20 Most Recent Quantum Audio Qa2000d 2000 Watts Mono-block Car Amplifier Questions & Answers
Sound quit working
Could be as simple as having hit the "Mute" button. Some tv's turn off sound when close captioning is selected.
3/6/2015 7:06:40 PM • Televison &... • Answered on Mar 06, 2015
0answers
I bought a quantum fx
Hi.
Its really easy just plug the color connectors(red,white,yellow) where you plug the connectors of your DVD.
9/15/2012 10:25:53 AM • Quantum... • Answered on Sep 15, 2012
How to restore apps the Harwa smart tv doesn't wanna open for apps
If your Harwa smart TV is having trouble opening apps, you can try a few troubleshooting steps to restore the functionality: 1. **Restart the TV**: Sometimes, simply restarting the TV can resolve temporary glitches. Turn off the TV, unplug it from the power source, wait for a few minutes, and then plug it back in and turn it on. 2. **Update the TV's Software**: Make sure your TV's software is up to date. Check for any available firmware updates in the settings menu of your TV. Updating the software can often fix bugs and improve performance. 3. **Clear App Cache/Data**: If specific apps are not working, try clearing their cache and data. Go to the settings menu of your TV, find the Apps section, locate the problematic app, and then clear its cache and data. This will reset the app to its default state. 4. **Check Internet Connection**: Ensure that your TV is connected to the internet and that the connection is stable. If your internet connection is weak or unstable, apps may have trouble loading or functioning properly. Try restarting your router or connecting to a different Wi-Fi network. 5. **Reset Smart Hub or App Store**: If the issue persists, you can try resetting the Smart Hub or the app store on your TV. This will restore the default settings and may resolve any issues with app functionality. Refer to your TV's user manual for instructions on how to reset the Smart Hub or app store. 6. **Factory Reset**: If none of the above steps work, you can perform a factory reset on your TV. This will restore the TV to its original factory settings, removing any customization and potentially resolving software-related issues. Keep in mind that a factory reset will erase all data and settings on your TV, so make sure to back up any important information before proceeding. 7. **Contact Customer Support**: If the problem persists after trying the above steps, you may need to contact Harwa customer support for further assistance. They can provide additional troubleshooting steps or arrange for repairs if necessary. By following these steps, you should be able to restore the functionality of apps on your Harwa smart TV.
4/23/2024 9:56:30 AM • Televison &... • Answered 4 hours ago
My television will suddenly turn off every 4 minutes or so and when I turn it back on it will do it again. I need help to stop this please?
It sounds like there might be an issue with your television or its power source. Here are a few steps you can take to troubleshoot the problem:
  1. Check the Power Source: Make sure the power cable is securely plugged into both the television and the power outlet. Try plugging the TV into a different outlet to see if the issue persists.
  2. Check for Overheating: TVs can sometimes overheat, especially if they're placed in an enclosed space or if vents are blocked. Ensure that there's proper ventilation around the television.
  3. Check the Remote Control: Sometimes, the issue might be with the remote control. Check if any buttons are stuck or if the remote's batteries need to be replaced.
  4. Reset the TV: Unplug the television from the power outlet for about 5 minutes, then plug it back in and turn it on. This can sometimes reset the TV's internal system and fix minor issues.
  5. Check for Timer Settings: Some televisions have timer settings that automatically turn off the TV after a certain period of time. Check your TV's settings menu to ensure that no such timer is enabled.
  6. Update Software: If your TV has a software update option, make sure it's up to date. Sometimes, software glitches can cause unexpected behavior.
  7. Inspect for Physical Damage: Look for any physical damage on the television, such as frayed cables, cracked screens, or damaged components.
  8. Contact Manufacturer Support: If none of the above steps resolve the issue, contact the manufacturer's customer support for further assistance. They may be able to provide additional troubleshooting steps or recommend repair options if the TV is under warranty.
4/23/2024 8:19:30 AM • Televison &... • Answered 5 hours ago
How to remove child lock from BELTEK TV?
general steps: Get the TV remote control and push the "Menu" button and select "Options". Select "Child Lock" from the "Options" list. On some televisions, the "Child Lock" is named "V-chip". Choose the "Remove Child Lock" selection. Highlight this and then hit the "Enter" button. Enter the four-digit code that you used when you activated the child lock feature. If you cannot remember it, your only option to deactivate the child lock is to reset the TV. The instructions for resetting a TV is written on the user's manual of the TV. Exit the TV menu once you have entered the four-digit code. To do this, press the "Exit" or "Menu" button on the TV's remote control. If you don't have a remote, you might try leaving the TV unplugged overnight. Some TVs will 'forget' their settings if left without power for a long period. You could also potentially buy a cheaper universal remote, and use that to turn off the child lock.
4/22/2024 8:10:04 PM • Televison &... • Answered 17 hours ago
How to pairing Ruwido Amadeus R 9710 to tv?
To pair your Ruwido Amadeus R 9710 remote to your TV, you can follow these steps: Insert Batteries: Your remote is powered by two 1.5 V AAA batteries1. Make sure to insert the batteries correctly. Switch on your TV: Ensure your TV is turned on. Press the TV key: Press the TV key on your remote control for approximately 4 seconds until the LED flashes twice. Enter the Code: After seeing the 2 flashes and within 5 seconds, enter the 3-digit numerical code from the list provided with your remote2. After entering the code, the LED will flash twice indicating that the code has been accepted. Test the Remote: Point the remote control towards your TV and press the key. If your TV does not respond by going into Stand-By mode then repeat steps 3 to 5 and enter the next code in the list. Bed.-Anl. H2 Version1 (ruwido.com)
4/21/2024 7:58:23 PM • Televison &... • Answered Yesterday
My ecco TV is on but the screen is black when flashing light I can see the picture tv model LH 32.
That sounds like it has a backlight fault. A good TV engineer can possibly repair that for you.
4/21/2024 2:31:53 PM • Televison &... • Answered Yesterday
Tek L26D10. How to open the unlock the TV unlock code for Tek model L26D10?
Ask your parents. There is no easy way to defeat the parental lock.. https://www.google.com/search?q=Tek+model+L26D10+TV+unlock+code ..
4/21/2024 5:35:32 AM • Televison &... • Answered 2 days ago
6answers
Vistron remote codes for sky
TV maker is Palladium codes are 0560, 398, 391, 446
4/20/2024 8:49:55 PM • Televison &... • Answered 2 days ago
JVC KW-AV50 DVD receiver. None of the volume Up or Down buttons work JVC KW-AV50.
Try cleaning behind them with electronics switch cleaner spray, but it may be the whole module is faulty. https://www.google.com/search?q=jvc+kw+av50+volume+button+not+working ..
4/20/2024 6:31:28 PM • Televison &... • Answered 2 days ago
2012 troybiilt super pony transmission axel is trying to slide out how to fix it
The axles may have substantial amount of in/out play, 1/4 inch or more. Does the axle in question actually drive the wheel or does it freewheel?It's a typical differential so if you get both wheels off the ground and spin one wheel, the other wheel should rotate in the opposite direction.The axles are retained by the differential assembly (inside transmission) so if the axle is truly falling out, to fix it will require transmission be removed and opened. Probably not an economical repair unless you can DIY or replace with good used unit.
4/19/2024 9:41:16 PM • Televison &... • Answered 3 days ago
What is the sky remote code for a cello model c20234f-led ?
Turn on your Sky Box and TV. On your Sky Remote, press the TV button. Simultaneously press the Select and Red buttons until the red LED on your remote blinks twice. Enter one of the following 3-digit remote codes for Sky TV: 2274 2169 1874 1798 1872 1873 The light on the remote should flash twice. If it blinks only once, repeat the steps with the next code. Press the Standby button on your remote. If your television turns off, press the Select button to save the setting. Turn on the TV and press TV Guide; if the TV Guide list displays on the screen, the programming was successful. Remember that there are multiple versions of Sky Remote Controls available, so ensure you have the most recent version. If you encounter any issues with the 3-digit codes, you can also try using a 4-digit code. Here's how: Repeat steps 1 to 3. Enter the 4-digit Sky remote code for your TV brand. Press the Standby button. If your TV turns off, press Select to save your settings. Check if the TV Guide displays successfully on the screen. Sky TV Remote Control Codes
4/19/2024 8:32:21 PM • Televison &... • Answered 3 days ago
2answers
Harwa 32 Inch Led Television. How do I update my software on my Harwa 32 inch as my apps show it needs an update.
To update the software on your Harwa 32-inch TV, follow these steps: Check Other Solutions First: Before proceeding with a firmware update, ensure that you've tried other troubleshooting solutions. Sometimes issues can be resolved without updating the firmware. Gather Necessary Items: You'll need the following: A computer with an available USB port. A high-speed internet connection. A USB flash drive. Find Your TV Model Information: On your TV, navigate to the Help menu and select System Info. Write down your TV's model, revision, and firmware information. Download the Firmware Update: On your computer, visit the Insignia Products website at www.insigniaproducts.com. Click on Support & Service. Enter either NS-19D220NA16 or NS-19D220MX16 in the search box under Manual, Firmware, Drivers & Product Information. Follow the Firmware Installation Guide: Download the firmware update from the Insignia website. Copy the firmware file to a USB flash drive. Install the Update on Your TV: Plug the USB flash drive into the USB port on the side of your TV. Press the MENU button on your remote. Navigate to HELP and press ENTER. Highlight Update Firmware and press ENTER. Confirm that you want to update the TV firmware by selecting OK. Your TV will display a status screen while installing the update. Do not turn off your TV during this process. Once the update is complete, unplug the USB flash drive and press ENTER. Your TV will turn off and then back on to finalize the update. Rescan for Channels (if needed): If your channel list has been deleted, you'll need to scan for channels again. Refer to your TV's manual for instructions on how to do this. Remember: If you encounter a message saying the firmware file is incorrect, ensure you've downloaded the correct file for your specific model. If the update fails or your TV screen remains blank with a blinking red then blue power LED, turn off your TV, turn it back on, and run the upgrade again.
4/19/2024 7:23:41 PM • Televison &... • Answered 3 days ago
Need a new remote control for iheater ih1500--how much does it cost and can you ship it to me? model IH1500 Serial IHA080939250
Sorry, we do not supply anything. I would aproach the supplier or manufacture for advice and spares availability.
4/19/2024 3:13:01 PM • Televison &... • Answered 3 days ago
Sorry, but we do not supply parts. This is a website for advice on repairing items. You could try contacting the store you bought it from or contacting iheater directly.
4/19/2024 3:12:50 PM • Televison &... • Answered 3 days ago
Where is the Google on the Matertech?
It appears that there could be miscommunication. As of my previous update in January 2022, Matertech doesn't seem to be a commonly known term or corporation. On the other hand, if you're talking about "Google," it's a well-known worldwide technological corporation that specializes in internet-related services and goods, such as search engines, cloud computing, online advertising technologies, software, and hardware. Google's official website or an internet search utilizing one of the search engines like Google itself are usually the easiest ways to get information about Google. If "Matertech" relates to a particular thing or idea, further information could be helpful in order to provide a more precise answer.
4/16/2024 4:37:21 PM • Televison &... • Answered on Apr 16, 2024
2answers
Changhong tv
Refer its user manual for details.
4/16/2024 3:46:48 PM • Televison &... • Answered on Apr 16, 2024
Quantum Audio Qa2000d 2000 Watts Mono-block Car Amplifier Logo
1 questions posted
Top Quantum Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you a Quantum Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Quantum Televison & Video
Most Popular Question
multi region unlock codes teac lcdv 1001
  • Televison & Video
