20 Most Recent
Dacor Preference RSD30 Gas Kitchen Range Questions & Answers
We have a Dacor RSD30
always shut power off
two screws attach element frame to body
look at new part for screw holes
you may have to remove convection cover in order too see
Gas range flame problems
Could be as simple as dirty burners. Take them off and you should be able to clean them out. Do that before calling a repair man. Otherwise you may have other problems. Make sure the burners are all put in the place they are suppose to be.
The spark gas igniter won't turn off how do i fix this
I assume you are talking about a surface burner spark igniter. If so, there may be a failed valve switch. You would need to access the back side of the surface burner valves and disconnect wiring to verify the cause. Selective disconnection at each switch should identify which switch is failed. Look at a parts picture for your exact model range to see the valve switches and identify the part to purchase.
Rsd30 lower element
Cause for problem could be failed element or failed wiring to element or failed control. Some electrical checks will determine which. If you are not knowledgeable in doing these checks get a repair technician.
