered on Sep 13, 2017
0answers
0answers
Broderbund site
Be the first to answer 11/5/2016 2:13:02 PM • Broderbund... • Posted on Nov 05, 2016Be the first to answer
*.sig to PDF convert
Anyone has experience about the pdf to image conversion toolkit I am tetsing these days? Any suggestion will be appreciated. Thanks in advance. Convert PDF to Image Types in NET pqScan com
12/10/2015 2:31:40 PM • Broderbund... • Answered on Dec 10, 2015
Which printmaster program works with win 8.1
The newest version (v6 Platinum) says that it works with Windows 8. Doesn't say anything about 8.1, but it should be the same. PrintMaster v6 Platinum Broderbund Official Software Site
8/25/2014 3:43:35 PM • Broderbund... • Answered on Aug 25, 2014
2answers
I have windows vista and
BODY { FONT-FAMILY:Tahoma; FONT-SIZE:10pt } P { FONT-FAMILY:Tahoma; FONT-SIZE:10pt } DIV { FONT-FAMILY:Tahoma; FONT-SIZE:10pt } TD { FONT-FAMILY:Tahoma; FONT-SIZE:10pt } People who use Sony and Cannon camcorders may feel frustrated trying to upload their videos to youtube, as thesy are taken and saved as mts/m2ts. Well, in fact, all they have to do is to find an mts to flv converter. How to convert m2ts to flv?
Download and install mts to flv converter on your PC. It takes only a few steps to convert m2ts to flv on Windows.
Step 1: Connect your HD video camera/camcorders to your PC. Copy the videos you want to share to your PC's hard-drive before converting or editing them.
Step 2: Launch the m2ts/m2ts to flv converter. Click "Add files" to browse your computer hard disc and add the .mts or .m2ts files you want to convert. You can load all the source files before the m2ts to flv conversion as batch converting is supported by this m2ts flv converter.
Step 3: Now you select flv as the output format and specify a directory for the output files. This m2ts to flv converter supports comprehensive video formats including avi, mpeg, wmv, mp4, mov, xvid, 3gp and more.
Step 4 (optional): The mts to flv converting program can set the brightness, the contrast and the saturation of your videos, crop, trim videos and even merge multiple files into one single file before the conversion.
Step 5: Click the "Start "button to start the mts flv conversion and all you have to do is to wait until the m2ts to flv conversion is done.
Related article: How to convert m2ts to flv and How to convert mts to flv
2/25/2014 3:46:13 AM • Broderbund... • Answered on Feb 25, 2014
0answers
0answers
Need install cd burner in windows xp
IDE or SATA connections ?????? To enable CD burning for your computer is a relatively simple process in Windows XP. All you need is a CD burner drive installed in your computer, the disk with the drivers and software that goes with it and an XP-loaded personal computer. Once your driver is installed, the process is almost automatic. Here are the steps you should follow to begin creating your own CDs. Check your system requirements before installing the CD burner and make sure that your system can handle the speed and memory requirements of the drive. WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Turn off the computer, disconnect the power cord and remove the cover from the case. Check the IDE cables inside your computer. You may be able to connect the optical CD drive to the same ribbon cable as the hard drive if it is set up as a secondary or slave drive or to a separate ATA/IDE channel by a second cable. Find an empty CD drive slot, remove the plastic cover from the outside, slide the drive in through the back and screw it in place. If you are using a SATA CD burner, you'll need to connect the red SATA cable from the CD drive to the SATA connection on the motherboard or on your SATA drive controller card. With SATA drives, you don't have to fool with jumpers. Attach one end of the separate ATA/IDE cable to the motherboard if you have an IDE drive and the other to the back of the CD burner. If slaving the drive, hook the drive to the second connection on the main hard drive cable to the burner drive. If you do that, you'll have to set the jumpers on the CD drive to the "slave" position. The drive's installation instructions will show you where the jumper pins are and how to set them to the slave position. If using a separate IDE cable, just leave the jumpers in the factory setting. If this is an older drive, you may have an analog audio cable as well that connects to the motherboard. Follow the installation instructions for hooking it up. Close the case and reconnect the power cord and other cables. Turn on the computer and let it boot up. Open the "My Computer" folder and make sure there is a new icon for the drive that you just installed. XP will generally recognize it automatically, but if it doesn't you'll have to reboot the computer and open the CMOS setup program. Follow the instructions for your particular PC to open the CMOS window. Check the ATA channels to make sure both are enabled in setup and that, if you are using a master/slave setup, that the CMOS selections match that setup. Reboot the system. If the CMOS settings are correct, the XP operating system will set your drive so that it uses either digital CD playback (no audio cable) or analog playback (with audio cable). To check, open the "My Computer" window, choose "Properties" then "Hardware" then "Device Manager". You'll see a "DVD/CD-ROM Drives" icon. Click the plus sign next to DVD/CD-ROM Drives folder. Click it, then right-click the icon for the new CD burner drive. Now choose "Properties". If you don't have an audio cable, left click on the selection box for "Enable digital CD audio for this CD-ROM device". Insert the CD burner software disk that came with your CD burner. Insert the disk that came with the drive into the CD drive and install the software following the prompts. If the drive doesn't come with CD burner software, Windows XP comes with a lite version of Roxio's Easy CD Creator that detects blank CDs. Just insert a blank CD in the burner and XP offers you a "burn CD" option when you have autoplay set up for the CD-drive. There are lots of freeware burning software on the internet. http://download.cnet.com/instant-cd-dvd-burner/3000-2646_4-10393316.html Burn audio, video, and data CDs/DVDs and create and burn ISO files. Instant CD & DVD Burner is the ideal choice for anyone looking for a simple but full featured CD/DVD burner. http://www.freeware-downloads.com/nero_essentials.htm nero 8.1 essentials free This is the newest version of the most known CD and DVD burning software, but now with the capability to burn HD DVDs, and Blu-ray Discs http://nero-free.soft32.com/ Nero 9 .4.12 free Create, rip, copy, burn, edit, share, and upload online
11/11/2013 2:49:27 AM • Broderbund... • Answered on Nov 11, 2013
Broderbund Mavis Beacon Teaches Typing Deluxe Version 20: Mac/Windows Logo
2 questions posted
Top Broderbund Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Broderbund Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Broderbund Computers & Internet
Most Popular Question
family tree stored
  • Computers & Internet
