20 Most Recent HP Business Desktop dc5700 - Intel Pentium Dual-Core E2140 1.6GHz - 512MB DDR2 SDRAM - 1 x 80GB - DV... Questions & Answers
Intel e2140 driver for windows 7
You can download the device drivers from the Compaq/HP WEB support/download page. Make sure you select your model laptop and the Windows drivers you require and install them. Click on this link to download the drivers: - http://welcome.hp.com/country/au/en/cs/support.html
1/8/2013 8:56:00 AM • HP Business... • Answered on Jan 08, 2013
I am not able to
You can download the drivers from the Compaq/HP WEBsupport/download page. Make sure you select your model laptop/computer and the Windows version of the drivers you require and install them. Click on
3/29/2011 9:12:27 AM • HP Business... • Answered on Mar 29, 2011
I want install windows xp on hp pc Pentuim 2 step by step
For installation of windows xp you will need windows xp bootable disk. Set the first boot device to cd/dvd and proceed with installation.
3/31/2010 11:50:40 AM • HP Business... • Answered on Mar 31, 2010
Users cant get access to share drive
there is some security rights issue check that for that user ou user has set permisson of read and write and full check its ou security rgihts also check user group.
6/23/2009 7:32:37 AM • HP Business... • Answered on Jun 23, 2009
2answers
Xp or linux couldnot load in my laptop
I've successfully installed XP SP3 on a DV5Z (custom build). Here is what I did, you will need to check that your DV5Z has the same components before using these drivers.
Step 1 Create an XP boot disc
Get the AMD motherboard/SATA drivers slipstreamed into an XP SP2 installation disk. I use NLite for this from http://www.nliteos.com
Drivers are available at:
http://www.gigabyte.com.tw/Support/Motherboard/Driver_DownloadFile.aspx?FileType=Driver&FileID=3517
Other forum posts have more information on how to create the disc but I found NLite pretty easy to use. I suggest slipstreaming the SP2 patch into your installation disc.
Step 2 Install XP
Install XP from a Bootable disc you created using NLite. Get XP working and upgrade to SP2 if your installation disc wasn't already SP2.
You should see all the devices now in Device Manager in XP, but with exclamation marks.
Step 3 Get the XP drivers/software
The HP Compaq 6735s shares many components so you can get many drivers from this link:
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=3687622&prodTypeId=321957&prodSeriesId=368762
1&swLang=8&taskId=135&swEnvOID=1093
Audio UAA bus driver sp33867 Install this before upgrading to XP SP3
HP Software update sp38874
Synaptics touchpad sp39032
Wireless assistant sp39374
Quicklaunch 6.40F1 sp39425
XP SP2 updates sp39429 I guess these will be in XP SP3
Driveguard software sp39602
Webcam driver sp39606
Driveguard driver sp39738
AMD CPU driver sp40535
AMD SATA driver sp39719
The following is on other laptop models but you can just search for it manually or use the following link:
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=US&swItem=ob-62438-1&prodTypeId=321957&prodSeriesId=3687621
Audio IDT driver sp39671
Drivers from other sites:
1) Realtek Ethernet driver
http://www.realtek.com/downloads/downloadsView.aspx?Langid=1&PNid=13&PFid=5&Level=5&Conn=4&DownTypeID=3&GetDown=false
If the link doesn't work you want the PCI Express versions fromhttp://www.realtek.com
2) AMD Dual-Core Optimizer
http://www.amd.com/us-en/Processors/TechnicalResources/0,,30_182_871_14098,00.html
If the link doesn't work look around on http://www.amd.com
3) ENE CIR driver version 1.3.306
http://drivers.softpedia.com/get/Other-DRIVERS-TOOLS/Others/MSI-GX600-08-ENE-CIR-Driver-133060.shtml
I found that the 1.3.306 Vista driver works fine on XP but newer Vista drivers do not. I couldn't find an XP driver
4) Atheros Wifi AR5008 driver
http://www.atheros.cz/
5) Realtek Card Reader
http://www.realtek.com/downloads/downloadsView.aspx?Langid=1&PNid=15&PFid=25&Level=4&Conn=3&DownTypeID=3&GetDown=false
If the link doesn't work look around on http://www.realtek.com
6) ATI graphics
Get these from http://www.ati.com you need to get the Integrated chipset version if you have HD3200 graphics.
7) Realtek Audio Codec
http://www.realtek.com/downloads/downloadsView.aspx?Langid=1&PNid=14&PFid=24&Level=4&Conn=3&DownTypeID=3&GetDown=false
I installed both the ATI HDMI Audio device and the Windows XP driver, you may only need the ATI HDMI.
Step 4 Installation
Install the drivers first (after devices have been detected), then the software. You will need to force install some of the drivers by going through Device Manager but most of the drivers have installation programs. CANCEL ANY DETECT HARDWARE DIALOG BOXES TO AVOID AUTO-INSTALLING THE WRONG VERSION OF A DRIVER.
You will also need to carry out a registry fix for the wireless LED. Copied from another post:
"For the Wireless LED its a little trickier. If you can find the root directory for your wireless network adapter like Paddy MacSeamus mentioned above its pretty simple. Follow his directions until you find your Wireless Network Adapter listed next to DriverDesc. In that same directory, i.e., 0003, add these Dword values just like you did above:
New-> Dword
Value Name=gpioFunc0ActHi and Value Data=0
Click Ok.
New-> Dword
Value Name=gpioPinFunc0 and Value Data=3
You are done. These values should be seen in the same window as DriverDesc and the name of your Wireless Network Adapter. The LED will work correctly after you disable and re-enable your wireless."
After doing all this, my DV5Z works correctly except for the following:
- Mute button LED always on orange
- No on-screen display of volume/mute etc. You can use Microsoft Intellitype (use the Digital Keyboard device and download this) instead of the HP software - see other forum posts if you need more info on where to find this
- QuickPlay key doesn't work. Presumably this can be fixed by installing the QuickPlay software for another notebook eg DV6000 series but I've not tried this
One final thing - I was given incorrect SP details by an HP person on an online chat session and told to refer to manufacturer websites for other drivers. The latter is incompetent but acceptable in my view, whereas the former is clearly unacceptable (why give out incorrect details on their own drivers and pretend they're doing me a favour?).
6/5/2009 8:13:30 PM • HP Business... • Answered on Jun 05, 2009
3answers
Install windows xp in hp dv5 1106 or hp dv5 1102 or dv 2000?
Just integrate the correct sata Drivers with WinXP and Install XP Normally>>>
(Intel wireless - RTL Lan - nVidia Graphics - intel chipset ) can be installed Easily
(BT - Sound Driver - Mic - Scroll - Fingerprint) Can't find their drivers
(Webcam) Driver automatically Work with XPSP3 without Drivers
5/6/2009 4:45:56 AM • HP Business... • Answered on May 06, 2009
Hp pavillion dv5-1106tx drivers for windows xp pro
the drivers will be available on hp.com go there and type ur model no and series u will getand there will be a option like which os u have select drive according to ur os
2/28/2009 7:05:50 AM • HP Business... • Answered on Feb 28, 2009
Start up problem
Techguru2009: The startup fails to load because you have too many programs trying to start at the same time when you log on. To fix this problem you are going to sacrifice what programs you want to start up when you log on. first I asume you are using windows operating system. click the start button, click on run, type msconfig, press enter. Click on Startup tab. Uncheck the box for programs you do not want to start when you log on. Careful not to disable windows startup programs. Hope this helps.
2/26/2009 5:28:27 PM • HP Business... • Answered on Feb 26, 2009
How i install window xp in dv 5 and dv 4
You'll need to follow this guide:
http://maxeasyguide.blogspot.com/2008/04/preparations-for-winxp-installation-cd.html
It's not exactly hard, but it's not the easiest process if you're a n00b.
2/20/2009 12:09:16 AM • HP Business... • Answered on Feb 20, 2009
3answers
I need to know how to turn on a HP X13-04657 LAPTOP, all the lights are on but nothing on the screen.
HP X13-04657, is 2007 PC THOSE this PC has CCFL back lamp strip that is dead.Vista era PC, laptops. are hard to work with now, 17 years old.is this not a HP COMPAQ presario HP X13-04657 (wrong name!) sorry !became HP in 2002. so is HP but manuals are super hard to find now. that x13 is part of the microsoft license code vista. (so is distraction to what it is)the real name of the Laptop is and was Presario CQ61 laptop CQ61 the PC has bottom sticker that shows the real names of PCs.CQ61-219TU is real name of on CQ61, there area many different sub codes, and they are not all the same.CQ61-306AX this had CCFL (cold cathode florecent lamps) that love to fail 3 waysdead, blinks ,dime or yellow = white.was made until 2009 and evolved, to LED backlamps.-410 is CCFLI will answer for CCFL as those just love to fail,but the the test is so easynow the answer for ANY laptop this old. 2007 and older. black screen all the time, and BIOS screens dead, answers only me. here. remove the main battery (large) it simply snaps off the bottom.the power pack is next we run the PC on your power pack AC to DC it must make the screen glow with something, do not use the wrong pack as in mixed up with others.now the lap top seems on, even the fan blows, LED glowpoint a flash lamp at the screen ,dark' room , and of you see any kind of LCD data on the screenthe CCFL lamp below #1 is bad.this is phase 1 testing, as other things can fail too. The keyword below is Mercurythis tells me it is those pesky CCFL glow tubes. 2007 is the year some PC went to LED back lamps. yes I was correct the service manual I did find proves they made both lamp types ccfl-hp07-psnmcz4s4yabbrmds04n13cd-d-0.jpg
4/17/2024 12:37:57 PM • HP Computers &... • Answered on Apr 17, 2024
Dove posso scaricare il driver per HP ScanJet 8270? ente compatibile per windows 10...
Question edited for clarity. Question translated to English. We only speak English on this North American website. https://www.google.com/search?q=hp+scanjet+8270+driver+windows+10
HP Scanjet 8270 Document Flatbed Scanner
Hewlett-Packard https://support.hp.com > ca-en > drivers > hp-scanjet-827... Download the latest drivers, firmware, and software for your HP Scanjet 8270 Document Flatbed Scanner ... drivers free of cost for Windows and Mac ... Windows 10 / ...
Hewlett-Packard https://support.hp.com > ee-en > drivers > hp-scanjet-827... Download the latest drivers, firmware, and software for your HP Scanjet 8270 Document Flatbed Scanner. This is HP's official website to download the correct ...
HP Scanjet 8270 Document Flatbed Scanner drivers - Download
Softonic https://hp-scanjet-8270-document-flatbed-scanner-drivers.en.softonic.com Download the latest and official version of drivers for HP Scanjet 8270 Document Flatbed Scanner. This driver package is available for 32 and 64 bit PCs. It is ...
HP Scanjet 8270 Document Flatbed Scanner drivers - Free ...
Download.it https://hp-scanjet-8270-document-flatbed-scanner-drivers.en.download.it Download HP Scanjet 8270 Document Flatbed Scanner drivers varies-with-device. Software drivers for the 8270 flatbed model of the HP Scanjet printer. ..
4/10/2024 8:38:39 PM • HP Computers &... • Answered on Apr 10, 2024
2answers
HP 8440P Laptop. I don't remember my password. Help needed for HP 8440p.
This video shows you what to do if you forget your computer password:
4/6/2024 8:00:24 AM • HP Computers &... • Answered on Apr 06, 2024
2answers
How to do a bios recovery on a hp pavilion dv5-1004nr
This video shows you how to restore the BIOS in your computer:
4/6/2024 7:57:59 AM • HP Computers &... • Answered on Apr 06, 2024
Hp dv8 not charging battery
You can follow the steps in this video to troubleshoot your battery:
4/6/2024 7:13:37 AM • HP Computers &... • Answered on Apr 06, 2024
Hp supply central pin connected to the 19V power
  1. Central Pin: In many laptop power supply connectors, especially those using the barrel-type connector, there's a central pin that carries the voltage (typically around 19 volts for most laptops) to power the device.
  2. Voltage and Polarity: It's crucial to ensure that the voltage supplied by the power adapter matches the requirements of your laptop. Most laptops operate on 19 volts, but there are exceptions, so always double-check the specifications of your laptop and the power supply.
  3. Polarity: Additionally, the polarity of the connector is important. The central pin typically carries positive voltage, while the outer sleeve of the connector is the ground (negative). Reversing polarity can damage your laptop, so make sure the connector is inserted correctly.
  4. Safety: Always use the power adapter that came with your laptop or a compatible replacement from a reputable manufacturer. Using an incorrect or incompatible power adapter can not only damage your laptop but also pose safety hazards such as overheating or electrical fires.
  5. Replacement: If you need to replace your laptop's power adapter, ensure that the new adapter provides the correct voltage, polarity, and wattage for your laptop model. It's often safer to purchase adapters from the laptop manufacturer or certified third-party suppliers to guarantee compatibility and safety.
3/30/2024 8:53:24 PM • HP Computers &... • Answered on Mar 30, 2024
3answers
I got a 4 year HP laptop and it show a black screen and if I press Esc it will say Esc..start up and will do the same F2 and others.
If your laptop starts but the screen remains black, this video shows you the troubleshooting steps to follow:
3/27/2024 7:16:54 AM • HP Computers &... • Answered on Mar 27, 2024
What kind of screws open the backside of an HP Envy PC
The screws are T5 Torx security screws. You can get a set of these screwdrivers from any DIY Store or from Amazon. https://www.google.com/search?q=torx+screwdriver+set I have a set like this which has a handle and all the security screw bits. https://www.canadiantire.ca/en/pdp/mastercraft-33-pc-torx-screw-set-0544039p.0544039.html ..
3/13/2024 5:33:03 PM • HP Computers &... • Answered on Mar 13, 2024
How do I open the back of an HP Envy PC, and What kind of screws open the back please.
Great questions, but two questions edited into one. The screws are T5 Torx security screws. You can get a set of these screwdrivers from any DIY Store or from Amazon. https://www.google.com/search?q=torx+screwdriver+set I have a set like this which has a handle and all the security screw bits. https://www.canadiantire.ca/en/pdp/mastercraft-33-pc-torx-screw-set-0544039p.0544039.html ..
3/12/2024 6:00:48 PM • HP Computers &... • Answered on Mar 12, 2024
2answers
What to try now hp omen dv7 battery issue
If calibrating the battery didn't work for you you could try a hard reset of the battery:
3/6/2024 9:11:06 PM • HP Computers &... • Answered on Mar 06, 2024
2answers
I have installed 4G RAM, Is that the MAX supported or may upgrade to more ?
Memory Max Maximum supported = 8GB
2/17/2024 5:55:53 AM • HP Computers &... • Answered on Feb 17, 2024
HP Business Desktop dc5700 - Intel Pentium Dual-Core E2140 1.6GHz - 512MB DDR2 SDRAM - 1 x 80GB - DV... Logo
11 questions posted
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • HP Computers & Internet
Most Popular Question
intel e2140 driver windows 7
  • Computers & Internet
