20 Most Recent Casio EXILIM 10.1-Megapixel Digital Camera - Red Questions & Answers
2answers
I have a casio exilim 10.1 camera, how can I get a owners manual?
Many Casio Digital camera manuals are available here: https://world.casio.com/manual/dc/ . Check the full model number since 10.1 indicates the effective number of pixels on the camera sensor. Select your preferred language and then use the drop-down menus to select the full prefix and then specific camera model. There are several Exilim 10.1 MP cameras, including the EX-Z29 and EX Z33. The current link to the Exilim EX-Z29 (North American version) manual in English is https://support.casio.com/en/manual/001/EXZ29_MF_FB_na_EN.pdf . I hope this helps. Cindy Wells
8/27/2019 4:33:31 PM • Casio EXILIM... • Answered on Aug 27, 2019
Where is the service center in the philippines
Check your camera's manual or go to the website for that information
7/4/2014 3:14:24 AM • Casio EXILIM... • Answered on Jul 04, 2014
How do l make videos?
Casio makes a number of different 10.1 megapixel cameras, most of which are available in silver. Which model do you have?
4/14/2013 8:44:45 PM • Casio EXILIM... • Answered on Apr 14, 2013
In casio exilim 10.1 16gb memory card support or not
Casio makes a number of 10.1 megapixel cameras. Could you specify the model of yours?
4/10/2013 4:41:27 PM • Casio EXILIM... • Answered on Apr 10, 2013
The camera dose turn on
Try the procedures in this tip.
1/28/2013 6:42:40 PM • Casio EXILIM... • Answered on Jan 28, 2013
When I turn the camera
1/28/2013 6:42:30 PM • Casio EXILIM... • Answered on Jan 28, 2013
The DCIM applications on my sd card has been deleted,how can i download it back?
You don't need to download anything. Just format the memory card to recreate the DCIM folder.
1/28/2013 6:42:15 PM • Casio EXILIM... • Answered on Jan 28, 2013
After i download pictures from my camera to my
The best way to delete all your pictures from the memory card is to format the memory card.
1/28/2013 6:42:10 PM • Casio EXILIM... • Answered on Jan 28, 2013
Power surge on hub port.
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
If you insist on using the USB connection, do not go through a hub. You can't get enough juice through a hub to download pictures. Connect the camera directly to a USB port.
7/4/2011 10:48:23 PM • Casio EXILIM... • Answered on Jul 04, 2011
2answers
I need to get a
Hi budski99,
You forgot to include the specific model of your camera. Please click HERE and check if this is your camera's manual.
Hope this helps.
2/22/2011 3:54:57 AM • Casio EXILIM... • Answered on Feb 22, 2011
I'll push the power button and the little green
First check the battery. Charge the battery to full condition or change with new battery and try to turn on your camera.
Or you can put off all batteries and memory card, wait for a moment, then put in again and turn on your camera.
Hope this help
2/9/2011 6:04:39 AM • Casio EXILIM... • Answered on Feb 09, 2011
Why does my camera turn on, make a weird noise and
hi. you have problem in lens unit and the weird noise come from to focus gear.maybe you go to the beach or dusty place thats why the said dust or sand goes into lens gear. If you can open and try to clean its better but if not bring to service center and request for cleaning and adjustment.
goodluck my friend
7/13/2010 5:41:56 PM • Casio EXILIM... • Answered on Jul 13, 2010
Lens won't stay out
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
12/28/2009 10:20:05 PM • Casio EXILIM... • Answered on Dec 28, 2009
I need to transfer image from memory onto the card
In the menu, there should be an entry for "copy" which would allow you to copy the internal memory to the memory card.
10/2/2009 10:36:20 PM • Casio EXILIM... • Answered on Oct 02, 2009
Need instructions manual to casio Exilim digital camera Ex S8 12.1 pixels
Look it up on Google
9/16/2019 6:06:50 PM • Casio Exilim... • Answered on Sep 16, 2019
How do I identify my casio camera`s model by using the serial number?
The quickest way is to put the serial number into your search engine. To double check yourself, look thru the images until you see a picture of the camera you own.
8/16/2016 9:03:54 PM • Casio Exilim... • Answered on Aug 16, 2016
Instructions on operation
Digital Cameras - Manuals - CASIO
support.casio.com > Support > Manuals
CasioIn order to use this service to download user's guides and operating instructions (manuals), you must agree to be bound by the following "Terms and Conditions.
Manuals - Support - CASIO
User Manual for Casio Watch Module - My G-Shock
12/28/2015 1:03:33 AM • Casio Exilim... • Answered on Dec 28, 2015
0perating instruction
[PDF]Operation Guide 5410 - Support - Casio
support.casio.com/en/manual/009/qw5410.pdf
CasioThis User's Guide uses numbers shown above to identify watch hands and ..... follow the instructions in this manual, especially the information under "Operating ...
12/28/2015 1:02:43 AM • Casio Exilim... • Answered on Dec 28, 2015
I am asking anyone who has firmware for casio ex z40, to help me clear the system error. please send it to me to my email address([email protected])
Sorry, we don't send e-mails. Only when you have the right tools and software to flash a camera from Casio, you could use firmware. You can't put in there firmware, when the camera is not 100% functional. Once the flashing of the new firmware starts, it can't be stopped, because it is writing new software that has no connection with the older software. And a part of the old with a part of the new software does not make one correct program. So NEVER try to solve a system error with a update. The system error must be repaired by a pro.
3/5/2015 9:57:59 PM • Casio Exilim... • Answered on Mar 05, 2015
How do i unlock the card on my exilim.casio camera
Remove the card and see if the pictures remain on the camera. If they do, then they are stored in camera memory. Make sure the memory lock on the card is in the proper position. Put the card back into your computer and delete the pictures. Then format the card, and try the card again. If the card is still locked, try a different memory card that has been formatted.
2/27/2015 1:24:51 PM • Casio Exilim... • Answered on Feb 27, 2015
Casio EXILIM 10.1-Megapixel Digital Camera - Red Logo
18 questions posted
Top Casio Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Casio Camera Expert? Answer questions, earn points and help others
View Most Popular
Exilim Casio
  • Exilim Casio
Most Popular Question
l make videos
  • Cameras
