20 Most Recent
Doro DECT 850 Cordless Phone Questions & Answers
Resetting answering machine message, lost
goto this wepage put in your model number and you can download your replacement manual.
http://www.doro.com/global/businessunit/dorohome/support/manuals
Reset base unit defaults
Resetting will return most functions to the original factory default setting.
Registrations are not affected by resetting.
1. Press Menu.
2. Scroll using v/V to Base Set. Press OK.
3. Scroll using v/V to Default Set. Press OK.
4. Enter your current base unit PIN code (0000 at default).
5. Press OK to confirm.
What buttons do we need to use to set new message
Click menu/select button, select>Ans. system, press up/dn arrow to select >ans. machine set-up, then press menu/select. up/dn to.announcement, then press menu/select. handset announces "to play press the #" (that it tells you, to record, press the # that it tells you). handset announces "record after tone" and (press the # it tells you) when complete. after tone, speak towards the microphone of handset. press# it told you when complete.
I’m happy to help further over the phone at
https://www.6ya.com/expert/david_6df67de3b14de867
Doro 5065 - changing outgoing message
Go to:
http://www.doro.com/global/businessunit/dorocare/support/imagesdownloads
Type in your phone model number. Scroll down to PDF and download in your language.
I can receive a call but caller cannot hear my reply on Doro Phone easy duo cordless
double posted but now a not complete model told
a land line. posted o cell phones wrongly.
DORO PhoneEasy 100W Duo - cordless phone with caller ID?
or the model 110
or the model 115
we can not guess the model numbers
the the microphone is failing
did you get 2 phones in the kit new (as is common) and both fail.
is the battery still good.?
see this hole, , clean it carefully, of food or spittle. sludge.
that is the MIC.
