20 Most Recent
Hard Drive Caddy 7X499 for Dell Latitude D400 with Connector for sale at Gadgettown.com Questions & Answers
Remove my credit card from Slotomania THATS ALL.
This is nothing to do with FIXYA dot com, so there is no need to rant at us. We are a peer to peer self help group and presumably you found us via Google. We are NOT Slotomania Support.
The easy way is to cancel your account, but I bet they don't make that easy either.
How to change my banking details on slotomania?
Super Cheats
https://www.supercheats.com > iphoneipad > questions
May 14, 2019 - To remove a payment method, tap Edit, then tap the Delete button. 7. To change the order of your payment methods, tap Edit, then use the ...
Have trouble removing old debit card from slotomania ...
JustAnswer
https://www.justanswer.com > computer > gw5c4-roub...
May 25, 2021 - 1. On your computer, go to your Google Play account at https://play.google.com/store/account/paymentmethods · 2. Click Edit payment methods. · 3.
1 answer · Top answer: Hi there! My name is ***** ***** I'm so happy to be helping you today! I have over 15 ...
How to Change Payment Method
The Game Reward
https://thegamereward.com > slotomania-slotmachines
Should you wish to remove your credit card information from your Facebook account, please click on your Account Settings (upper right part of the Facebook ...
Change epg colour, background & text ?
The ability to change the Electronic Program Guide (EPG) background or text color can vary depending on the specific TV or set-top box you are using. While some devices offer customization options for the EPG appearance, others may have limited or no options for modifying the colors.
Here are a few steps you can try to change the EPG background or text color:
1. Check the TV/Set-Top Box Settings: Navigate to the settings menu on your TV or set-top box. Look for options related to the EPG or display settings. Explore the menus to see if there are any options to customize the EPG appearance, including background and text colors.
2. Accessibility Settings: Some devices provide accessibility settings that allow users to adjust visual settings for better readability. Look for an "Accessibility" or "Display" section in your device's settings. Within this section, you might find options to change contrast, color, or text size, which could indirectly affect the EPG visibility.
3. TV Theme/Display Mode: Certain TVs or set-top boxes offer different display themes or modes that can change the overall appearance of the user interface, including the EPG. Check if your device has different themes or display modes and see if any of them improve the visibility of the EPG.
4. Contact Manufacturer Support: If you have exhausted the options available in the settings menu and still cannot find a way to change the EPG colors, it is recommended to reach out to the manufacturer's customer support. They can provide specific guidance based on your device model and may be able to assist you further.
Keep in mind that the availability of customization options can vary significantly depending on your specific device and its firmware version. Therefore, it is always advisable to consult the user manual or contact customer support for precise instructions tailored to your device.
Hard reset do not have password?
You willneed a factory reset. All data will be lost as no password, it probably isn't yours, so security will delete everything.
How to hard reset SC-1031W?
SC-1031W is a tablet made by Smartab. To hard reset the tablet, you can follow these steps:
- Turn off the tablet by pressing and holding the power button for a few seconds.
- Press and hold the volume up button, and then press and hold the power button.
- Keep both buttons pressed until the Smartab logo appears on the screen, and then release the power button while continuing to hold the volume up button.
- When the Android logo appears, release the volume up button.
- Use the volume down button to highlight "wipe data/factory reset" and press the power button to select it.
- Use the volume down button to highlight "Yes -- delete all user data" and press the power button to select it.
- Wait for the reset process to complete, and then use the power button to select "reboot system now" to restart the tablet.
Please note that performing a hard reset will erase all data on the tablet, so make sure to backup any important data before proceeding.
How do I hard reset Quorum ELERT Portable Alarm? Any ideas?
To hard reset a Quorum ELERT Portable Alarm, you can try the following steps:
- Disconnect the power source from the alarm
- Remove the battery
- Hold down the "Reset" button while reconnecting the power source
- Release the "Reset" button
- Reinstall the battery
This should reset the alarm to its factory settings and erase any previous settings or configurations.
If these steps don't work, you should refer to the manual or contact Quorum's customer support for further assistance. It's also a good idea to check the manufacturer's website for updated information and instructions, as the process for resetting a device can change over time.
How to recover data from the raw hard disk
Hi
Don't use the drive at all until you are in a position to start a recovery scan.
To do this you need:
A working computer that you can attach this drive to as an extra.
Another drive (external or the boot drive) large enough to save any data
Appropriate software for the data recovery.
The software is the most difficult to specify as some are better at some recoveries than others. I have had some success with Pandora Recovery, available here:
http://www.freewarefiles.com/search.php?query=Pandora+recovery&B1.x=7&B1.y=11&boolean=exact
or PC Inspector File Recovery, available here:-
TechRadar
There are many Recovery programmes out there, you may find another you feel happier with, but both the above have worked for me.
Once you have downloaded and installed the software to your computer, read the help/instructions carefully before you start.
Basically there are three steps to recovery :
Firstly a full scan of the affected drive. Be patient this can and often does take hours, especially with larger drives.
Secondly the programme compiles a list of the files it can recover, often with an estimate of the probability of the file being intact and usable after recovery.
Thirdly identifying those files you want to recover and telling the programme where to save them once recovered - NOT the drive you are recovering from.
Hope this is helpful, if so would you please register that with Fixya
Cheers
How to hard reset onda v971
If your onda v971 tablet is giving you trouble, there are a few things you can try to get it working again. Sometimes a hard reset is all it takes to get your tablet back on track. Here's how to do a hard reset on your onda v971 tablet:
1. Power off your tablet.
2. Press and hold the volume up and power buttons simultaneously for about 10 seconds.
3. Release the buttons when you see the Android logo appear on the screen.
4. Use the volume buttons to navigate to the "wipe data/factory reset" option and select it with the power button.
5. Confirm your selection and wait for the reset to complete.
1tb external hard disk drivers
zippy is like 2003 products, super rare now
NO PC told
no OS told XP to W11 is is windows , is it windows?
no zippy enclosure model told . 1tb first drive is 2007
is it USB , E-sata , firewire , or Bluetooth connected, how"?
if USB try all USB ports yet.?
try on 2nd good PC. yet. why not?
connected can you year the hDD spin?
is it a 2.5" or 3.5"HDD inside, if large it needs a power pack or will never ever work lacking good power.
the maker zippy is gone, and super super extreme rare now.
zippy is gone and there are no drivers. (unless MS has them)
MS is microsoft, as in windows.
if running w10 most old USB devices older than 2010 are dead.
no drivers exists. on the old USB devices.
the drive must show up in (winkey+X) DISK MANAGER.
