20 Most Recent
Frigidaire 26.0 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Black Questions & Answers
The ice door will not open like it used to. Now I
Good Morning Misty, thank you for your post!
It is a good idea to clean the
ice dispenser and ice container if the ice dispenser sticks or before
contacting an experiencing technician to assist further.
1.
First, stop ice
production by lifting the wire signal arm to the "up" or OFF position
(side-mounted) or the ice maker's On/Off power switch turned Off-set to the "O"
position (rear-mounted).
2.
Remove ice
container by lifting up and out. Empty and carefully clean the container with
mild detergent. Rinse with clear water. Do not use harsh or abrasive cleaners.
Allow ice container to dry completely before replacing in the freezer.
3.
Remove ice chips
and clean the shelf and chute that supports the ice container.
4.
Replace the ice container. Lower the wire signal
arm on the ice maker to the "down" or ON position (side-mounted) or
the ice maker's On/Off power switch is turned On-set to the "I" position.
(rear-mounted) and the ice maker will resume production.
I hope these troubleshooting tips help you in some small
way.
Smells like frost
Baking soda, follow the directions on the box for use in freezer or fridge.
Fresh Food temperature display is
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
The icemaker is 110v
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
First I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
If you still have trouble GO HERE:
hhttp://www.applianceaid.com/procedures.htm
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
