20 Most Recent Frigidaire FGQ332ES Gas Dryer Questions & Answers
Frigidaire gas dryer trouble shooting gas dryer taking too long t
Check the fins on the fan impeller. They may be covered in lint or not spinning adequately.
3/5/2017 2:48:03 AM • Frigidaire... • Answered on Mar 05, 2017
Why Frigidaire gas dryer will not start? makes humming noise
Rodney, if the humming noise sounds like your motor is running but the drum does not turn you probably have a broken belt.
1/21/2015 6:15:42 PM • Frigidaire... • Answered on Jan 21, 2015
My Frididaire Crowne Model CRGR5700AS1 isn't getting hot
have a multi meter? check ur heating element and thermostats for continuity
12/20/2014 5:50:42 PM • Frigidaire... • Answered on Dec 20, 2014
I had a bunch of verywet towels because my sink was leaking, and I put them in the dryer and it worked for a few minutes them stopped. What might be wrong?
Good Morning Friend, I understand that you had a bunch of wet towels, and put them in your Frigidaire dryer, model# FGQ332ES. I see that your dryer worked for a few minutes and then stopped. There could be a possibility that the wet towels were too heavy from all the water in them. I suggest that you spin the towels out in your washer first and then move them over to your dryer. If you are still noticing the dryer working for a couple of minutes and then stopping, I suggest giving your appliance a hard reset. You will do this by either unplugging your appliance or shutting the power off at your homes circuit breaker for 3-5 minutes. When power is restored start it on any cycle. If your dryer is still shutting off after a few minutes, I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance and determine what is causing it to shut off after a few minutes. Hope this is helpful. -Best regards- WP
5/16/2014 2:45:05 PM • Frigidaire... • Answered on May 16, 2014
0answers
manual
0answers
Fridgedare front load dryer wont start, no noise, the light is on so i know it is getting power. finished one load went to start another and turned the switch and nothing
Hello ebega7 - I understand the lights are blinking; however will the display illuminate or allow you to program a setting? If it will not allow you to do so, try resetting the unit by either unplugging it or flipping the household breaker off. Wait approximately ten minutes and turn on the dryer. Select a normal cycle and if it is ineffective contact a professional to move forward accurately. The unit may possibly have a defective cord or wiring, control board or door switch.
1/8/2013 6:02:29 PM • Frigidaire... • Answered on Jan 08, 2013
Dryer runs for short time, then stops. will not restart.
Hello Tommy Mason - Have you try unplugging the unit or flipping the household breaker off. Wait approximately ten minutes. I suggest touching each button individually on keypad, do any lights turn on or does the display change? If any proves to be ineffective, I would recommend contacting a professional to move forward accurately because it can possibly have a defective keypad.
11/29/2012 4:47:26 PM • Frigidaire... • Answered on Nov 29, 2012
Dryer starts, runs a short while, then shuts off!
Does the dryer shut off or do you mean the heat shuts down?
11/27/2012 1:10:37 AM • Frigidaire... • Answered on Nov 27, 2012
Model glg331as4 will not tumble
Does the motor run and it won't spin or does it not respond when you press the start button?
11/22/2012 1:16:12 AM • Frigidaire... • Answered on Nov 22, 2012
I have a frigidaire gas dryer crgr5700as2 i need to replace the door switch but not sure which wire goes with which prong
Hello - Usually this type of information is not release to someone who is not a technician (or to a consumer) and it is very rare to find enough information to do it yourself. Typically this is something that you want a certified professional to install for you due to safety and liability reasons. They also usually warranty their labor just in case something else may turn out to be the root cause of your initial problem and it does work out better to your advantage. Consider contacting your manufacturer for more details on who in your area can properly install this part. (part usually have a 30 day warranty with tech). I would suggest contacting your manufacturer to provide you a listing of authorized technicians in your area whom may guide you through this process.
10/31/2012 7:51:42 PM • Frigidaire... • Answered on Oct 31, 2012
Dryer has power but doesn't spin or heat up
Check to see if the door switch "clicks" when you push and release it. If the switch is bad, the dryer won't run. Here is the part in case you need it.
10/30/2012 6:00:46 PM • Frigidaire... • Answered on Oct 30, 2012
0answers
Ho heat
Be the first to answer 3/7/2012 11:41:26 PM • Frigidaire... • Posted on Mar 07, 2012Be the first to answer
What do I need to
What you need is here:
http://www.repairclinic.com/PartDetail/LP-Conversion-Kit/PCK3100/1057164
Good luck from Detroit, MI.
7/11/2011 4:18:45 AM • Frigidaire... • Answered on Jul 11, 2011
I have power to dryer but dryer will not start
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
6/30/2011 1:38:50 AM • Frigidaire... • Answered on Jun 30, 2011
Frigidaire FGQ332ES Gas Dryer Logo
103 questions posted
Top Frigidaire Dryers Experts
ZJ Limited
ZJ Limited
Paul Bade
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
View Most Popular
Frigidaire Dryers
  • Frigidaire Dryers
Most Popular Question
frigidaire gas dryer will not start
  • Dryers
