20 Most Recent Xerox Phaser 3200MFP/N Laser Printer Questions & Answers
That is the Laser unit. Not good. There may be a service reset process but you'll have to send or call it in.
Xerox Phaser... | Answered on May 01, 2017
If you have recently replaced your toner drum then probably the replacment drum is not matching the printer`s criteria or may be the repalcement drum is not the right to be intalled in. Check with service manual if you have got the right replacment or not.
Xerox Phaser... | Answered on Apr 25, 2017
need change fuser unit
Xerox Phaser... | Answered on Sep 09, 2016
The fuser is not coming to temperature. Probably bad temperature senor on fuser. Replace fuser.
Xerox Phaser... | Answered on Mar 23, 2015
There is a small strip of glass on the left side directly under the edge of the scanner, About a half an inch wide. It has something on it.
May be very hard to see, use a strong glass cleaner or some alcohol and a regular piece of paper to clean it with.
Xerox Phaser... | Answered on Mar 14, 2015
Take your empty cartridge to any Costco or Fry's electronics and they will fill it for you at a great price
www.costcoinkjetrefill.com
Xerox Phaser... | Answered on Aug 08, 2014
Laser Unit has failed and needs replaced.
Xerox Phaser... | Answered on Mar 16, 2014
I would highly suspect a defective toner. What happens if you put the old toner back in - - do you get the same error? If you don't, then replace the toner. If you continue to get a lsu error, then your Laser Unit has a toner spill on the glass, or has gone bad and will need replaced.
Open heat error is caused by a bad fuser. Replace the fuser assembly.
go to xerox.com driver, put in your operating system type and download the proper driver
Xerox Phaser... | Answered on Jan 16, 2014
Xerox Phaser 3200MFP/N Laser Printer Logo
109 questions posted
Top Xerox Office Equipment & Supplies Experts
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
Phaser Xerox
  • Phaser Xerox
Most Popular Question
install toner continuously beeping
  • Office Equipment & Supplies
