20 Most Recent Insignia 26 in. LCD Flat-Panel HDTV Questions & Answers
Where do i find schematics for this model
Can you please give the model number.
12/24/2013 4:44:45 PM • Insignia 26 in.... • Answered on Dec 24, 2013
2answers
Insignia 32" begins to power up but shuts down right away
Unfortunately, your TV requires repairs. In-home service can be obtained by calling 1-888-237-8289 in the U.S. or 1-866-237-8289 in Canada.
11/30/2012 11:37:34 PM • Insignia 26 in.... • Answered on Nov 30, 2012
Insigna 37 in screen comes on then off right away
which mean had an error detected by the main board which turn to safety mode. if you will be the one to do the repair make sure you have knowledge in electronic repair since as you know some parts with high voltage. now let first disconnect the connector that supply the inverter board for screen back light just to ensure if their is a shorted component in the board. then turn on the tv unit, if the tv unit doesn't turn off right away that was mean the cause is the inverter board.
9/4/2012 6:50:38 AM • Insignia 26 in.... • Answered on Sep 04, 2012
2answers
No Non-Hd sound
I had the exact same problem on a brand new Insignia 26 " LCD with DVD. Comcast tech was able to fix it by changing the Comcast box diagnostics. Here is what he did. Using the Comcast remote with the TV on - press power, cable, menu in that order. A comcast diagnostic srceen will appear. Select Additional HDMI options, then audio options. Change the audio options to L-PCM. Press power again to exit the diagnostics. That will fix it and you get to use the HDMI cable.
6/11/2012 3:03:27 AM • Insignia 26 in.... • Answered on Jun 11, 2012
Dvd player reads disc error
either a dirty or a bad optical pickup unit inside (it reads the disc).
4/29/2012 12:38:33 PM • Insignia 26 in.... • Answered on Apr 29, 2012
How do I turn off
You mean the CLOSED CAPTION? Look for CC button on the remote.
Subtitles are usually are on DVD which you can turn it on and off under DVD menu setup.
1/5/2011 4:12:51 AM • Insignia 26 in.... • Answered on Jan 05, 2011
Tv turns on then turns itself off within minutes
had a very similar situation with my Phillips 42 in. LCD TV.
Here was my Problem. The Power Supply Board. I opened it up( Warranty was Expired) and found several faulty capacitors on the PSB. Its pretty common. Major Electronic companies were sold faulty capacitors that fail in 2-5 years instead of 10-20 due to a lack of preservatives. It wouldn't surprise me if you have the same problem. TV will work fine for a few years and then just fail completely or slowly deteriorate.
Here are the solutions
1. Have it Repaired
2. Check for faulty caps and if you find some(budged or leaking) you know you have located a problem
Remove the board and replace the whole thing.
3. If you have some soldering skills you can replace the faulty caps.
Caps are very inexpensive, under a dollar in most cases. I replaced 4 for about $5.00
Hope this Helps.
Good Luck
12/10/2010 12:40:30 AM • Insignia 26 in.... • Answered on Dec 10, 2010
The television began losing audio off and on about
the audio problem of your TV is from the sound IC. The sound IC is faulty and it needs to be replaced for your TV sound to come up again.
Concerning the pink picture/color, how long have you been using this TV? Why I am asking is because when a TV color begins to display pink, it means the TV is reaching the end of its life span. The TV tube is going bad, that's why its showing pink.
Secondly, the pink picture is a sign that there is a problem with the CRT. This is caused by failure of the green amp transistor on the TV panel. There is a possibility that the CRT or the transistor of the TV is bad.
I would suggest that you take the TV to a qualified repairman to help you diagnose the problem so that you would know what step to take next.
I wish you good luck.
5/12/2010 1:29:25 PM • Insignia 26 in.... • Answered on May 12, 2010
Turn on TV insignia 26 inch DVD combo. Screen is
Your TV will likely require repairs for this issue to be resolved. Service can be obtained by carrying the unit in to the place of purchase.
3/25/2010 11:56:40 AM • Insignia 26 in.... • Answered on Mar 25, 2010
I have a 26 in insignia tv i need i need help. i
Go to Setup in the onscreen menus, then select Captions and use the arrow keys to highlight OFF; press PLAY to select. Press the back arrow, then Exit. More information can be found in the owner's manual.
3/25/2010 11:54:27 AM • Insignia 26 in.... • Answered on Mar 25, 2010
Aspect Ratio problems with Insignia 26
Keep your Auto Zoom Off set Full screen than only you will get proper picture
1/21/2010 10:09:06 AM • Insignia 26 in.... • Answered on Jan 21, 2010
Volume control on Insignia remote doesn't work..
Your remote control may be faulty. If you can control the volume from the cable box and from the buttons on the TV - then I'm pretty convinced the remote control needs replacing.
1/1/2010 12:40:27 AM • Insignia 26 in.... • Answered on Jan 01, 2010
I just got my TV and a few days later it randomly
Cover up the remote receive eye on the tv and see if it still happens. If it does it is in the set, if not there is a signal coming from somewhere else like another remote possibly a neighbor. Don't know your surroundings just trying to cover all angles
12/30/2009 5:09:47 AM • Insignia 26 in.... • Answered on Dec 30, 2009
I did not choose cable/satellite box in the set
try to unplug and start all over
11/4/2009 2:45:57 AM • Insignia 26 in.... • Answered on Nov 04, 2009
I just bought a new insignia 26 wide flat panel
This web link provides free TV manual downloads for your TV:
http://www.retrevo.com/support/Insignia-IS-LCDTV26-TVs-manual/id/8223ag520/t/2/
7/5/2009 2:17:54 AM • Insignia 26 in.... • Answered on Jul 05, 2009
The DVD player won't work; it spits the the DVD back out
Normal dvd players won't play blu-rays...fwiw.
6/28/2009 7:31:39 PM • Insignia 26 in.... • Answered on Jun 28, 2009
If it is a burnt dvd, it might not play that format. If it isn't, I would take back the tv to where you got it from and get your miney back.
6/1/2009 6:27:33 PM • Insignia 26 in.... • Answered on Jun 01, 2009
Insignia 26 in. LCD Flat-Panel HDTV Logo
Popular Tags
40 questions posted
Top Insignia Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Insignia Televison & Video
Most Popular Question
turn off
  • Televison & Video
