20 Most Recent Canon PIXMA iP3500 Printer Questions & Answers
2answers
Waste ink absorber full
It's Very Simple
Just Enter in Service Mode of your printer and clean absorbers count.
To enter in SERVICE MODE
1) Power off Printer
2) Push and hold "Resume" button and then push and hold "Power" button
3) Hold the Power button, then release and 2 times press Resume button
4) Led indicators must change
5) Release all buttons
6) Then printer in Service Mode
(If something wrong, repeat 1-6)
To clean absorber counter,
7) Press "Resume" Button 4 Times and after press Power button. It's all! Your absorber count is EMPTY!
In SERVISE MODE you can do several useful things:
To print Service Nozzles test, press "Resume" 1 time and press Power
To print EEPROM data, press Resume 2 times and press Power.
DO NOT press Resume 3 times and POWER. It will reset some EEPROM data settings
Any Question mail me: ossipenko(prettydoggy)gmail.com
7/18/2019 10:47:36 AM • Canon PIXMA... • Answered on Jul 18, 2019
3answers
Flashing orange light
Cannon pixma 3500 Flashing orange light count the blinks for the error,
5/24/2019 9:34:34 AM • Canon PIXMA... • Answered on May 24, 2019
2answers
Why is Alarm code 5 flashes not going away?
This is consistent with any of error codes 1401, 1403 and 1405. It indicates a problem with the print head. Per Canon the resolution of these errors 'requires the assistance of a Canon authorised service facility. Please use the link at the top of the page to locate your nearest facility.' From Canon error page for 'Orange light blinking 5 times': 1401/E05 Description: The print head is not installed or has not been properly installed. 1403 Description: A print head temperature sensor error has occurred. 1405 Description: Faulty data of the print head. http://www.canon.co.uk/support/consumer_products/product_ranges/printers/pixma/error_codes/
5/24/2019 9:25:55 AM • Canon PIXMA... • Answered on May 24, 2019
My Canon iP3500 will not
The paper feeder pads need to be replaced. You may be able to buy these directly from Canon.
11/11/2017 12:26:06 PM • Canon PIXMA... • Answered on Nov 11, 2017
Orange light flashing five times
With the printer on... Open the lid Remove the ink cartridges Lift the print head lock lever on the left Remove the print head Gently clean out any ink Gently clean the copper contacts on the back Gently clean the print head nozzle(s) on the bottom Make sure it's dry Re-install the print head Put the lock lever back in the down position Reinstall your ink Close the lid Try printing again The printer may detect that you removed/inserted ink so it may go through a print head cleaning of it's own that you need to wait to finish If needed, power cycle the printer and then try printing again You may need to replace the print head
11/11/2017 12:02:49 PM • Canon PIXMA... • Answered on Nov 11, 2017
CANON MG8100 series error 5C00
Per http://www.canon.co.uk/support/consumer_products/product_ranges/printers/pixma/error_codes/#5c00 5C00 - Orange and green blinking 4 times Description: A service error has occurred. Resolution:
  1. Turn off the printer.
  2. Disconnect the power cable.
  3. Open the printer cover.
  4. Check for any orange protective tape or white polystyrene and remove if necessary.
  5. Check that there are no foreign objects in the printer (such as a paper clip) and remove if necessary.
  6. Close the cover.
  7. Reconnect and turn on.
If the above solution has not resolved your error, please contact your nearest Canon authorised service facility using the link at the top of the page.
3/22/2016 12:33:32 PM • Canon PIXMA... • Answered on Mar 22, 2016
Light flashes 3 times
Which light? Orange? You probably have a paper jam or an obstruction in your paper feed path:e.g.Orange light blinking 3 times 1250/E17Description:The front door is closed.Resolution:Open the front door to allow prints to exit.1300/E03Description:A paper jam has occurred during printing.Resolution:Locate and remove the jammed paper from the printer.Press the button on the device to continue printing.1303Description:A paper jam has occurred in the rear tray.Resolution:Remove the jammed paper from the rear tray.Press the button on the device to continue printing.Derived from: http://www.canon.co.uk/support/consumer_products/product_ranges/printers/pixma/error_codes/
3/22/2016 12:08:44 PM • Canon PIXMA... • Answered on Mar 22, 2016
What causes orange light to flash 4 times?
It is related to a badly installed or empty print cartridge: http://www.canon.co.uk/support/consumer_products/product_ranges/printers/pixma/error_codes/#1600 1600 - Orange light blinking 4 times Description: The ink cartridge has run out. Resolution:
  1. Lift the printer cover up.
  2. Identify the ink cartridge that has run out (the ink cartridge flashes quickly at around 1-second intervals).
  3. Replace the applicable ink cartridge and close the cover.
  4. Press the [Resume/Cancel] button on the device to continue printing.
If the above solution has not resolved your error, please contact your nearest Canon authorised service facility using the link at the top of the page. 1660 - Orange light blinking 4 times Description: The ink cartridge has not been installed correctly. Resolution:
  2. Check that the red lights on the ink cartridges are all turned on.
  3. If no red light is activated on a particular cartridge, check that the cartridge is securely positioned and adjust if necessary.
  4. Also make sure that the orange protective cap has been removed from the bottom of the ink cartridge.
  5. Press the [Resume/Cancel] button on the device to continue printing.
3/20/2016 1:57:12 AM • Canon PIXMA... • Answered on Mar 20, 2016
The printer won't print... it demands I try a test page... I print the test page and it STILL won't print. My ink cartridge levels are fine!
ok first thing to check is the connection. either network or usb, Go to start on your computer and bring up devices/printers and faxes. look for your copier. right click and select printer properties it will be below preferences. you should get a page come up. first option is general, select the PORTS option and check the ticked address, either the ip address or usb. if it on parralell port this can cause errors. it might have selected this if you have a usb port try swapping the usb selection. If on network cable check the IP address is correct. You can check the ip by typing it into your web browser and the web page for the copier should come up if connection good. It sounds like the connection type may be wrong if its saying off line. Good luck,hope it helps
10/19/2015 10:17:15 AM • Canon PIXMA... • Answered on Oct 19, 2015
Paper is not printing
Since you are asking about a Canon Pixma ip3500, I would guess that the ink cartridge(s) is/are dried out, empty, or clogged. Try swapping out with new, fresh Canon cartridges and see if that fixes the problem. Also, be aware that it is extremely ill-advised to use only refilled or "compatible" cartridges all the time in the case of inkjet printers (of which the Pixma line of printers is an example). The reason being that the refilled and "compatible" cartridges use plain ink while the OEM cartridges use a mix of ink and lubricants so as to keep the ink delivery system functioning to peak efficiency and help to keep the system clear of clogs. Therefore, if you have recently put in a new cartridge but it is yet another refill, swap it out for a real Canon cartridge and then try using the "clean the printer" function to try to clear out the ink nozzles. If you don't feel comfortable doing this or you are unsure how to accomplish this task, get in touch with a local computer or printer repair shop and they will gladly resolve this for you.
6/5/2015 4:30:56 PM • Canon PIXMA... • Answered on Jun 05, 2015
3answers
Canon Pixma Ip3500 will not power on
In that case its power source - the black box on which the mains cable plugs in is dead.
The printer is fixable - all you need to do is to replace the source. But this will cost you almost as much as a new printer. Your choice.
4/20/2015 4:52:21 AM • Canon PIXMA... • Answered on Apr 20, 2015
My Canon Pixma is not printing properly. Sometimes it prints sometimes it doesn't. Any info and help appreciated.
dear the contact points of the ink cart. to be cleaned with dry cotton lint free cloth. if it not improved then touch the head on the boiled drinking water for minuet and dry the contact point to moisture if any. this will help to reopen the nozzles. thanks.
1/21/2015 3:18:25 PM • Canon PIXMA... • Answered on Jan 21, 2015
Yellow in not working
  1. plz clean the jet cartage with isoprropile or alcohol and then chek.
7/24/2014 4:25:57 AM • Canon PIXMA... • Answered on Jul 24, 2014
2answers
Error light flashes 5 times
According to the manual (see http://www.canon.co.uk/Support/Consumer_Products/products/printers/InkJet/PIXMA_iP_series/PIXMA_iP3500.aspx?DLtcmuri=tcm:14-1026897&page=1&type=download " Five flashes: Print Head is not installed. / Print Head is defective."
"Follow the directions given in your setup sheet to install the Print Head.
If the Print Head is already installed, remove the Print Head once and then reinstall it.
If the error is still not resolved, the Print Head may be damaged. Contact your Canon Service representative. "
6/15/2014 2:55:22 PM • Canon PIXMA... • Answered on Jun 15, 2014
Error light 5 flashes times
Try this link. http://electronicshelponline.blogspot.com/ It has details about the error codes to many popular printers. Search the site by brand name of your printer. It will make search easy.
5/12/2014 2:12:55 PM • Canon PIXMA... • Answered on May 12, 2014
Canon PIXMA iP3500 Printer Logo
242 questions posted
old marine
old marine
ZJ Limited
ZJ Limited
View Most Popular
PIXMA Canon
  • PIXMA Canon
Most Popular Question
orange light flashes 4 times
  • Office Equipment & Supplies
