20 Most Recent Frigidaire 30" Self-Cleaning Slide-In Gas Range - White Questions & Answers
2answers
Cleaning the cast iron grates and griddle
Try This....
Place the grates in a sink of hot, soapy water and let soak for 15-20 minutes. For tougher stains, add a cup of sudsy ammonia to the water. Make sure grates are thoroughly dried after each cleaning. After the cleaning process, Lightly coat the bottom of the grates with a cooking spray and then blotting them dry.
Or
If you self clean the oven on occasion, put them in the oven when running the self clean cycle.
7/30/2015 6:58:37 AM • Frigidaire 30"... • Answered on Jul 30, 2015
3answers
Take the grates off and slide them on your dishwasher rack and run them thru a cycle... pull them out before dry if you want..
7/30/2015 6:24:15 AM • Frigidaire 30"... • Answered on Jul 30, 2015
2answers
How do I season the griddle that came with my new
This is taken verbatim from page 11 of my Frigidaire Gallery range:
"Seasoning, using and caring for the griddle Before first use: -Wash griddle in hot soapy water. Rinse and dry completely. -Apply a thin coat of vegetable oil to the entire surface (front and back of griddle). -Preheat your oven to 350*F. Place the griddle on the upper rack in your oven. -Bake griddle for 1 hour at 350*F, then turn oven OFF and let cool before removing. -The surface may have a tacky feel to it from the seasoning process. If desired, wash the griddle in hot soapy water, rinse well, and dry completely.
Using the griddle: Remove the center burner grate and carefully replace with the griddle (some models). Preheat the griddle for 5 minutes on medium to medium low setting. Slow preheat ensures even heat distribution during the cooking process. DO NOT preheat the griddle on HI setting. Preheating on HI may warp the griddle and prevent even heat distribution.
After each use: -To prevent rusting, store in a dry place and keep uncovered. -After each use, clean with a stiff brush and hot water only. -Do not clean griddle in the dishwasher. -Dry immediately and apply a light coating of vegetable oil to griddle before storing.
7/29/2015 10:16:20 AM • Frigidaire 30"... • Answered on Jul 29, 2015
0answers
SELF CLEAN DOES NOT TURN ON.wHEN I PUSHTHE SELF CLEAN BUTTON ON,IT TURNS ITSELF OFF IN A COUPLE OF SECONDS
The door has to be latched. Bad door latch assembly maybe? Will it bake ok? Getting any codes? E-5 is bad door latch I believe. If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
12/26/2013 4:39:06 PM • Frigidaire 30"... • Answered on Dec 26, 2013
Badly stained gray burner grates for stove
Common problem, very frustrating...Use the self clean feature of your oven if available or you can place all of the grates and pieces into a black trash bag, spray them with oven cleaner and let the closed bag sit in the sun for a while, rinse and spot clean. You can get the tough stuff by "gently" using a steel wool pad - be careful, you could scratch the surface.
12/7/2013 7:01:37 PM • Frigidaire 30"... • Answered on Dec 07, 2013
Can gas range grates and burners be painted
Lowes has it
12/21/2012 3:57:41 AM • Frigidaire 30"... • Answered on Dec 21, 2012
Moved into place with frigidaire ceramic top, slide in. I accidentally lean on the control panel and have set the door lock. How do I unset it?
Hello mccuefamily - Is the door lock indicator light glowing? Try resetting the unit by either unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and turn the range back on. This will clear most false error codes. If error code still displays on panel, I would suggest contacting a professional to move forward accurately. The unit could possibly have a faulty light switch, door latch or EOC.
11/30/2012 7:05:42 PM • Frigidaire 30"... • Answered on Nov 30, 2012
I have a GE Gas Stove & we bought a steel and
Welcome to fixya
Hello
I have a solution for this
Press Ok, Accept or replay so we may get started
Your pre-solution is coming up shortly
PLEASE REPLY OR LEAVE COMMENT TO CONFIRM YOU RECEIVED THIS EMAIL
My name is Bruce
9/8/2012 4:25:56 PM • Frigidaire 30"... • Answered on Sep 08, 2012
0answers
0answers
I cleaned black gas stove
No paint will withstand the heat at that point; those are protected with porcelain when new and they unfortunately will always degrade with time. Porcelain is applied with very high heat but doesn't retain its gloss in service. You might try one of them, on one small area, to see if a 'rust remover' such as Lime Away will somewhat defog them but they will never appear as new once they have been exposed to use.
5/11/2011 1:41:40 PM • Frigidaire 30"... • Answered on May 11, 2011
I have a Frigidaire 30"
Hi
To remove the main top:
1. Lift the front of the main top and disengage the lift and lock rods.
2. Lift the top up and forward.
3. Slide a putty knife between the main top and the control panel to disengage the hold down clips, one on each end.
Hope this helps... Please post back with complete model# if you need more information.
Daniel
1/1/2011 6:39:36 PM • Frigidaire 30"... • Answered on Jan 01, 2011
[email protected] display shows dr and
hello
what is the model number of your machine ? Thanks I await your reply
Rick
1/1/2011 5:56:52 PM • Frigidaire 30"... • Answered on Jan 01, 2011
When cleaning the stove i touched my accident the
F90 Maximum oven door unlock time exceeded.
F91 Maximum oven door unlock attempts exceeded.
F92 Maximum oven door open time exceeded.
F93 Maximum oven door lock time exceeded.
F94 Maximum oven door lock attempts exceeded.
1. (F90, 91, 92, 93 & 94) Check the wiring between EOC & Lock Motor Micro Switch.
2. (F90, 91, 92, 93 & 94) Replace the Motor Door Latch assembly if necessary.
3. (F90, 91, 92, 93 & 94) Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam.
4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
5. (F90, 91, 92, 93 & 94) Lock Motor continuously runs - if Micro Switch is open, replace Lock Motor Assembly.
6. (F92, 93 & 94) Check oven door Light Switch - if open, replace Switch.
7. If all situations above do not solve problem, replace EOC.
F90 is a door lock code, Try this...
unplug the range.
wait 1 minute.
turn the range back on,
then while holding in on the oven door.
start another self clean.
wait 2 minutes.
then cancel the self clean.
do not release the door until the door lock light goes out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
10/1/2010 3:37:29 AM • Frigidaire 30"... • Answered on Oct 01, 2010
If i push the clean
The oven goes on full balst and heats up to like 800 degrees to try to incinerate averthing that spilled or run over into the oven....the problem is that it also incinerates everything around your oven including the controls and wiring...do it at your own risk... it is on there because it sells ovens...
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
9/7/2010 11:14:46 PM • Frigidaire 30"... • Answered on Sep 07, 2010
Door locked and can't release.
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
The other option you have is to call the customer service number of the manufacturer... they often have codes that they do not publish...
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
8/23/2010 12:57:16 AM • Frigidaire 30"... • Answered on Aug 23, 2010
Does my griddle pan on my Frigidaire 5 burner
I just got a new range and the instructions to season the griddle are in the instruction book. Wash an d dry the griddle. coat all surfaces ( top and bottom ) with a thin coat of cookin oil. place in oven at 350F for one hour. turn off afer an hour and let cool in the oven.
7/12/2010 6:58:20 PM • Frigidaire 30"... • Answered on Jul 12, 2010
Frigidaire 30" Self-Cleaning Slide-In Gas Range - White Logo
81 questions posted
Top Frigidaire Kitchen Ranges Experts
Paul Carew
ZJ Limited
ZJ Limited
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
View Most Popular
  • Frigidaire Kitchen Ranges
Most Popular Question
gas range grates burners painted
  • Kitchen Ranges
