20 Most Recent GE Profile Spacemaker II 1.0 Cu. Ft. Mid-Size Microwave - Bisque-on-Bisque Questions & Answers
Most major manufacturers supply manuals online so if you were to log on to the manufacturer's web site, you may be pleasantly surprised as usually, if available, one is able to download, by model number, Customer Instruction Manuals, Dealer Network for spare part supplies as required.
The information is normally free of charge.
I hope this helps.
GE Profile... | Answered on Mar 17, 2011
It sounds like possibly your transformer has failed or it could be an internal ground failure from your transformer to the magnetron.
It can most likely be repaired but needs done by a trained technician. If it were to be diagnosed with what I state could be wrong you would be ahead to get a new unit as opposed to paying for parts and labor to repair.
If you smell something burning in it do not run it any more, you could start a fire. I would also kill the power to it via unplugging, breaker, etc.
The front control panel should come off after removing a few screws then look for a large capacitor behind it
.DO NOT TOUCH THE TERMINALS! This capacitor is a common cause of the symptoms you describe and costs almost nothing.Changing it may be the fix.
GE SpaceMaker... | Answered on Mar 11, 2019
first suspect is the inverter board (power) and magnatron a distant second----in either case the part involved unless an expensive unit is pricey.
GE SpaceMaker... | Answered on Jun 02, 2018
SOUNDS LIKE FLAME SENSOR SWITCH OPENED OR CLOSED AND THE UNIT THINKS IT OVERHEATED AND TURNED THE FAN ON TO COOL IT MUST FIND SHORTED FAN SWITCH
GE SpaceMaker... | Answered on Apr 19, 2018
I had this mute problem and found that unpluging it for 1 to 2 min. and the problem cleared.
GE SpaceMaker... | Answered on May 03, 2017
May be an issue with the magnetron tube.
GE SpaceMaker... | Answered on Mar 29, 2017
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screw(s) you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
In some cases, you then have to gently rotate the handle to unlock it.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
GE SpaceMaker... | Answered on Sep 28, 2016
It normally is not possible to check the diode of a Microwave oven without some special high voltage testing equipment. If you suspect it, replacing it would be much cheaper. A typical DVM will not do the job. But diodes usually are not the first part to fail; check the transformer.
GE SpaceMaker... | Answered on Sep 11, 2016
Since I don't know the model, here's a general answer. On a GE over the range oven, the top air deflector assembly is usually removable. After its off, you will have access to the fasteners at the top of the control panel. Remove it, and you should be able to see the door switch/latch assembly on the left.
Do all of this with the oven unplugged. Do not go near the high voltage capacitor as it can retain a charge of 4000 volts indefinitely. Stay away from the rest of the h v wiring as well.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
GE SpaceMaker... | Answered on Jun 28, 2016
ever heard of a mirror to see in tight places .
GE SpaceMaker... | Answered on Apr 18, 2016
should be available any place that sells the units
There is a fuse inside the unit you may check and see if that is it. If not then it will be the front panel. Hope this helps
GE SpaceMaker... | Answered on Feb 26, 2016
12x12x12= 1728 cubic inches= 1 cubic foot
15x30x15.75=7087.5 cubic inches.
4.1 is the answer.
GE SpaceMaker... | Answered on Feb 13, 2016
GE Profile Spacemaker II 1.0 Cu. Ft. Mid-Size Microwave - Bisque-on-Bisque Logo
5 questions posted
Top GE Microwave Ovens Experts
Poppa Maddo
Poppa Maddo
William Miller
William Miller
Jimmy
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
View Most Popular
SpaceMaker GE
  • SpaceMaker GE
Most Popular Question
ge spacemaker ii microwave serial
  • Microwave Ovens
