20 Most Recent
Canon MF4150 Laser Printer Questions & Answers
Canon mf4100 have a paper
I had a problem with a constant false paper jam, after I teared a paper trying to get it out after a real paper jam and I did it wrongly, probably damaging in doing so a spring sensor at the paper exit. It is a small plastic rod in the middle of the opening where the paper comes out that just senses the paper, when it's coming out - I damaged the spring holding this rod in place and consequently it was always up (but should have been down until the paper passes - which signals that the paper has come out).
Nothing helped, powering off and again on the printer only resulted in hearing a sound of the wheels mechanism trying to turn, but got stuck.
Disassembled all the external plastics and the top part, reached the black curved plastic where the paper comes out, opened it from the top (fixed in place with 2 plastic hinges on left and right) and there it was the sensor with the plastic rod with a spring out of place. Fixed the small spring, assembled all together and it works.
It keeps on giving me
It thinks there is a document stuck in the document handler. Check for a small piece of paper, or a stuck sensor.
Please post your feedback and Vote if the problem resolved as per your satisfaction.
A600 error or Canon Pixma MP780.
Hi there
Error A600
Your A600 is a paper path error, usually related to the purge unit. Try checking the purge unit for paper stuck in it.
The 6A00 is a Canon generic code for paper path jam.
Some where in the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 code.
Almost 90% of the time is related to the purge unit being jammed with something and not being able to move.
Look for paper, paper clips, push pins, screws flower bud pods or the like.
The offending item needs to be removed or the purge unit needs replacement.
The purge unit, called a spittoon assembly in an HP, Lexmark, and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing. That is why you'll find the print head assembly parked on top of it. It also has an electrical pump to milk the print heads and test for ink flow.
The purge unit is a white plastic assembly (on the right side of the printer where the print head homes) that is spring loaded on rides on a rail.
You can try moving it back and forth about 5 times or so and clean the rail with a cleanex and putting a little bit of some light oil on it and then close everything up and try it.
If you found this useful all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Campatibility with MacBook
Ther are a few 3rd party solutions to this, the unix based gimp print will print to allmost any printer, do a googlesearch on gimp print
Printer driver for Cannon Image CLASS MF 4150
First of all i like to know for which operating system you need that driver.
anyways follow the below link for Vista driver -
http://www.microsoft.com/Windows/compatibility/Details.aspx?type=Hardware&p=Canon%20ImageCLASS%20MF4150%20-%20multifunction%20(%20B%2FW%20)&v=Canon&uid=&pf=6&pi=3&c=Printers%20%26%20Scanners&sc=Multifunction&os=32-bit
Good Luck!!
Thanks
Configure dates and telephone connection to enable fax
Copy this site to your web browser for the manual. Look at the Guides and Manual section for downloading the Instruction Manual for your Canon MF4150 Laser Printer. Hope it helps. (http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=335&modelid=14444)
