20 Most Recent
Digipower Travel Charger for Select Sony and Digital Camera Batteries Questions & Answers
Im trying to charge my
I recently purchased the same exact charger for the same exact battery....I had to slide the battery in backwards to align the positive and negative and then it should charge properly. If you slide it in the other way which seems to be the front side of the battery the light will automatically appear green same as if no battery was in the charger. This is because its not aligned to the positive and negative from the battery to the charger. Best Wishes!
Battery not charging
Hi
Did you try to check if the battery is working? first of all try to replace the battery with the same rating as the manufacturer suggests you.
If you have already tried replacing the batteries then maybe you are not using the charges which came with the camera. If not then use the same rating adapter to charge your camera as the amperes and voltage does matters.
7/15/2011 7:37:39 PM •
Digipower...
Answered
on Jul 15, 2011
This is a stupid question
Well, I can't find the instructions online anywhere, but the charger seems easy enough to use. The battery contacts need to come in contact with the contacts in the charger. This particular charger automatically figures out the + and - so if you insert it incorrectly, it doesn't hurt anything.
11/8/2010 9:00:40 PM •
Digipower...
Answered
on Nov 08, 2010
My open view is not showing any pictures but showing information about programs playing what might be the problem
Some steps you can try:
Check Picture Location:
Ensure that the pictures you want to view are in the same folder location. Sometimes, if the images are scattered across different folders, they may not appear correctly in the photo viewer.
Repair or Reset the Photo App (for Windows 11):
Go to Settings > Apps > Photo.
Click on Advanced options.
Choose either Repair or Reset to address any potential issues with the Photo app.
Enable Thumbnail Previews (for Windows 10):
Open File Explorer Options:
Type "file explorer options" in the Windows search bar and select the first result.
Switch to the View tab.
Ensure that the option "Always show icons, never thumbnails" is unchecked.
Click Apply and then OK to save the changes.
That is about all I can offer. If you repost, include brand and model.
4/19/2024 8:18:20 PM •
Cameras
Answered
3 days ago
