20 Most Recent
Apple iMac DV Ruby Mac Desktop Questions & Answers
ERROR CODE 4M0T/4/40000003: HDD-1211
Install a new HDD.
Press and hold Command, Option and R keys with a keyboard connected via USB.
Power the mac on whilst holding down the keys. Release the keys when the globe shows and select your router code then download the OS for your mac.
Install the OS.
It takes some time to do this!
4sns 1 4000000 th00 9.000
There are several causes for this:
- Dust buildup in the computer prevents proper cooling, so the fans have to work harder.
- Corrupted Power Manager chip settings. Go to the Apple support page and search for "Power Manager" "reset" and your specific model. You can get the model number from the System Profiler utility (Apple menu: About this Mac: More Info). If this is the problem, resetting the Power Manager should solve it. If it happens again after unplugging, you may need a new clock/PRAM battery;
- Bad temperature sensor (all fans run at high speed);
- Shorted fan driver transistor on the logic board or in power supply (one fan always runs at max speed).
Help yahoo com
If you are sent bulk mail then you are not used public email server. Because public email sent normal 10-50 max email one day. If you are bulk mail sent then you are purchase extra space or server. If you are want yahoo through sent email then contact yahoo and ask i want to sent bulk mail so yahoo available space or service and also yahoo charge taken.
Thanks,
MacHealthCheck
Imac pc unable to change the @ on a uk keyboard
Please select a different keyboard layout
Click the Apple icon from your menu bar, select System Preferences, and then follow these steps.
1) Click Keyboard.
2) Make sure you're on the Input Sources tab.
3) Click the plus sign button on the bottom left.
In the pop-up window, you'll see a list of languages on the left and options for them on the right. You'll also see a preview of the keyboard layout.Select the language you want and then pick the option on the right. For example, French > ABC - AZERTY or English > Dvorak.
5) Click Add.
I need delete my Guest account on my MacBook Air
For removing the guest account
Click on Apple menu on the desktop and select system preferences then click the user & Users icon in the system action.
Click the bottom right corner and then enter you account and password as prompted.
This unlock the setting allow to make a changes.
How toEject a stuck CD in Imac?
If your Imac is in Warranty period than don't go for these process. Call your near by Apple support any demand for service
http://www.apple.com/imac/ . but if you are out of warranty than
Try to Eject it from Desktop Disk Drive or Restart your Imac and try to eject. if still not help than follow
Mac Support .
How do i send email with a large attachment from my imac
Hi
Attachments to email should be less than 10mb.
Your ISP sets the limit.
Open an email and get it ready to go.
Put cursor where you want the attachment to sit on the page.
Drag your file to be attached, from the Desktop to the Email window & drop. Then clik send.
For larger attachments:
Use the free DropBox to share files with friends. You place files to be shared in the Dropbox Folder which shows in the top menu of a Mac. Very simple to use, once set up.
https://db.tt/7ByRbUj
Cheers
Trevor
