20 Most Recent Nikon N5005 35mm SLR Camera Questions & Answers
Se me callo al suelo no funciona
7/18/2016 6:02:07 PM • Nikon N5005 35mm... • Answered on Jul 18, 2016
What exposure rating do i put when its dark for a nikon n5005?
By the highest speed ( ASA ) Film you can fine, ASA 1000 if poosible
10/26/2014 3:35:19 PM • Nikon N5005 35mm... • Answered on Oct 26, 2014
Battery pieces
Not a minor repair. You have to remove two circuit boards and their attached wiring to replace, plus the camera covers
5/14/2014 12:52:34 AM • Nikon N5005 35mm... • Answered on May 14, 2014
2answers
How do you work the
Hi there fellow Nikon user. I see that you want to know you can make the self-timer work. I suggest you click on this link: http://www.cameramanuals.org/nikon_pdf/nikon_n5005-2.pdf then go to page 44-45
Enjoy!
3/30/2011 5:05:08 PM • Nikon N5005 35mm... • Answered on Mar 30, 2011
How do u take a picture?? everytime i hit the
Press the button down further. The shutter release button on these types of cameras has two modes, half way down causes the camera to autofocus, all the way down causes it to shoot. If the camera is in autofocus mode, it will not fire until it feels that is focused.
3/3/2011 7:41:24 PM • Nikon N5005 35mm... • Answered on Mar 03, 2011
Can you tell me the best choice in a telephoto for NiKon N5005 ca
try looking for a cheap 70-300mm AF-D i'm not sure it the AF-G version (no aperture ring, control via body) will work with your cam.
12/30/2009 1:19:34 AM • Nikon N5005 35mm... • Answered on Dec 30, 2009
Need a new back door for Nikon n5005
Nikon no longer sells that part. You can check eBay foe a used door, or maybe a parts camera. UScamera.com sells a repair kit to fix the latch on the door you have.
12/17/2009 12:42:42 AM • Nikon N5005 35mm... • Answered on Dec 17, 2009
N5005 will not advance film when loading.
As I stated in a second posting, I found that the previous owner had left leaky batteries in the camera. when I removed the bottom cover I found some corrosion on the bottom of the motor gear assembly.I' m thinking of trying to remove the motor assembly and see if it's free. What led me to the motor was the fact that when I tried to load film and it did not wind I set the camera down for about 5 to 10 minutes. when I came back and picked up the camera, I noticed that the motor drive battery area was very warm. This led me to remove the bottom of the camera. Seeing the rust on the gears makes me think some might be stuck. If that's the case, I'm going to try and see if I can free them and go from there.
12/9/2008 3:59:47 PM • Nikon N5005 35mm... • Answered on Dec 09, 2008
2answers
Camera won't take a picture
WHAT YOU ARE SEEING IS BASICALLY AN ERROR WARNING THAT THE SHUTTER SPEED IS NOT RIGHT FOR THE LIGHT CONDITION AND THE LIGHTNING BOLT USUALLY MEANS THE FLASH IS NEEDED. IF THIS IS A FILM CAMERA, IT IS PROBABLY WANTING YOU TO PUT IN THE CORRECT EXPOSURE SETTINGS FOR THE CONDITIONS. DOES THIS HAPPEN WITH ALL CONDITIONS? HAVE YOU TRIED OTHER SETTINGS ON THE CAMERA? LET ME KNOW IF YOU NEED MORE HELP.
ARCLIGHT1217
11/14/2008 4:43:53 AM • Nikon N5005 35mm... • Answered on Nov 14, 2008
Won't release shutter
Didn't solve the problem but, the camera is a friends and he is going to sell it as an as is auction on e-bay.Thnx anyway.
8/31/2008 5:36:33 PM • Nikon N5005 35mm... • Answered on Aug 31, 2008
2answers
Help!!!!
Remove the lens from camera.
Look inside pass the mirror, how is the shutter?
Should be flat with the film with no warp or opened shutters.
Or try this:
Lens out, set camera to M (manual mode).
Shutter set at 1 (One Second).
No flash.
800 ISO
Lnes drive pin (recessed) fully into the body, not S or C.
Fresh batteries.
Set self timer on.
Press shutter button.
Camera should blink and then shutter should be tripped.
This will also check to see if you have enough power for min. of one shot.
[email protected]
1/24/2008 5:21:21 PM • Nikon N5005 35mm... • Answered on Jan 24, 2008
Nikon N5005 - No Shutter Release
The lens aperure ring must be set to the highest number, ( IE, smallest aperture, f22,f32 ) for the camera to work in full auto. Also, with the ASA set to DX, the camera will not release without film.
12/23/2007 4:09:16 PM • Nikon N5005 35mm... • Answered on Dec 23, 2007
My Nikon FM has an issue where every-other time I advance the film the shutter mirror flips up and the shutter goes off. I can actually watch the mirror go up as I'm winding if I take the lens off
It sounds like your Nikon FM may be experiencing a mechanical issue with the shutter mechanism. Here are a few troubleshooting steps you can try:
  1. Inspect the Film Advance Mechanism: Check the film advance lever and mechanism to ensure they are functioning properly. Make sure there are no obstructions or debris interfering with the movement of the advance lever.
  2. Check the Shutter Release Button: Inspect the shutter release button to see if it's sticking or malfunctioning. Sometimes, a stuck or sticky shutter release button can cause the shutter to fire unintentionally.
  3. Examine the Mirror Mechanism: Carefully inspect the mirror mechanism to see if there are any visible signs of damage or misalignment. If the mirror is flipping up unexpectedly, there may be an issue with the mechanism that controls its movement.
  4. Clean and Lubricate: If the camera hasn't been serviced in a while, it's possible that dirt, dust, or dried lubricant may be causing the issue. Consider cleaning the internal components of the camera and applying a small amount of appropriate lubricant to the moving parts (be cautious and follow proper procedures when lubricating a camera).
  5. Seek Professional Repair: If the issue persists after attempting basic troubleshooting, it's advisable to have the camera inspected and repaired by a qualified camera technician. They can diagnose the problem more accurately and perform any necessary repairs or adjustments to restore the camera to proper working condition.
  6. Use a Different Lens: Sometimes, issues with the lens can affect the camera's operation. Try using a different lens to see if the problem persists. If the issue only occurs with a specific lens, there may be a problem with that particular lens.
It's essential to handle the camera with care during troubleshooting, especially when accessing internal components. If you're unsure about performing any repairs or adjustments yourself, it's best to seek professional assistance to avoid causing further damage to the camera.
3/16/2024 9:18:35 AM • Nikon... • Answered on Mar 16, 2024
Test question ~ please delete
11/17/2023 4:59:16 AM • Nikon... • Answered on Nov 17, 2023
My Nikon FE film advance lever is stuck. It does
Have you tried fresh batteries and setting the shutter speed dial to M90 or m250 whichever you have? If this does'nt work you can remove the camera bottom plate and gently pull a lever away from the advance cog. Some times things get out of sync in there. Sorry I can't be more specific but I did this many years ago. Good Luck.
4/8/2022 9:42:31 PM • Nikon... • Answered on Apr 08, 2022
How to replace nikon f3 shutter?
There are youtube videos on this type of repair to DSLR cameras and I dont recommend that you try it unless you have incredible talent for small details and a very clean environment.
6/22/2021 1:55:43 AM • Nikon... • Answered on Jun 22, 2021
My Nikon is coming up with “n1” where the numbers are displayed and the film won’t wind so I can’t remove it, what do I do?
On many cameras, a lens error means the lens is not set to is highest f/stop such as f/16 f/22 and the like. The lens must be put in that mode for the camera so that the camera electronics can auto set the f/stop as needed. First thing I would do is look at the f/stop on lens with manual f/stop settings; such as the Nikon 50mm f/1.8D making sure it is set to the highest f/ number (smallest opening). Remove the lens check the dial. Also, is the battery fully charged? If all that is okay then do the following couple of things; 1. Get yourself a film change bag, they look like a black plastic/rubberish T-shirt. Put the camera in there make sure the bottom is fully closed, put your arms through the sleeves, they have elastic keeping light out. Open the camera carefully remove the film canister then using your fingers rewind the film back into the canister. 2. Okay, you do not have access to a film change bag, easy get a thick blanket or two, go in to a closet, close the door, put a towel at the bottom, cover your camera as best as you can then do the same as if you were using a change bag. Important, make sure you are in a completely dark place without ANY LIGHT working its way through to you. Next, being as your are using film, big congratulations for that, purchase a change bag from Adorama, Amazon, B&HPhoto. Every film shooter should have one. Hope the above helps you.
11/2/2019 6:08:32 PM • Nikon... • Answered on Nov 02, 2019
Nikon N5005 35mm SLR Camera Logo
17 questions posted
Top Nikon Photography Experts
Tony Parsons
Tony Parsons
Pallikonda Nisha
Level 1 Expert
Are you a Nikon Photography Expert? Answer questions, earn points and help others
View Most Popular
Nikon Photography
  • Nikon Photography
Most Popular Question
work
  • Photography
