20 Most Recent
Ducane 436 inch 2 - 2 burner Grill Questions & Answers
Ducane high efficiency propane furnace, pressure switch problem
A short cycle heat cycle indicat a pressure switch replacement was needed. This did not fix the problem. the problem was in PCV line since the end was filled with slugs and cause the line to backup with water. When this happen the system would stop asking for gas. the water would leak out and it would restart. The problem was fixed by cleaning value at end of PCV. This released the water, two quart of water, that was back up causing problem. Curious if a filter change indicator was providing a clue that was missed?
How to replace the wheels on our 2004S Ducane gas grill?
first check for any screws at the wheels' center that could be loosened to remove the wheels. If not exist, please check if there any hub-cap-like covering on the wheel-centers than can be pulled away to reveal screws. You can also reference the grill's manual.
If all else fails, please reach out to Weber grills (who owns Ducane) over the phone get the strategy for removing the wheels. You can call them at 1 (800) 446-1071.
Thank you.
