20 Most Recent
Nortel Meridian M3820 Corded Phone Questions & Answers
How to programe the 14
When you connect a Nortel Meridian M3820 phone to a 3300 CITELlink Gateway andprogram it as a CITELlink Type2 device, ... Button Label. Function ... Feature Key 4. 11. Feature Key 5. 12. Feature Key 6. 13. Program. 14. Menu Right
Meridian M3820 - why is display not working
Try another 4 wire phone cord from the wall jack to the phone it is possible that you have a bad cord. These phones will only work with a Meridian System .2 wires are line ,the other 2 wires are power to the phone. If you have another phone try plugging it into the same wall jack to check the jack/line itself. Anything else would be a defective phone/ lcd ( note you can have dial tone without display, but the unit will only access one line.
I have a meridian m3820
press feature 983 the screen should say log:
enter 1020000 (default password) if you have a 3 digit intercom number, 120000 if you have a 2 digit intercom number
the display should say m box, AA, and other, above the three soft keys
press the m box soft key
the screen should say add, Del , and change above the soft keys
press the change soft key
enter in the mailbox number you wish to reset the password on
press o k
the screen should say reset and next above the soft keys
press the reset soft key
press the RLS key
your password should be reset to 0000 The default .
Cannot find how to change the password, I have
the display should say mbox, AA, and othr above the three soft keys
press the mbox soft key
the screen should say add, del, and chng above the soft keys
press the chng soft key
press ok
press the Rls key
I want to insert headphone jack and need to
There should be a swing plastic cover on the front underside of the phone for plugging in the headphones line cord plugged in and handset cord plugged in the middle jack is for heanset.
Phones
obviously if you know the german word for "language"it would help greatly.you need to press the button that is labelled program then press the scrollbar (below the keypad) and each time you press the scroll the display will show a different menu.when you see something like afspraak (german word for language ?) select the digit beside it and you are then in the language menu.then select english for your language choice.i hope this helps
