20 Most Recent
Frigidaire 24" Built-in Single Electric Wall Oven - Black (Special Order) Questions & Answers
What do the error codes for frigidaire elite electri clean oven
Hello friend, thank you for your post!
I see you have a Frigidaire wall oven and you are searching for error codes. Do you have a specific error code that your oven is giving you? Also, could I get your model number please? With that additional information I would be able to provide you more assistance. I look forward to hearing from you. -Matt
Frigidaire FEB24S5AB 24 inch F10
Hello friend, thanks for the post!
I understand your Frigidaire wall oven is flashing a F10 code and not heating up. Based off of that information an F10 code stands for a runaway temperature, which could be an issue with a sensor probe or oven control. It could possibly be a miscommunication with the board and that could be cleared out by resetting your appliance. To reset your appliance disconnect power to it by unplugging the oven or flipping the household circuit breaker for ten minutes. If that step does not resolve your issue and you continue to receive the F10 code I would recommend contacting a technician to come and repair your appliance. I hope this information is helpful. -Matt
Where is thermostat located in Frigidaire wall oven?
Hello Brad,The thermostat is a small diameter appx. 6 inch long round probe it looks like this
To test it for proper functionality ya need to use a multi meter capiable of reading ohms of resistiance...unplug the sensor from the wiring and place the meter leads onto the 2 wire ends of the sensor and at room temperature once the oven has been off check for between 1060-1100 ohms at the sensor if its good,if the ohms value is much higher or lower that 1060-1100 at room temp. the sensor is defective.GENE
Inherited uncle's house that has
Sorry to read about your problem, I hope this helps you out.
without the model number, you will need to have a service company, come and look at the unit,
tell them on the phone, that you dont have a number, and to send their most experienced person. then they can match a coil up....
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
What does the F 5 error message displayed on
Hello there:
Here is what the code means and what needs to be dne to resolve this problem
F5
Internal
watchdog
circuit has detected a failure
Defective
EOC
(Electronic Oven Control)
Should be something like this
F3 message displayed
HI, you oven temp sensor if malfunctioning. the circuit is open. its basically dead. Check sensor harness and harness connection between oven sensor and oven control.
Replace oven temperature sensor (RTD) if wiring is ok.
Error F3 on display ovens beeps
the temperature probr is located inside your oven in one of the upper corners. it should be a round stick looking piece. some are removed from the front others are removed from the back.
