I just replaced and old
If you are using a 20Lb LP Gas Tank, rather than hard piped to the grill or you're using Natural Ga, here in may lie the problem. If it is Natural Gas, was the grill converted or ordered for Natural Gas? If not, that's why it' not heating well.
If you're using a 20Lb grill tank, do the following:
1. Turn the Propane Tank Valve OFF and disconnect the hose from the tank.
2.Wait 5 minutes and reconnect the hose to the tank. Open the tank valve VERY, VERY SLOWLY (Slow motion, slow).
3. Once the valve is fully open, light the burner farthest from the tank first and turn the control knob to HIGH. Does the flame height look correct for being on HIGH? If so, light the remaining burners the same way, Do all the flame hieghts look correct? If co, close the lid and allow the grill to preheat for at least 20 minutes. Did the grill thermometer go higher that 200 degrees F. If so, you solved the problem. Always remember to turn the tank valve ON very, very slowly.
If that did not solve the problem, the thermometer may be incorrect/faulty. I had this happen myself, with a new grill. To test it, invest $5.00 in an Oven Thermometer, like you use in a regular oven, It sits on the oven shelf. But, in this case it will sit on the center of the grill's cooking grates.
Light the grill and preheat it for 20 minutes. Loo k at the grill thermometer and then lift the hood and look at the oven thermometer. The oven thermometer may be as much as 200 degrees higher. That's because it's actually reading the temperature at cooking level, not up in the air, where the grill thermometer is.
I never replaced my grill thermometer. I continue to use the inexpensive oven thermometer, because it's giving me the actual temperature, at the level I'm grilling at. And I, do a lot of grilling.
Hope this helped you troubleshoot and solve the problem. Pleas let me know and Happy Grilling.
