20 Most Recent
Ideazon Zboard Keyboard Questions & Answers
Zboard
I have had this problem for a while. there about about 20 or so screws on the bottom side of your board. take out your keyset, then unscrew all of those. be careful removing it because of the plastic inside, and all the hardwired buttons on the top will fall out and one of mine broke. Now when you get it open, rip out the rubber keys, they'll just fall off. go wash them. I guarantee they're disgusting. now gently blow out between the plastic sheets, and replace them. make sure they're lined up right. you'll be able to figure out how to line it up. once you finished cleaning it all, you might also want to take a rag and wipe down all the plastic of the casing. put it all back together, and it'll work.
Like I said, I've had this problem multiple times and this always fixes it.
Zboard has issues when I install software
The original drivers are not updated therefore the keyboard acts erratically.
When you just connect the keyboard normally it has the proper driver installed automatically by the Operating systems Dll( dynamic link library ) files You could go to the manufacturer site to see if there is an updated version of the driver or just purchase another keyboard with better compatibility.
Same for me
My Shift, Z and P just stopped working, trying to type 'zboard' or' ideazon' into google was tricky, I had to copy a z from somewhere else, I went here
http://www.steelseries.com/download and down load the newest software for the board and there back ZPPZPZPZPZPZPZPZPZ...yipee!!
Had problems with the software
I think the software which you are using is itself corrupt or somehow not supported due to specific software. Changing or rebuying the software may help. Thank you.
Baby spilled coke in i now only par of he keys
Drain all of the liquid from the keyboard by shaking. If the fluid in the keyboard was not plain water, rinse the keyboard out using plain water, preferably distilled water. Then, rinse out the keyboard using distilled alcohol. This will force the water out of the keyboard and allow it to dry better. Wait until the keyboard is thoroughly dry--this may take two or three days. The keyboard should then be usable, but don't try to plug it in unless you are sure it is thoroughly dry.
Como cancelar el winter driver
EnglishIt is a car, and cars are complexbut no car was told , maker, model , and year.we can not guess cars. post the VIN? and all that is knownname a problem what can't your car do right?name symptoms or evidence that is confusing to you.then answers can happen.onlygood luck , finding itand Mucho Gusto.my guess now is this is posted to computer forumand not to CARS !must be some odd traction controls thing'but 10,000 models of cars,
I need a product key
Have you actually purchased Visio, or are you just trying to get it for free?
As a software guy, I would have to advise against piracy. :)
There are several ways to get Visio for cheap. If you are a student, there are discounted versions available online and in stores. Also, you can check with your school for even cheaper options sometimes. Try the university bookstore if available. Or a Computer Science department maybe.
If you are working, and your company uses MS Office applications, find out if they have the "Microsoft at Home" program. You can get MS Office applications for really cheap that way. I can get Visio through my company's "Microsoft at Home" program for a few dollars.
My Employer Says They Are Going To Cut My Wages. Can They?
If you are in the middle of a contract, then cutting your wages is almost certainly a violation of your employment law rights. While I am by no means an expert on this matter, I did have a similar issue years ago - mid-contract wage cuts - and I hired an
employment attorney to fight the case on my behalf. It turned out that my employer was basically looking to scare people into taking the wage cut.
They got into some pretty serious legal trouble for their transgression, and nothing happened to me in terms of wage cuts after that. If you are between contracts, your employer can re-negotiate your salary, but as far as I am aware, if you are in an agreed-upon contract, they cannot just decide to reduce your salary. If you want to settle matters, contest this action with support from a legal professional.
