20 Most Recent
Panasonic Dmc-Tz30eb-K Compact Camera - Black 14.1Mp, 20X Optical Zoom 3 Inch Lcd Questions & Answers
My Panasonic Strada CN-HDS620D Car radio/dvd only plays for 50 seconds then freezes for over 5 minutes. Buttons also freeze and it's in japanese. Kindly assist.
It seems like you're encountering some issues with your Panasonic Strada CN-HDS620D car radio/DVD player. The freezing and button unresponsiveness, along with the language being set to Japanese, can be frustrating. Here are a few steps you can try to troubleshoot the problem:
1. Reset the device: Look for a small reset button on the front panel or the side of the device. You can use a small pin or paperclip to press and hold the reset button for a few seconds. This will reset the device to its factory settings. Note that this will erase any customized settings or saved data.
2. Check the disc: Make sure the DVD disc you are using is clean and free from scratches or dirt. A damaged or dirty disc can cause playback issues. Try cleaning the disc gently with a soft, lint-free cloth and insert it again to see if the freezing issue persists.
3. Check the power supply: Ensure that the car radio/DVD player is receiving a stable power supply. Check the wiring and connections to make sure they are secure and not loose. If the power supply is unstable, it can cause the device to freeze or malfunction.
4. Language settings: If the device is set to Japanese and you're not familiar with the language, you can try changing the language settings. Look for an "Options" or "Settings" menu on the device's display. Navigate through the menus to find the language settings and change it to your preferred language.
If the above steps don't resolve the issue, it's recommended to consult the user manual for specific troubleshooting steps or contact Panasonic customer support for further assistance. They may be able to provide additional guidance or recommend a professional service center if needed.
I hope these suggestions help you resolve the freezing and language issue with your Panasonic Strada CN-HDS620D car radio/DVD player. Let me know if you have any further questions or need more assistance!
Am I able to install English onto my Panasonic
No, that model was never intended for use outside of Japan.
Either remove it and replace it with another system or ignore it and buy a standalone satnav system (always cheaper and easier to update/replace).
Is it possible to change language on my navigator from Japanies from English
Yeah! This is possible. If you do not understand the Japanese language and using Gps then it is very hard to drive for you. Here are some simple steps for change Language. Step 1: Turn off your car and turn it on looking for a button that says "English." Some cars will have an option to change the language as soon as the car is turned on.Step 2: Look for a button around the touch screen marked "Language" or "LANG." Press this button and then press the button for "English" on the touch screen.Step 3: Check to see if your navigation system is a GPS system or a DVD system. If the system is a DVD system, you may have to call the company and purchase an English language disc. These can cost upwards of $150.Step 4: Take your car into a dealership that services your model of car. Many times they will be able to reprogram the computer for free, though some systems require more work and may be costly to change.If you want to update your downloaded Gps Device then you should feel free to browse our website or click on the Given link below and reach your destination very easily hassle free.https://www.gpsupdatesupport.com
