20 Most Recent Frigidaire 30" Built-In Single Electric Convection Wall Oven - Black Questions & Answers
Nothing Works, or the Oven / Range / Stovetop Works Only At Certain Times:
1.Home breaker flipped or the fuse blown?Possibly an electrical surge has flipped the breaker. Check your breaker or fuse box and replace or reset as necessary.
2.Power cord plugged in?Grab the plug and wiggle to determine a good connection.
3.Power cord damage?Damaged rubber with wires showing through or the wire is being pinched can cause issues. Electrical tape is acceptable for covering damaged wires.
4.Aclicking sound could be something wrong with a relay. Check for any loose connections around the main control board on your oven. The click you hear is a relay losing power and switching back on. If the clock resets then something is causing power interruptions to the board.
If your oven has internal fuses, a wiring or component problem could have caused a fuse to blow. A blown fuse is an indication that a component has shorted or failed, and the problem will need to be corrected. Most ovens that use fuses will have an indication of the circuits that are affected by a particular fuse. If an oven fuse has blown, then you should inspect the oven element and the associated wiring to determine the cause before replacing the fuse.
THINGS TO CHECK:
the broil element
is the heating element that is found at the top of the oven and produces a very high heat for broiling. If the broil element isn't working, you should first do a visual inspection for signs that the element has blistered or separated. If the element appears normal then you can check for continuity with a multi-meter. Remove power from the appliance before performing this test. Remove the back panel and locate the terminals for the broil element and inspect the terminals and wires for signs of overheating or damage.
If there is no continuity then the element will need to be replaced. If the wires are damaged then they will need to be repaired. If the element is ok then you will need to check the broil circuit to determine the cause. This involves live voltage checks and should only be performed by qualified persons. Components to check include fuses, if the range is equipped, and oven control thermostat or electronic control.
The bake element
is the heating element that is found at the bottom of the oven. Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake element performing 90% of the heating. If the bake element isn't working, the oven may not heat. To help determine if the bake element is defective you should first do a visual check. If the element is blistered or separated then it should be replaced. If the element appears to look normal, then turn the oven on to a bake function for a minute and then turn it off.
Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. If the element is burned or no longer has continuity, it will need to be replaced.
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
Frigidaire 30"... | Answered on Apr 17, 2015
You would need a new control display - you cannot change out the lighting segments.
Frigidaire 30"... | Answered on Aug 21, 2012
Sounds like the control board is not communicating correctly with the rest of the unit, consult a professional.
Frigidaire 30"... | Answered on Aug 14, 2012
Never ever use the Clean Mode. It breaks things, in your case over heating the fan. The clean cycle goes up to 650'F
Frigidaire Ovens | Answered on Nov 14, 2019
First take out the broiler pan, insert and any aluminum foil. Remove any other tools or pans from the oven. Next clean any large deposits in the oven cavity with hot, soapy water and a cloth. Clean the oven frame, the area outside of the door gasket and the very front center of the oven bottom with soap and water. Once you are ready to start the Self-Clean cycle, press the Self-Clean touch pad. To change the length of the Self-Clean cycle, press the pad again, as needed. Press Start. If you want to have the Self-Clean delayed, press the Delay Start touch pad after the Door Loc message appears. Type in the start time with the keypad.
To stop this cycle, press Cancel. If the oven is hot, the door will remain locked.
Frigidaire has most of their manuals available on their support site: http://b2b.frigidaire.com/support/manuals.asp . The current link to the English version of the Owner's manual is http://manuals.frigidaire.com/PDFnotFoundCheck.asp?path=ftp://ftp.electrolux-na.com/ProdInfo_PDF/&folder=Lassomption&PDFtype=Owner&PDFfile=318205312en.pdf&model=FGEW3045KFB . See pages 24-25 for this information.
I hope this helps.
Frigidaire Ovens | Answered on Nov 05, 2019
Possibly, the replacement EOC is defective.
Frigidaire Ovens | Answered on Oct 06, 2019
Check with a local repairman. He should be able to locate if it is still available.
Frigidaire Ovens | Answered on May 19, 2019
I know this isn't directly answering your question, however, what "burned up" about it?
You can get just about every part that fits that oven from Sears PartsDirect. Control boards, bake elements, convection fans, switches, replacement glass... just about everything.
Unless the oven literally burned through the side/top walls, you're most likely going to save money by fixing whatever's wrong with it.
Even the clock/timer control board is only $164 for the OEM part.
Frigidaire Ovens | Answered on Apr 18, 2019
Frigidaire 30" Built-In Single Electric Convection Wall Oven - Black Logo
4 questions posted
Top Frigidaire Ovens Experts
Marvin
Marvin
Bruce Denton
Alan Chouinard
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
View Most Popular
Frigidaire Ovens
  • Frigidaire Ovens
Most Popular Question
clock frigidaire built in oven part
  • Ovens
