20 Most Recent
RCA 25205RE1 Phone Questions & Answers
2 line phone rca 25205re1 only 1 line works not the rollover line
Most likely the problem is the cord from the wall to the phone. There are two types of cords and they look almost identical. Look closely at the connector. A single-line cord will have only two gold pin at each end. A two-line cord will have four gold pins at each end.
You need a two-line cord to get both lines from the wall to your phone. Since you have had the problem with several phones, that is the most likely cause.
RCA Phone model 252025 - displays Answer... on line 1
The Thomson folks said to reset the phone. Here's how: unplug power, then the phone line, then remove the batteries. Wait 10-15 minutes. Replace the batteries, then the phone line and finally, the power.
Note: We have 2 phones with these two lines and had to reset both of them to clear the "busy" on Line 1.
RCA 25205 Visys will not record message
Called the company. There is a misprint in the instructions.
In the section titled "Out-Going Announcement RECORD" on last step it says Press Exit to stop recording. It should have said Press Sel/Save.
I did this and it worked.
Repeat for Line 2 if you are doing both lines.
Next thing is to make sure you go right to the section titled "Configure Out-Going Announcement" and select the right type of message you want callers to hear for each line.
Worked like a charm and took 3 seconds to get 2 different personal messages on the machine.
I just want to make sure that I am shopping for
Yes, you can use a regular 2 line cordless phone with your 4 line corded systems. The only concern is when you put someone on hold. The on hold function may not release if you have different makes of phone. If you already have Panasonic get a Panasonic 2 line cordless phone with the on hold feature.
Yes, you can just take line 3 and plug it into your new fax. I might suggest looking into a fax to email service instead of buying a new fax. If you receive more than send it's a great way to save on the phone line and paper.
Digital phones are pretty secure, no one will accidentally hear your conversations. It is not encrypted but I think it would be perfectly fine in your office.
Greg
Where can I purchase a two line cord?
hi,
we have read your question that where to get the two line cord. I had provided, the address below, linking to the website for purchasing the cord, online.I have also added the image below for your verification of the cord, you are looking for! Please rate my solution as helpful.
http://www.amazon.com/s?ie=UTF8&hidden-keywords=rca&rh=n%3A597546&page=1
Thanks, have a great day.
RCA 25205 wont answer correctly
Yeah, I've wasted all morning messing with this. My personal outgoing message keeps reverting back to default. I just got off the phone with RCA and here's the fix for that part of the problem. Go into "Configure Out-Going Announcement" (page 23) and then select "personal," This finally made it stay there. The number I called for help is 1-800-511-3180, or 1-866-285-4651. Good luck!
