20 Most Recent
Honeywell Wide Breeze 16" Oscillating Stand Fan - Black Questions & Answers
Honeywell air cleaners, can you prevent or repair motors from freezing up?
Oiling the shaft will help considerably, but remember the shaft has two ends and two bearings. People forget about the one at the end of the motor, the other end from the fan which is often hidden. Also motors come in different qualities. Makers tend to go from cheap to mid range as they only have to last the period of the warranty. If you can get a quality motor in the same fitting with ball bearing races, they will basically last forever.
I have a Honeywell 18 inch Commercial grade floor fan, how do I put the fan cage back on the stand?
Hi. These are not bad to reassemble. Do you still have the rubber bushings and related hardware? Since the stand is lighter than the cage. Lay the cage face down and place the metal tubular stand in the correct position. Rotate the stand so the opening of the base (Touching the floor) faces the front side of the fan. Slide the flat washer onto the bolt, place the rubber bushing between the cage and the stand, align the holes and slide the bolt into place and tighten until snug. Repeat the same procedure on the other side, test, and tighten both bolts until bushing correctly supports fan from tilting freely.
