20 Most Recent
Canon MF8180C Color Laser MFC Printer Questions & Answers
Supply rec paper tray - what does this mean when the tray is loaded?
OK, I was having a similar problem: Tray full of paper and tray adjusted properly.
Whatever I tried, the printer kept saying load paper.
I went to print menu>properties button (windows XP this is next to the printer name)>paper source tab.
It tuned out that the paper source had been changed from cassette to multi-purpose tray.
Change it back to cassette and you should be golden.
How do I fix error code E000 on a canon MF8180c
hello the error E000 MEANS "fixing assembly faulty start-up (open circuit in the main thermistor)You need to Check the connector of the fixing film unit or Replace the fixing film unit or Replace the DCNT Borad PCB.you need to get the service manual for it will help you a lot you can get it from the below link:
http://goo.gl/uYxA40good luck
