20 Most Recent
XFX NVIDIA GeForce 8500 GT 256MB DDR2 PCI Express Graphics Card Questions & Answers
I bought an Ultra LSP 650w power supply (upgrade)
if thats wat the specs say then thats most probably the max youve just bought one thats to powerfull, and y did you need so much power the most powerfull graphics card in the world needs a 750watt power surpply, your computer is probably not designed to have major upgrades, and by looking at the specs i can see that your computer well putting it simply is **** for upgrading the specs are **** (no offense intended) i suggest upgrading to a whole new computer if you want that sought of power and graphics
How do I reinstall my graphics card since I installed win 7 pro
Hi
I presume that the installation of Win7Pro was an upgrade from a previous OS and that the graphics card was obtained before Win7 was available, as this would explain the lack of drivers for Win7Pro on the disk. If you go here:
AMD Catalyst Display Driver
you will be taken straight to a page where you can download the drivers for installation.
Hope this is helpful, if so would you please register that with Fixya
Cheers
No sound xfx one
You must set up port in drivers and in windows
analog for speakers and headset, or
digital for hdmi to tv speakers
How to repair msi vr320x with no display?
Does both the port not giving you display did you check the memories is it all fine set also the power you have connected it properly try it in different machine check the PCIE Volts which slot is suitable for your Card on your motherboard.
try the display cables and cooling all ok than i am afraid you need to send it to a workshop or you can fix if you know chip level work so there is An IC if fails or leak it does not give any out put so you need to change that.
Nvidia 9600 gt
Maybe you have set the view to large icons in properties.
