20 Most Recent
Samsung Laser Multifunction Printer Toner Cartridge Questions & Answers
Hi there, i would like
> CYCLE POWER
Turn the printer off.
Disconnect the power-cable from the wall-outlet.
Reconnect the power-cable.
Turn the printer on.
This is the full "cycle" from ON to OFF to ON.
Speckles all the way down the left side of print
Usually that type of print defect is caused by a drum unit being worn out. Check your users manual for the part number. It may be available from Office Depot or the store you purchased the printer from, if not order online.
Buddy
Corporate Computer
www.ccl-la.com
Black spots of the left side of the print
If you know how to remove your drum cartridge, take it out and check if you don't see your black spot on your drum....If so, replace your drum cartridge.
You may have a bad fuser to....
let me know !
I have a samsung C410W printer which keeps on flashing red and will not print. Help
Samsung printer C410W. Red light flashing.Checked paper paths; checked cartridges (nothing lower than 85%); removed and returned cartridges; checked back panel paper path. Still flashing red.
Technician's Assistant: Have you tried running your printer's self-cleaning cycle? (Sometimes you have to run this several times to see results.)
Is the self-cleaning prompt in the Easy Printer Manager?
Technician's Assistant: Have you tried wiping down the metal contacts on your printer and cartridges?
I have now wiped them
Technician's Assistant: Anything else you want the Printer Expert to know before I connect you?
How do I start the self-cleaning cycle?
I can't show ip address of printer samsung ml3312nd
In Windows, you can use the Control Panel to find the printer's IP address.
- Go to Settings > Devices > Printers and Scanners.
- Find your printer in the list, click on it, and select Manage.
- Click on Printer Properties.
- In the General tab, find the Location field. Your printer's IP address will be located in it.
For MAC OS click the Apple sign and locate printers.
