20 Most Recent ECM Giotto Espresso Machine Questions & Answers
Plumbing espresso machine
if this machine has a tank you fill for the the water it most likely will need some sort of lvl probe and inlet fill solanoid installed. best to check with manufacturer and see if your model originally had a model that could be hooked directly to water if not i would contact the company and see if they have the parts and if the control board in the machine has a fill circuit.
4/10/2014 5:40:05 PM • ECM Giotto... • Answered on Apr 10, 2014
0answers
0answers
0answers
Too high pressure
Be the first to answer 12/10/2013 10:19:29 PM • ECM Giotto... • Posted on Dec 10, 2013Be the first to answer
Not regular steam
First make sure that the nozzle is absolutely clean... If it is so, its most likely a problem with the mechanical steam valve spring. It could be that the spring is broken or even a pivot screw has come loose... You may need to open up the valve to check and clean
2/25/2013 7:47:31 PM • ECM Giotto... • Answered on Feb 25, 2013
My 5 year old Giotto has stopped working
The vent valve on the machine is stuck in the open position. Turn on the machine and open the steam wand until you hear a hiss or see small water bubbles from nozzle, let it steam out a little more then close wand, that should allow the machine to heat up correctly, then order a new vent valve for the machine.
7/24/2012 1:51:17 AM • ECM Giotto... • Answered on Jul 24, 2012
2answers
Where is ecm location 2006 holden rodeo has 3.6
Step 1. Have a good cup of coffee (but not that instant sh*t)Step 2. Look at the website page you are on more closely, and notice the lack of questions regarding Holdens, and cars in general.Step 3. Don't take this too seriously.Cheers, mate.
6/16/2012 6:34:18 AM • ECM Giotto... • Answered on Jun 16, 2012
ECM Giotto Espresso Machine Logo
79 questions posted
Top ECM Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
Sulejman Sulejmani
Sulejman Sulejmani
Kolbrun...
Are you an ECM Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
View Most Popular
ECM Coffee Makers & Espresso...
  • ECM Coffee Makers & Espresso...
Most Popular Question
plumbing espresso machine
  • Coffee Makers & Espresso Machines
