20 Most Recent
JBL LSR-4312SP Active Subwoofer Questions & Answers
My JBL ES250P wont turn on the light flicks from green to red.
that humming sound 60Hz is a hint of short. inside
it needs to be repaired in a shop.
a shop can fix it.
you have no tools or parts or tech skills to fix it inside.
right? so get it to a shop
or buy the service manual and have at it.
find the short. (top cause bad CAPS)
How to remove child lock from BELTEK TV?
general steps:
Get the TV remote control and push the "Menu" button and select "Options".
Select "Child Lock" from the "Options" list. On some televisions, the "Child Lock" is named "V-chip".
Choose the "Remove Child Lock" selection. Highlight this and then hit the "Enter" button.
Enter the four-digit code that you used when you activated the child lock feature. If you cannot remember it, your only option to deactivate the child lock is to reset the TV. The instructions for resetting a TV is written on the user's manual of the TV.
Exit the TV menu once you have entered the four-digit code. To do this, press the "Exit" or "Menu" button on the TV's remote control.
If you don't have a remote, you might try leaving the TV unplugged overnight. Some TVs will 'forget' their settings if left without power for a long period. You could also potentially buy a cheaper universal remote, and use that to turn off the child lock.
