20 Most Recent
Electrolux 30" Built-In Electric Cooktop - Stainless-Steel Questions & Answers
Water boiled over on the Right rear induction
Generally there is a number after the F. It sounds like some liquid got into the electrical, sometimes if you wait about a week for it to dry it will work. If not, you would need to call a service tech
always unplug electricity before attempting to repair on any electrical appliance
Electrolux cooktop E14 error
Hello Winnie - Error code 14 means that there is a communication failure with the key sensor for cook place 4 (left position) - right board. Base on the intensity of the issue; contact a professional technician to diagnose the following: Test flex cable between boards, change right board, change center board (on 36" models only), change left board.
Error code E95
hi i could not find this model in the uk european models but i do no that e90 codes usually relate to configuration problems possibly between user interface and powerboard . solutions are usually expensive. just check that bridging connections at the terminal block are correctly in place.
